Schumacher Corner
Mi2
Hello Gentlemen and Ladies,
First Please don't shoot. I was wondering if drivers out there have experimented with different belts for the mi2. As far as using another brand other than the schumacher for belts, pulleys etc? Its been a little tough finding parts locally for it. In addition the pulleys teeth are starting to chip away. And I will have to get replacements. Totaling the parts that are needed I'm just over 75$ in replacement parts. I wanted my son to race this for vta and usgt once he has enough confidence to get the laps in. I just don't want to have to wait for the parts from the UK all the time. Any info would be much appreciated.
Thank you in Advance
okay we know all kind of cars are out there. so I am sticking with my MI4cxl for now... I put the MI5 hubs around on my car with the 6 degree front carrier barrier. the car loosened up in the back dew to a shorter camber link location.
Should I raise the camber link plate or find another hub plate that will lengthen the camber link?
Thanks.
Thanks.
Thanks.
Thanks.
IMO i would suggest finding a replacement stewart, i think you will then find your lap times improve, or stop procrastinating and buy the evo, use your cxl in vta. im just busting your cahohnas you have a great car, wouldnt raising you camber plte give you a lower roll center an more bite
Shark
mi4cxl 17.5
front camber 2
rear 1
camber plates f/r stock #3 washer on top. flat on bulkhead.
everything else is stock.
4 degree camber blocks with mi5 hubs and carriers.
rear mi5 hubs.
stock top plate all screws tight.
droop 5 in front.
droop 3 in rear.
blue AE front springs. 17.00 lbs.
blue schumacher rear springs.16.00 lbs.
40wt. oil.
Looking to buy the spools for the Schumacher Mi3 ( Part number U3225). Please could you let me know any reliable place to buy them online. I'm located in the United States. Is this a good online store:
http://www.racing-cars.com/pp/Old_Ca...3.5/U3225.html
