Old 09-21-2002, 05:03 PM   #2971
Default Fusion?????
ADRIAN or PAUL---- any information on the Fusion w/ .12, like will the kit include an engine, and which one if it will, also will it include a pipe/header, and will the lay-out be the same as the .21 fusion??? Will the .12 version use the same 10mm wide front belt???? If so I may have to look into splitting it down the center......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-22-2002, 03:38 PM   #2972
I read a while ago that some of you were using Losi shock shafts and pistons. I assume that you were the .36 Losi shaft. According to my measurements the Losi shaft is .16" shorter than the stock shaft. Will this allow enough droop? Also what Losi piston is closest to the Vari-piston set to two holes?
Thanks in advance for your help.
racerdave is offline   Reply With Quote
Old 09-22-2002, 06:12 PM   #2973
Mopar's Avatar
RAcerdave, I adjust droop first then set the shock length to that max droop, seems to work fine for me. Although I dont use the Losi pistons because with the rounded sides you would need to use a heavier oil than with a squared piston. I prefer the RPM two stage pistons myself for the stiffer compression and softer rebound that it offers.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 09-22-2002, 06:16 PM   #2974
Mopar's Avatar
Thumbs up
Just 4 more weeks till I have my saturdays free. Then I can finnally go to SoCal again. Cant wait to try out the new car w/ the raised rc mod.
Old 09-23-2002, 06:04 AM   #2975
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
I may be wrong, but with droop screws, the only reason for setting the shock length is to adjust/limit the travel of the arm at full compression.
Any thoughts on that?
BigDogRacing is offline   Reply With Quote
Old 09-23-2002, 07:53 AM   #2976
fireblade's Avatar
Send a message via AIM to fireblade
Big Dog-I went to your website-bigdog graphic. Those bodies kick a*ss, Expect me to be sending my next body in their soon
fireblade is offline   Reply With Quote
Old 09-23-2002, 08:53 AM   #2977
Mopar's Avatar
Sorry if I misstated the intent. But w/ the Losi gold shaft the length (on mine) needs to be adjusted (longer) to match the droop setting.
Old 09-23-2002, 01:59 PM   #2978
Fireblade- thanks bro.
Mopar- ahhh, I gotcha.
Old 09-23-2002, 03:32 PM   #2979
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Guys I run the Losi gold shock shafts and have no problem with getting enough droop. I run my shocks at 67mm long just like I would with the stock shock shaft. The Losi shock shaft that I run is the standard one not the short one they run in the front. Im not sure where you guys are having trouble getting enough droop are your shocks long enough? I run my shocks this long so I can use the shock in any location and not worry about not being able to get enough droop.
Bigdogg.....the droop screws limit the down travel and the over all lenght of the shock will effect the up travel but the shock might have to be longer in the down travel to get the desired droop then it is need in the up travel. Does this make sence to you? You can limit the up travel by placing spacers on the out side of the shock shaft and still run the shock long to get the droop you need. If the shock is too long then when the shock is at full compression you might be hitting the shock shaft into the top of the shock body which can bend the shock shaft or make the car react funny. I hope that I did not confuse you more with this but its hard to explane.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-23-2002, 05:26 PM   #2980
Racer X's Avatar
Spoke with Paul today, the RW pulleys are now in stock...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 09-23-2002, 06:43 PM   #2981
Thanks Kevin. No, you didn't confuse me. I already knew that, but I didn't want to say that was the only reason when there could be others. As I've gotten older I've found out that I actually DON'T know everything....lol
Old 09-23-2002, 07:49 PM   #2982
Racer X Thanks for the help saturday night. I O U
JSCOTT is offline   Reply With Quote
Old 09-23-2002, 09:08 PM   #2983
STLNLST's Avatar
Trader Rating: 19 (100%+)
jscott & Racer X- Congrats on the wins this weekend. BN RACING was qualified 1,2,3 in mod but had a few unlucky incidents that didn't go our way. Jon a spot on the team is still here for you if you want it.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-23-2002, 09:43 PM   #2984
fireblade's Avatar
STINLST, were you at SW on sat?
Old 09-24-2002, 04:42 AM   #2985
STLNLST's Avatar
Yeah. I went there due to speedo borrowing (keyence blew up) and my carpool buddy couldn't go to Ripon this week. I will be there no matter who's driving this weekend.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
