Old 09-15-2002, 05:02 PM   #2896
Mopar's Avatar
PS , I like to use Silver front and Green rear.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 09-15-2002, 07:02 PM   #2897
heavy's Avatar
Trader Rating: 20 (100%+)
Default Re: Front belt on Mission
Originally posted by FTD RACING
I have just purchased a second hand Mission today. Have seen them going fast at my local track and thought it was time to try something diff.
I have noticed that the front belt is very tight, it doesn't even use the belt tensioner. Is this normal? It has the standard belts on it. Any tips on making it a bit looser?
Also, what effect does useing the in-board toe in front and rear?
Thanks for helping.
FTD. Make sure that the Layshaft Mounts are correctly installed. If you don't have them teh correct way to suit whichever layshaft pulley you are using then you can end up with a loose rear belt and tight front belt. Check your manual page 7 for the correct orientation of this part - very important
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 09-15-2002, 07:08 PM   #2898
I knew the weights on the Associated springs, but the Schuie springs are rated in metric tons or so crap....LOL I have a full set from when I ran TC3's.......
Thanks for all the help!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-15-2002, 07:20 PM   #2899
fireblade's Avatar
Send a message via AIM to fireblade
Ide just call up Adrain and ask him.
fireblade is offline   Reply With Quote
Old 09-15-2002, 09:20 PM   #2900
Impactplayr,
Black 6lbs
Grey 10 lbs
Blue 15lbs
Red 20 lbs
Yellow 25 lbs
Silver 35 lbs
racerdave
racerdave is offline   Reply With Quote
Old 09-15-2002, 10:02 PM   #2901
fireblade's Avatar
Go with Green!
Old 09-16-2002, 12:29 AM   #2902
heavy's Avatar
Go with Schumacher Blue both front and rear - 45wt oil and two holes open in teh shock pistons. You will be able to use that setup on both carpet and tarmac
Old 09-16-2002, 04:04 PM   #2903
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I personaly like the Losi springs over the Associated. The Losi springs feel better and the car seems to work better for me when I use them over Associated springs. The Associated springs seem to get too stiff the deeper in the movement of the spring and the Losi are more constant through out the whole compression range. But what ever springs you can get or work for you run them.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-16-2002, 04:21 PM   #2904
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Default Re: Re: Front belt on Mission
I bet you're right Heavy- good call!!
I can't believe I didn't think of that.
BigDogRacing is offline   Reply With Quote
Old 09-16-2002, 05:22 PM   #2905
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Does anyone have comments on XRAY Evo 2 springs.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-16-2002, 05:26 PM   #2906
does anyone have a stock/mod setup for high bite asphult?
And gearing as well, I race at socal raceway which is a small to med size track.
thanks
teamAE is offline   Reply With Quote
Old 09-16-2002, 05:41 PM   #2907
fireblade's Avatar
here is my setup for asphalt
Front-
Shock Piston-2
Spring- Associated Red
Oil-45 WT
Diff-One Way
Camber-1 1/2
Toe-0
Castor-2 small kwik clips
Tires-Sorex 36r With Blue Inserts for day & Cs-27 at night (Depending on track temp, 36r-82-98 degrees, cs-27 75-82 degrees) Tires Depend on Track Temp. I Used srex 36r and the whole car stuck like glue.
Rear-
Shock Pistion-2
Diff-Diff
Spring-Associated Gold
Oil-45 WT
Camber-1 1/2
Toe- 3
Castor-3 Med.size Quick klips
Tires-36r
Motor-Trinity p2k2
Body-Trinity Stratus
Gearing- 17t pulley, 25 pinnion, stock spur
Hope this helps. This is a p2k2 setup, Car is Extremeley fast. I won got 2end in my first heat and 1st in my seconed heat.
Hope this can help yall out
Old 09-16-2002, 05:52 PM   #2908
thanks I will give it a try on sat
oh and about the pully I have been using the 20t, is the 17 better for stock?
Old 09-16-2002, 06:50 PM   #2909
fireblade's Avatar
Well, I hear that 20 is a little faster than the 17. But my car has tons of motor over all the other guys cars so its about the same for me. But my gearing is with the 17 so ide install the 17. What motor u using?
Old 09-16-2002, 08:55 PM   #2910
From the info I have collected from running the Mission with the 20 and 17 tooth pullies is that with the same final gear ratio the top speed of the car is the same. The difference is that if you use the 17 tooth pulley it will get up to speed faster than the 20 tooth pulley. It all depends on your track layout. If you run on a long flowing track, use the 20 tooth. If it is a short track, use the 17.
James Nguyen
p.s. Garrett, you don't have motor on me....hehe.
James Nguyen is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
