Old 09-12-2002, 06:58 PM   #2881
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Godzilla.....most of the tracks around here are indoor carpet and they are about 75 to 90 feet long by about 50 and some of the outdoor/parking-lot type tracks are about 115 feet long. So the track size is relative to what you have to race on you know.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-12-2002, 10:20 PM   #2882
Trader Rating: 238 (99%+)
Any one have a good starting setup for the mission on carpet with foams?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 09-12-2002, 10:28 PM   #2883
fireblade's Avatar
Send a message via AIM to fireblade
I dont really dont know but. all i can say is Team Schumacher
www.rcacing-cars.com
Team Webb Tech/Pro-Wind Motors
www.teamwebbtech.com
KO Propo
www.kopropo.com
ur team shumacher site is-rcacing-cars.com, we all make mistakes.
its actually www.racing-cars.com. u misspelt racing. hey, its ok, i bet iam worse!
fireblade is offline   Reply With Quote
Old 09-12-2002, 10:58 PM   #2884
Why dont you guys specify rollout, as this takes out all the variables, and is a much easier term to compredend what the differences in your gearing are.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-13-2002, 09:20 AM   #2885
Thanks Fireblade I fixed it!!
Old 09-13-2002, 03:18 PM   #2886
fireblade's Avatar
thats ok, i had the same prob
Old 09-14-2002, 10:34 AM   #2887
RC Raptor's Avatar
Send a message via AIM to RC Raptor Send a message via Yahoo to RC Raptor
Angry Florida Racing
Where is everybody racing in Tampa Bay this weekend?
RC Raptor is offline   Reply With Quote
Old 09-14-2002, 03:36 PM   #2888
Default Front belt on Mission
I have just purchased a second hand Mission today. Have seen them going fast at my local track and thought it was time to try something diff.
I have noticed that the front belt is very tight, it doesn't even use the belt tensioner. Is this normal? It has the standard belts on it. Any tips on making it a bit looser?
Also, what effect does useing the in-board toe in front and rear?
Thanks for helping.
FTD RACING is offline   Reply With Quote
Old 09-15-2002, 07:14 AM   #2889
Send a message via ICQ to MattW
Tony, No this isn't normal. The front belt should generally be fairly loose. It is a while since i ran a std belt, but it wasn't any tighter than the grey ones. The only thing i can think of checking is that there isn't something crushed into either the diff pullies, or even into the teeth of the belt.
MattW is offline   Reply With Quote
Old 09-15-2002, 09:01 AM   #2890
Racer X's Avatar
FTD: The front belt can be run very loose, especially in stock. Instead of having to go around small drive pulleys, the belt goes around the two large diff pulleys. The extra teeth and larger pulley means less tension is needed to keep the belt from skipping. Some people run the grey belts, which are supposed to be freer (and some will swear by them), I didn't notice much difference between a greay belt and the stock belt after soaking it in WD40. Its your choice.
Inboard toe adds more traction to whatever end of the car it is on, but if the car is hooked without running the inboard toe, adding it will slow the car down a couple of tenths (so it has been said). If the car is loose, and nothing else seems to be able to hook the car up, the inboard toe usually will, in which case, the car will go faster. It's just one more adjustment that you will need to experiment with and see if it suits your driving style...Hope that helps.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 09-15-2002, 11:29 AM   #2891
fireblade's Avatar
I run 3 degrees toe in on my rear with a powerful motor to still keep it rollin fast. With the power of the motor and the traction of the car is about the best combination u could have!
Old 09-15-2002, 02:55 PM   #2892
Which Associated springs are closest to the grey Schuie sprngs????
I will be running on a bumpy carpet track this winter along with a smooth asphalt track, so to keep me from having to rebuild shocks each week I will be running Tamiya shocks with associated springs on the carpet track and need a place to start with Associated springs........
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-15-2002, 04:52 PM   #2893
fireblade's Avatar
What lb is the grey shumacher spring and i can tell ya.
Old 09-15-2002, 04:55 PM   #2894
This is the list of Associated springs....
Green=12lb
Silver=14.5lb
Blue=17lb
Gold=19.5lb
Red=22lb
Copper=25lb
Purple=30lb
Yellow=35lb
White=40lb
The grey Schumacher spring is pretty close to the Blue Associated. Probably in between Silver and Blue.......
SCHUMission is offline   Reply With Quote
Old 09-15-2002, 04:59 PM   #2895
Mopar's Avatar
This is off of the package for Asc spring set[list=1][*]Green 12.0 lbs[*]Silver 14.5 lbs[*]Blue 17.0 lbs[*]Gold 19.5 lbs[*]Red 22.0 lbs[*]Copper 25.0 lbs[*]Purple 30.0 lbs[*]Yellow 35.0 lbs[*]White 40.0 lbs[/list=1] Hope this is some help.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
