Old 09-20-2002, 02:08 PM   #2956
Why would someone spend the extra cash on a Mission and then buy a hitec servo...... kinda like buying a corvette and then putting a Geo Metro 3 cylinder engine in it!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-20-2002, 03:12 PM   #2957
no I would buy things then say how good the mission is compared to them
teamAE is offline   Reply With Quote
Old 09-20-2002, 03:38 PM   #2958
fireblade's Avatar
Send a message via AIM to fireblade
na dude, i got rid of the hitec. too damn slow for me.!
now iam runnin Airtronics (forgot the number but the last 2 digits are 57) its Digital,BB,Metal and FAST!! Set me back $135.99 And clint, its not the car, I have always drove that way, It does a few things for me 1.Helps me setup for the next corner 2. gets me ready to move if somebody crashes and 3.Easier to pass people. I even did this when I raced Go-Karts.
Ive never really went "straight".
IMPACT- Geo's have 3????? I thought they only made 4? Talk about a econmy car
fireblade is offline   Reply With Quote
Old 09-20-2002, 05:10 PM   #2959
I run a hitec servo the best one they make and there is major slop in the servo it self!!!!! I need a Air really fast.
Old 09-20-2002, 05:16 PM   #2960
heavy's Avatar
Trader Rating: 20 (100%+)
Why mess with the rest - get the best - it's still KO
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 09-20-2002, 05:20 PM   #2961
fireblade's Avatar
KO's are good too
Old 09-20-2002, 08:48 PM   #2962
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
I just bought two brand new KO 2123 digital fet servos from Hobbytown with the gift certificates I won in the Beat the Heat Race here in Memphis.
I can't wait to try them out!!!
I think the specs are:
High Speed Digital Type Metal Gears 55.0g (1.94oz)
38(1.50)x41(1.61)x20(0.79)mm(inch)
Torque / 9.5kg-cm (131.19oz-inch) Speed / 0.06s / 60o
Double Bearings, Coreless Motor Supply Voltage 7.2V
BigDogRacing is offline   Reply With Quote
Old 09-21-2002, 04:34 AM   #2963
Cole Trickle's Avatar
BigDogRacing, all I can say about the 2123 is.... you wont be dissapointed !
Cole Trickle is offline   Reply With Quote
Old 09-21-2002, 07:30 AM   #2964
STLNLST's Avatar
Trader Rating: 19 (100%+)
see......someone did put that engine in a corvette....LOL
Bigdog- I'm sending you those pics before I run this body this weekend. I changed the colors slightly. Due to lack of time and a real need to run this body this weekend, it didn't come out too good. Once me job stops with these 12 hour days then I'll have more time to due a body justice.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-21-2002, 10:10 AM   #2965
senna's Avatar
Hi everyone !
Do you know where I can buy lightweight pinions?
Regards,
Senna
senna is offline   Reply With Quote
Old 09-21-2002, 11:32 AM   #2966
Ian S's Avatar
Titanium Racing make Ti pinions, you can get them from Schumacher i think. Mine 25 tooth weighs 2 grams compared to my steel 25 tooth weighing 4 grams.
Ian S is offline   Reply With Quote
Old 09-21-2002, 01:22 PM   #2967
Regional Moderator
Darkseid's Avatar
I bought a 27 tooth TIR pinion, and I am totally unhappy with it! I mounted it up along with the Schumacher 86 tooth kit gear. The gear was so out of round that it was barely making contact on one side and nearly locked up against the spur gear on the other side! I know the motor shaft is straight and I know the Schumacher kit spur is round because it meshes well with my RRP, Trinity, HPI, and Yokomo pinions. So it had to be the TIR gear. I plan to try it with my RW spur gear to check and see if I get the same results, because I know how perfectly round the RW spur is.
I don't know if I got a bad one or what, but its almost unuseable. I was quite disappointed.
TLR 22...Tamiya F104...
Old 09-21-2002, 04:19 PM   #2968
Default PINION
If everything else is OK, there is one other thing you might want to check. Make sure that when the pinion is tightened onto the motor shaft the grub screw has full contact and is not hanging slightly over the end of the shaft. This can cause a pinion to run way out of true.
Otherwise you can return it....I am sure they would be helpful.
SCHUMission is offline   Reply With Quote
Old 09-21-2002, 04:50 PM   #2969
The problem probably is when they stamp the # on the pinion they probably smashed it a little We have had a couple of them like this.Get in contact with Adrian or Paul they will be glad to help.I also have the Ti pinions and they are the Truest ant lightest pinions I have ever ran.
Chris H is offline   Reply With Quote
Old 09-21-2002, 05:02 PM   #2970
Default NEW HOBBYSHOP AND TRACK!!!!!
Just to let anyone who s interested know there is a new Hobbyshop and track near me and they carry Schumacher,RW, and TIR equiptment.... actually he is a very inthusiastic supporter of Schumacher!!!!
INFO:
Gar-Lands' RC Car land and hobbies
635 summit ave.
Hagerstown, MD
Phone# 301-416-4700
Garland is a great guy and has a direct connection to Schumacher USA via the Schuie-phone....LOL
Actually I asked about the RW pulleys on Friday morning and he has them on the way already!!!!! He also has the Fusion in stock and let me say it i pretty awesome!!! can't wait until the Fusion Pro (.12/ 2 speed) is released so I can get my next racer!!!!!
OHH yeah Schumacher USA has the RW pulleys in stock!!!!!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
