Old 10-16-2002, 08:23 AM   #3181
cornerspeed's Avatar
rcdougie-From what I see with your set-up that you will have more roll in the rear of the car because you have the front upper arms in the lower hole(higher roll center) and the rear upper arms in the upper hole(lower roll center). Try moving either the rear down or the front up. Experiment both ways. Also by you using the inner hole on the hubs, the link is short, this will reduce chassis roll. Everything else seems ok. What is your droop settings?
cornerspeed is offline   Reply With Quote
Old 10-16-2002, 10:40 AM   #3182
rcdougie's Avatar
I would rate the track's traction as medium to high. Its a smooth surface and has been treated with soda. My droop settings were 2, both front and rear using an associated droop gauge. Again, thanks guys for the help. Everyone in here is very helpful and doesnt hesitate to lend a hand. As a matter of fact just about everyone that I know that has a mission has been helpful locally too, just nobody around here is running a locked diff.
rcdougie is offline   Reply With Quote
Old 10-16-2002, 01:33 PM   #3183
Unless you are running very low foams I would say your droop settings may be way off, with full sized tires at 5mm ride height your actual uptravel is something like 6 or 7 mm... Try this for setting your droop...... set the rideheight, now set the chassis on the rideheight guage at a detting 2mm above your ride height, now adjust your droop screws so that the tires just touch the ground, now you have a setting of 2mm actual droop.
The problem with guages like the associated piece is that as your ride height canges the droop settings change with it, so when running foams as the tires wear you actaully loose droop, so a new set of foams will handle erratically different from a well used set.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 10-16-2002, 02:18 PM   #3184
Try a droop setting of 4mm front and 3mm rear using droop gauge. Running a spool diff is not always faster. Depends on the track, layout, etc. So you may go faster with a one-way. That will have to be your determination with practice runs and lap times.
Old 10-16-2002, 04:27 PM   #3185
AdrianM's Avatar
Pulleys will be in right at the end of the month. Just in time to throw foams on your cars and get ready for Cleveland!
Adrian Martinez
Old 10-17-2002, 02:11 PM   #3186
Send a message via AIM to ZER01
Mission owners, which side are your outdrive grub screws on? I installed the diffs like the manual says(left diff cover on left side of car) but now each diff bolt is facing opposite direction to the other.
ZER01 is offline   Reply With Quote
Old 10-17-2002, 02:37 PM   #3187
heavy's Avatar
Trader Rating: 20 (100%+)
They need to be that way to prevent pressure to loosen them. Think about it. In simple terms the rear diff is driven from the bottom and the front diff is driven from the top.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 10-17-2002, 02:42 PM   #3188
Cool Heavy, that's what I wanted to hear Reason I asked is because my XXXS both diff bolts are facing the same direction. Just wanted to be sure and thank you for the answer.
Old 10-19-2002, 01:54 AM   #3189
TeamPRP's Avatar
Thought some of you guys might be interested in these parts.
We're going to be selling graphite roll center plates for the Mission. Made from 2mm carbon fiber plate. These RCP's raise the front inner hinge pins, you guessed it, 2mm http://home.attbi.com/~teamprp/missionRCP.html
We also have a transponder mount that fits well onto the upper deck behind the motor and it doesn't get in the way of the upper deck screws. http://home.attbi.com/~teamprp/transpondermount.html
Both of these will be available first week of November and pricing will be finalized very soon.
TeamPRP is offline   Reply With Quote
Old 10-19-2002, 06:13 AM   #3190
Since we're on the subject of raised roll center, what have you that have performed this mod changed on your set up to get the most out of it? Also, does this mod perform best on asphalt or carpet surfaces?
PRP,
parts look good! I'll be getting these.
Adrian,
Where are the RW parts ( ie., part #s for online ordering) listed on the web site?
Stika525 is offline   Reply With Quote
Old 10-19-2002, 09:43 AM   #3191
Company Representative
Where can I find set-up sheets form the american drivers ? I am specifically looking for foam on carpet set-ups. All the schui site has are european drivers. Alos if anyone could give a point in the right direction on a carpet set-up for a small track thats far from smooth, I'd appreciate it. Thanks.
Gary F.
Gary Fliegel is offline   Reply With Quote
Old 10-19-2002, 09:34 PM   #3192
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Gary, post ur email address and I will email you my carpet setup! Its totally dialed, but you must have the warpspeed chassis.
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 10-19-2002, 09:36 PM   #3193
gfliegel@shaw.ca Thanks Cory, I appreciate it.
Old 10-19-2002, 10:13 PM   #3194
corey, could you send it to me also? james@autoworx.com
James Nguyen is offline   Reply With Quote
Old 10-20-2002, 11:35 AM   #3195
Trader Rating: 74 (100%+)
Default Axles for Axis
Does anyone know of a conversion for the MIP CVD style steel axles for the Axis, or the mission. The steel axles bind when I turn the wheel and the plastic ones keep breaking the pins out . Its really frustrating. Can someone please help.
Serpent USA www.serpentamerica.com, Maclan , Xpert, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, JSpec custom stickers and apparel.
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
