Old 12-29-2010, 09:52 AM   #27646
cuttingedge's Avatar
I agree with GK on this one the only weak point in the LP was the drive shafts , thats why every one ran TR or Litmodz stuff But the new ones on the cx seem outstanging quality
see them here at www.car69.me.uk for some close up pictures of them
Schumacher uk - Litemodz - Potters Electrical Supplys - The Sign Shack - www.car69.me.uk - Akula Racing
cuttingedge is offline   Reply With Quote
Old 01-01-2011, 11:52 AM   #27647
Default MI3.5
What spear gear size 64p is recommended for 17.5 and 13.5 with Timing ?
2Quick is offline   Reply With Quote
Old 01-01-2011, 02:02 PM   #27648
lochness42's Avatar
Originally Posted by 2Quick View Post
What spear gear size 64p is recommended for 17.5 and 13.5 ?
I'm running 114t with 10.5 and 13.5 and no timing in my LP.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-02-2011, 09:14 AM   #27649
Thanx
Can I run the same with Timing ?
Old 01-02-2011, 09:26 AM   #27650
lochness42's Avatar
I ran it also with timing boost before we settled on no timing rule.
The higher timing you run, the smaller pinion/bigger spur you want to run.
Pavel Balint
Old 01-03-2011, 05:51 AM   #27651
My son runs a MI3.5 in vta and we are trying to find a good base set up for it. Will the suggested rubber tire for carpet be the best place to start?(only difference is associated blue springs on front and silver on back) The setup he had on it pushes like a dump truck unless you have like new tires on it. We need to find a setup that works with old tires as well. ANY help would be appreciated.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 01-03-2011, 08:03 AM   #27652
If its only pushing when the tyres have worn it says to me that the tyres are wearing into the camber. Either try rotating you tyres around more often or reduce the camber, probably on the rear!
YZFAndy is offline   Reply With Quote
Old 01-03-2011, 08:34 AM   #27653
MikeXray's Avatar
Trader Rating: 73 (100%+)
try this setup
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-03-2011, 11:42 AM   #27654
Originally Posted by MikeXray View Post
try this setup
Mike we will give it a try THANK YOU very much!
J. Barton
Associated B5M
Associated RC8B3E
Old 01-04-2011, 03:31 PM   #27655
Default Schumacher MI3
So I just bought a MI3 roller on rctech with a grip of parts and rubber tires for a sweet deal. The deal is that our club mostly does foam we really dont have many people so not really a stock class. So the question is, do I run mod rubber can I do that? The track said thats what we can do it's ok with them to do that but again should I? Would I stand a chance agaist foam tires? What spedo and brushless system should I be looking into? I know I have many questions but there is many choices out there in onroad and i have been a nitro guy for sometime. Any help would be super sweet... Thanks
mattythegreat is offline   Reply With Quote
Old 02-01-2011, 06:22 AM   #27656
Default MI3.5
Can someone tell me what the different size Pivot Block Spacers does to the handling ?
Old 04-07-2011, 02:51 PM   #27657
koval's Avatar
Default problem with stability (mi 3.5)
hi guys!i have a sh. mi 3.5 with a xerun 9000kv !when starts accelerating the car began turning ,as the accelerating is incresing this problem getting worst.try to change settings more n more toe in and the things wasn t so bad but still very annoying .i bought the harder 3mm chassis but nothing at all change arms nothing !!i have this car for about 2 years and i love the durability of that car ,let me know if i can do something for that!forgot to say i run with foam tyres in asphalt!!
koval is offline   Reply With Quote
Old 05-01-2011, 08:07 PM   #27658
idbdoug's Avatar
Trader Rating: 33 (100%+)
Does anybody know a shop or shops that stock Schumacher MI3/3.5 parts in the U.S.A.?? Stormer appears to be stocking most of the parts. Any other shop online or not.
thanks
idbdoug
idbdoug is offline   Reply With Quote
Old 05-01-2011, 09:00 PM   #27659
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
You can anything you'd want from www.racing-cars.com
Old 05-02-2011, 12:12 AM   #27660
US Dealers
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
