Old 09-30-2002, 05:27 PM   #3031
No the kit inserts are cheapy foams, the Tamiya pieces are molded
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-30-2002, 07:21 PM   #3032
Dragonxmx's Avatar
Default Mission frame
Thanks King-G
Yes I have machined a gear adapter; it’s a very tight fit to get the spur gear on this side and there is no way to do it with the kit pieces unless you can drill the shaft and machine the stock spur gear… and some spacers (e-mail me for instructions if you want to try). The only geometry change is the batteries, which are now straight along the chassis (since the spur gear in no longer in the way). Overall the chassis is about 10mm narrower than the stock one. The next two chassis will get a new battery strap that will allow the batteries to be move forward about 9mm or so by turning the strap 180 degrees around.
I made the motor spacers only as a prototype to check the feasibility, as it turned out they worked very well.
impactplayr your pic request is gone to my webmaster...
if he can stop tinkering on his Mission long enough to post them LOL
wrench
Dragonxmx is offline   Reply With Quote
Old 09-30-2002, 09:37 PM   #3033
Send a message via AIM to ZER01
Anyone here know the differnace between the Keyence V-Zero Extreme ESC and the V-Zero Extreme 2002 ESC? Are the wires replaceable on these?
ZER01 is offline   Reply With Quote
Old 09-30-2002, 09:45 PM   #3034
fireblade's Avatar
Send a message via AIM to fireblade
ProudWinner- When my friend comes back on, ill ask him. Heas the expert on the Zero extreme.
fireblade is offline   Reply With Quote
Old 09-30-2002, 10:20 PM   #3035
Post Keyence ESCs
I am pretty sure the Keyence Zero V Extreme and the Zero V Extreme 2002 are the same thing. The only thing that I noticed that was different was that the 2002 model has a better on/off switch on it. I dont think there is any difference between the two except that the 2002 is just the new 2002 model. I have them both and they dont differ in any way except that the 2002 has a different design on the face plate but I took that off and put the heat sink on anyways so they both look the same now. I will check them both again to see if there is any different settings in them. I have replaced the wires on both of mine and they have been working for a long time now with no problems. I'll keep you posted if I find anything else different between the two.
James Nguyen is offline   Reply With Quote
Old 09-30-2002, 10:36 PM   #3036
fireblade's Avatar
Theirs ur answer
Old 09-30-2002, 11:17 PM   #3037
Thanks James Nguyen and Fireblade.
Old 10-01-2002, 10:59 AM   #3038
Ian S's Avatar
Im not certain but i think the 2002 model has holes in the solder pads to solder the wires straight up like the quantum. Other than that and the faceplate i think there the same.
Ian S is offline   Reply With Quote
Old 10-01-2002, 12:38 PM   #3039
My older Zero V Extreme has the holes in the posts too.
Old 10-01-2002, 02:13 PM   #3040
Anyone know where I can oreder the RW diffs? and the bigger diff balls? I tried racing-cars.com but they did not have them up there any other placce have them in stock?
teamAE is offline   Reply With Quote
Old 10-01-2002, 03:55 PM   #3041
fireblade's Avatar
Call up Adrian @ Shumacher USA, and he will get em fo ya
Old 10-01-2002, 04:04 PM   #3042
Nice How much are they plus the bigger diff balls?
Old 10-01-2002, 06:38 PM   #3043
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Team AE.....the diff pulleys retail for 12.99 each......and what bigger diff balls are you refering to? The diff balls that were in the Axis series cars were bigger but the Mission uses the standard 3/32 diff balls.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-01-2002, 06:54 PM   #3044
one of the team drivers said that the new balls for the rw diffs are bigger
Old 10-01-2002, 07:15 PM   #3045
Kevin K's Avatar
Ummmm I dont know why they told you that they are not......I just put mine in my car and used my stock diff balls with no problem. Dont know what they were doing that they needed bigger diff balls
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
