Old 09-04-2002, 01:03 AM   #2806
Send a message via ICQ to JesseT
Well I bought two Sanwa (Airtronics) ERG-XS servos in about - 93 or something and I've never had any trouble with them ever since. So they have lasted nearly a decade and are still competitive racing equipment. Only my Sanwa Machine1 radio and 10x15 diff Boca bearings have lasted longer. The Bocas I bought for a Yokomo dogfighter I had ages ago. Since then the bearings have found new homes in many Yokomo and Schumacher cars and I now have them in my Mission. Great stuff.
About the tweak stuff. I agree. I'm also very glad Scumacher got rid of the tweak problems with the Mission. The Axis was a real pain.
JesseT is offline   Reply With Quote
Old 09-04-2002, 04:14 PM   #2807
fireblade's Avatar
Send a message via AIM to fireblade
1993????? HO Sh T Damn thats hella long for a servo!!
fireblade is offline   Reply With Quote
Old 09-04-2002, 06:51 PM   #2808
Default xxx-s versus Mission or maybe axis 2
Anyone go from Losi to Shu Mission! I'm giving it plenty of consideration, but I've noticed at the local track the Axis 2 is still the commanding car.
What is the best performance hop ups to do during the build, not the aluminium nice looking stuff performance items like one-way, light weight items etc.
Mr. G is offline   Reply With Quote
Old 09-04-2002, 07:38 PM   #2809
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Mr. G- go with the Mission. It's a far better car according to all the diehard Schuie guys I know.
As far as hopups, get the roll center blocks and the threaded shock bodies. If you're into good hardware, get the titanium screw kit and you won't have to mess with the hoopty wood screws that come with the kit. Also decide if you want to run Schumacher springs or associated TC3 springsd and get them from the beginning. Might consider using the Schumacher nonadjustable shock pistons too. If you're a oneway front diff fan then get one, but I don't see that as a neccessity from the beginning.
Hope this helps!!!
BigDogRacing is offline   Reply With Quote
Old 09-04-2002, 07:40 PM   #2810
fireblade's Avatar
I came from the Third world land of The Losi and Came to the Country of Shumacher.
Old 09-04-2002, 07:53 PM   #2811
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by fireblade
From where I come from there are tons of shuie guys, Yea its normal for a shumacher to kick ass and take names
We'll see where that Schiue ends up this weekend as I may bring a power house of Losi cars with me to Ripon....LOL The sad thing is that the schuie that keeps winning weekend and week out is an Axis 2. Doug Lemmons has been on a tear. He's going to be real tough to beat if there isn't a mod class. Are you racing this weekend? I better tune a couple of stockers just in case. I'm coming up with a couple of schuie master (Racer X & the cop) See you there.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-04-2002, 07:56 PM   #2812
STLNLST's Avatar
the shuie is a good car but to be honest with you......when you had your Losi you were asking the shuie guys for set up advice. What could they tell you about the car??????? I may have to let you squeeze a pack or two off on mine
My broadband is still sloooooooow!
Old 09-04-2002, 08:02 PM   #2813
King-G's Avatar
Send a message via ICQ to King-G
ahh, my favorite topic, hopups, and ditching Losi's (dont worry its a local joke)
as for the Mission we are finding the car to be the most durable at our club, it continuosly comes away unscathed from hits that would have broken the Losi, tc3 and others...we find that breakages are very minimal, only upper arms are worthy of a mention. The little pivot Kingpins which screw into the underside of the steering hubs can bend, these are worthwhile checking each race day, as it can go undetected for some time, with weird handling traits.
also the mission is very Lightweight in Kit form...the other guys at our track are buying carbon this, Graphite that, alloy and Ti to get anywhere near the weight of the standard missions.
as for hopups, (for stock), definately go for both the grey belts, these along with the new RW racing machined pulleys make the mission a friggin efficiency machine!...
For Mod you can run the front grey ultraflex belt only, but soak the rear belt in wd40 overnight to really help.
for tuning options, always pick up 2 packs of springs (1 pair of each tension per pack)
I like the oneway Diff, but the mission is very fast in 4wd trim also, there was a lesser improvement once using the oneway on my mission than with previous cars raced. (for most cars it is mandatory, but I feel that the mission has plenty of steering and holds good cornerspeed out of the box),
so this one is personal preference.
For strength and Weight savings, look at the Titanium Turnbuckles, especially for the rear toe, the Kit ones are stong enough, but Ti is just horn. also you can look at the Titanium lower hingepins (dont bother with the upper ones, as they never bend!.
again, I never had a problem with the Kit items as they are pretty strong, but i am a sucker for hopups.
The alloy Layshaft mounts are one alloy item I recommend (along with the alloy layshaft pulleys, as these Items give consistent rear belt tension, and resist wear, skipping and chassis flex/ and provide a solid mount for the topdeck.
The Threaded shocks are usefull, along with the alloy bottom seal retainers, these items give good consistent dampening, without stiction.
For carpet or high grip asphalt, you can run the stiffer top deck, for added rigidity..It helps isolate all the forces through your suspension, and helps prevent scrubbing cornerspeed.
I have all of the available hopups on my car, and find those few to be the best bang for your buck.
If you wanted to go one step further, then look at the alloy Diff mounts, these have helped free up my car a little also, and give consistent chassis tweak as they are a more solid mounting point for the topdeck.
some hi quality fully sealed bearings (bocca accer etc...) I still run Kit type bearings in the hubs, and Tamiya blue seals for the Diffs.
I have the Ti screws, but dont find them to be of real benefit, as the Ti isnt much harder than the kit ones, and can still strip out, once you get to this point the weight savings are becoming less of an issue, as the car is underweight, but I have added 45 grams to my car on the left side to get it perfectly balanced, so every bit does count.
King-G is offline   Reply With Quote
Old 09-04-2002, 08:42 PM   #2814
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
There is not too much that you need to hop up on the car like you do other cars. If you have the money there are plenty of things that you can buy but for the most part the kit is good from the get go. All I would suggest is the Titanium tierods for the rear toe links and the Alum Y blocks. Threaded bodies are nice but are not really needed the same with a 1 way.....even though I like a locked diff better some people like the 1 ways. Going on what King G said about the king pin screws you can now get them out of Titanium so they will not bend as much as the stock ones. Also the Warpspeed chassis is very nice and makes the car more responsive and its more balanced out more then the stock chassis. Things like the Alum Pully and diff mounts are nice or are something to change when the stock ones wear out or stip. This is one of the only cars that I can think of that when you get the stock kit there is not much more that you have to get to be fast, and the car is very durable compaired to alot of the cars on the market now.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-04-2002, 08:59 PM   #2815
King-G's Avatar
Ti Kingpins?..im on it!
Old 09-04-2002, 09:44 PM   #2816
Default Mission Hop-ups
Great web site, Thanks for taking the time to list all your suggested hop-ups.
Yes Doug is on fire with the Axis 2 in Ripon and Sacramento !
Old 09-04-2002, 10:34 PM   #2817
fireblade's Avatar
For some reason my losi turned hella wide, I did different shock mount places and a bunch of other stuff i can't remember to make it turn harder. Yea ur probley right, I should of asked YOU or some other losi guys or the man himself Matt. I still like my losi, Makes for a good backup car and its still WAY FAST. My mission only beats it cuz its lighter and has a more powerful motor and it turns faster.
Old 09-05-2002, 12:25 PM   #2818
Fireblade or anyone,
Where can I purchase RW racing stuff (like the machine gear)?
Where can I purchase the grey belts as mentioned for the Mission?
Warpspeed 2mm or 3mm I'm thinking 2mm and add thicker top deck for carpet, any comments.
Old 09-05-2002, 12:50 PM   #2819
Mr. G- not sure about the RW stuff, but you can get the belts at Schumacher USA or Speedtech R/C
Old 09-05-2002, 12:56 PM   #2820
Mr.G you can order the grey belts as well as R.W gears thru Shumacher USA
BrianJ. is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
