Old 09-10-2002, 10:33 PM   #2866
fireblade's Avatar
Send a message via AIM to fireblade
O yea. I run Ti hinge pins and Ti Turn Buckles. The stock ones can brake easily and for the hinge pins. I herd that they brake a little easier but they dont bend, they brake. Ide rather have a broken hinge pin to tell me to replace it instead of a bent one that messes me up in a race.
fireblade is offline   Reply With Quote
Old 09-10-2002, 10:35 PM   #2867
fireblade's Avatar
I run the Stock spur with the 17t pulley and a 25 pinnion. The car is the Fastest top speed and the fastest off the line while running a P2K2!
Old 09-11-2002, 08:13 AM   #2868
is the stock spur 48p? I will give that a try then. I get it today
teamAE is offline   Reply With Quote
Old 09-11-2002, 08:29 AM   #2869
I run my MVP around 9.11 FDR usually...LOL and yes it gets smokin' hot, but the think is crazy fast....LOL
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-11-2002, 03:24 PM   #2870
fireblade's Avatar
Yea its 48p.
Old 09-11-2002, 03:51 PM   #2871
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Impact- show me your math to get 9.11
That's about what I would gear a 9double.
BigDogRacing is offline   Reply With Quote
Old 09-11-2002, 03:59 PM   #2872
fireblade's Avatar
Heas gearin a MVP stock at 9.11??????????? HO shit, iam surprised u dont blow a arm!
Old 09-11-2002, 04:57 PM   #2873
I don't understand the numbers you guys are stating as gear ratios.
Here in Australia at the TFTR track we have the best, highest level, club racing in the country and everyone gears stocks and mods around 6:1.
I personally hold the fastest lap record for stock and that was done running the 31:86 with the 2.12 internal - about 5.85 I think.
I might also mention it was done using a P2K2 Pro, straight out of the packet, no mods.
Godzilla is offline   Reply With Quote
Old 09-11-2002, 07:01 PM   #2874
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Godzilla......How big is the track that you are racing on? With that ratio you have got to be on a track with 120ft straight or more. We all need to consider the size of the tracks when we say what ratio we are using. If the track is super long then yeah you can run a lower number ratio or if its short then you can run a higher number ratio. The ratios I run are mostly on tracks about 80 to 90 feet long and some are tighter then others so you need to adjust for that. There is no magic ratio that you will always run at every track. I dont think anybody is wrong with what ratio they said they are runnig we need to look at other factors like what size track and how tight it is and what not.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-11-2002, 09:08 PM   #2875
what should I gear stock at(p2k and a mod) 8x2?
Old 09-11-2002, 09:36 PM   #2876
Info From the Stockton Carpet Track:
http://www.riponspeedway.com/Page.cfm
9-9-02
Carpet schedule updated. Our first race is on the night of Wednesday, October 16th. Note that foam tires will be allowed in the modified and 19T touring car classes... :-) but not in the stock touring car classes :-| See ya on the rug!!!
Foam!!!
Mr. G is offline   Reply With Quote
Old 09-11-2002, 09:38 PM   #2877
fireblade's Avatar
ahh yea baby! my 1st time on carpet. See what goes. Hey Mr.G what ur name?? you probley know me, I race sportsman and iam the kid that usedto have Tall Bleached hair and I wear sunglesses.
Know who iam??
PM me!
Old 09-12-2002, 09:22 AM   #2878
Well let's see.... looking at the ratio chart in the back of my manual.........
Pulleys 17/36
86 Tooth spur
20 tooth pinion
FDR=9.11
I stumbled across this at a tight indoor asphalt track (60x40).
I was practicing with a 16T double, and when I switched the MVP in I forgot to change the pinion, and it was silly fast, then I realized what I had done I switched in the 24 I usually used.... and it was slow!!!!
I run the same ratio at the local track which is carpet, and a little smaller, but not as tight......
Old 09-12-2002, 01:27 PM   #2879
Mopar's Avatar
Almost have my #2 Mission ready for its test drive. I built this one w/ raised RC. Cant wait to try it. Hey Adrian, I was told by Hobby Central that you will no longer be carrying the CS Rocket Max ESC's, this true? If so too bad, I like mine a lot. Just waiting for the last goodies for the new car to further the first car.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 09-12-2002, 04:46 PM   #2880
Kevin K, yeh our straight would be about 40 metres long so you're right. What size tracks do you guys race on? I'd call TFTR a medium-large track, we have bigger.
Last year in our state champs race, the winner ran stock (mvp I think) at 4.3:1, he was stupidly fast when he got a smooth flowing run.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
