Old 09-03-2009, 12:22 PM   #27511
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by outlandr91 View Post
I tried to pry them off but they are really tight. I took the steering knuckle off the car and tried to use a larger flat blade screwdriver but didn't have any sucess.
[6291026]If mine are on there real tight I just gently pry them off with a small flat tip, or xacto blade
[/QUOTE]
take off the o-ring, drop the pin out, put the wheel back on and spin it while holding the outdrive with a screw driver or allen wrench.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-03-2009, 05:06 PM   #27512
That did the trick! Thanks very much
take off the o-ring, drop the pin out, put the wheel back on and spin it while holding the outdrive with a screw driver or allen wrench.[/QUOTE]
outlandr91 is offline   Reply With Quote
Old 09-06-2009, 05:35 PM   #27513
Shawn you have a pm.
Originally Posted by Shawn Palmer View Post
chicagokenji:
Al's Hobby is probably your best bet.
Old 09-09-2009, 03:19 AM   #27514
koval's Avatar
yesterday as i driving my mi3.5 sudenly the left drive pin broken. i took the wheel and the outside bearing didnt turn at all and the inside was totaly broken!after that a friend told me that an overthithen wheel can cause a broken pin !but why the bearings broken?should i buy tko or other good quality bearings or shumachers bearings is better?
koval is offline   Reply With Quote
Old 09-10-2009, 03:09 AM   #27515
koval's Avatar
filinaly i order a set of abec 35 bearings(hope thats good)!!now i need to buy new drive pins for my mi3.5 from uk because in my country no one knows schumacher so i ll make an order with plenty parts !what parts you think are the most susceptible such as drive pins or driveshaft?
Old 09-16-2009, 06:55 PM   #27516
How are you guys anchoring your lipos in the mi 3.5?
I'm using tape but I'm worried they'll slide out the side.Is there a plate available?
Old 09-17-2009, 12:50 AM   #27517
koval's Avatar
[ATTACH]500260[/ATTAC
as you can see in the fotos i use lipos with nimh pack dimensions.this plastic holder i use is from a sst rally part mumber u2038 that fits very well in the mi3.5 and hold battery very well even after a strong crash!
Old 09-17-2009, 08:38 AM   #27518
Trader Rating: 22 (100%+)
There are 3 ways to do it:
1. Schumacher sells Li-Po Locators which are little carbon fiber pieces that fit the battery slot that can be glued onto the battery to hold it in place.
2. Nexxus Racing has stick on weight that is battery cut out size
3. PPD Billet and others have weight plates that can be bonded to the battery and have slots that drop into the cutout.
I assume you have a flat bottom battery, so in turn those will work. I did not need to add a lot of weight with a 5000c IP pack and it had the bumps on the bottom so I just taped it in. So be careful with a full weight plate on a larger battery because balance will be off. I know people who have ran them but with the bigger mah batteries the additional weight is minimal to achieve balance.
-j
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 09-17-2009, 01:53 PM   #27519
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
On my Mi4 I have some lead weight on the inside of the chassis so my lipo cant move into my spur gear, and needed weight. But the tape holds the batt in just fine! As long as you have good tape you should be fine
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-17-2009, 04:51 PM   #27520
Thanks for the help guys. I'm going to use a combination of your ideas
Old 09-17-2009, 06:33 PM   #27521
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by koval View Post
Attachment 500257
Attachment 500258
Attachment 500259
How come you need a receiver pack? The make brushless speed controls without BEC circuits??
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-17-2009, 07:30 PM   #27522
skypilot's Avatar
cheap and easy, if your using a lipo with a flat bottom, double sided scotch tape will hold it in place just fine.
Old 09-17-2009, 07:50 PM   #27523
Suspended
Default re
march- racing will be in turbo mode. Look forward to racing with you. Hopefully it won't be too dry out here for you.(lol)
I went to jacksonville last year for the on-road nats. I was miserable. Sweating just sitting doing nothing.
begintravel55 is offline   Reply With Quote
Old 09-24-2009, 05:14 AM   #27524
Conrad's Avatar
For those that run the Sorex 28R with the JB insert (carpet tyre), how many runs are you getting before you see a noticeable drop off in performance?
Also does anyone have any problem with the outside edge of the tyre (not sidewall) blistering? Obviously the tyre is overheating or trying to roll over on itself. I've increased the front camber to reduce the contact when cornering and it hasn't helped much, still got roll center adjustments and anti roll bars to try, anyone got any thoughts?
Conrad is offline   Reply With Quote
Old 09-25-2009, 06:12 PM   #27525
Hey guys, I want to add some ackerman to my mi3.5.I notice there are different lenght track rods. I understand what changing the distance between the pivot balls does, but what about the different lenghts?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
