Old 08-20-2009, 07:39 AM   #27496
mjc168's Avatar
Trader Rating: 25 (100%+)
just got my U2999 Race Shock Seal Rebuild Pack today....i notice that there are extra 4 blue o-ring. does any one know where should i install the 4 blue o-ring? thanks.
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 08-20-2009, 10:08 AM   #27497
Send a message via ICQ to MattW
They are actually for the Off Road Car. All other parts are the same, so i guess it's easier for them to have just one pt number and send out both types of seal. In theory there is no reason why you can't use that seal in touring car, i'm not sure how it would be - as i haven't ever tried it!
MattW is offline   Reply With Quote
Old 08-20-2009, 11:09 AM   #27498
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
they work well if you add some soft shims under the cap (i use the teflon motor shims) to get the correct compression. something like 3 or 4 of them. when this is done, the resultant seal has lower friction than the standard clear orings. it's a bit of a pain and probably only useful in a pinch.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-29-2009, 08:20 PM   #27499
chicagokenji's Avatar
We're in Chicago and we recently bought an area racer's Mi3. The front belt needs to be replaced. We tried using a Corally 171t belt but it seems to be too snug.
Where's the most efficient place for us here in Chicago to get Schumacher parts quickly? it seems most of the shops around town here aren't stocking common parts.
chicagokenji is offline   Reply With Quote
Old 08-29-2009, 11:31 PM   #27500
Mopar's Avatar
As long as the belt fits the pullies (pitch) just rotate the eccentrics for the diff. Rotate forward if the diff is in the low position, or back if it's in the high position.
Mopar is offline   Reply With Quote
Old 08-31-2009, 06:50 AM   #27501
Shawn Palmer's Avatar
chicagokenji:
Al's Hobby is probably your best bet.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 09-02-2009, 07:30 AM   #27502
Default hex
I finally got my Mi3.5 running and it looks promising. I was trying to remove the wheel hexs to do some maintenance and those suckers are on the axels very tight. Any hints on removing them?
outlandr91 is offline   Reply With Quote
Old 09-02-2009, 07:33 AM   #27503
abailey21's Avatar
Trader Rating: 36 (100%+)
If mine are on there real tight I just gently pry them off with a small flat tip, or xacto blade
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-02-2009, 08:32 AM   #27504
Low_E's Avatar
Send a message via MSN to Low_E
a torch?
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 09-02-2009, 03:38 PM   #27505
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Well it's a step up from using your teeth like you used to
Old 09-02-2009, 06:27 PM   #27506
abailey21's Avatar
quit telling people I use my teeth i dont want them to find out!
effin gross FTW
K.C.C.O.
Old 09-02-2009, 06:28 PM   #27507
I tried to pry them off but they are really tight. I took the steering knuckle off the car and tried to use a larger flat blade screwdriver but didn't have any sucess.
[6291026]If mine are on there real tight I just gently pry them off with a small flat tip, or xacto blade[/QUOTE]
Old 09-02-2009, 09:37 PM   #27508
If you have an old pair of curved body scizzors that you don't mind risking the blades on, those make a great hex removal tool
Old 09-03-2009, 07:25 AM   #27509
Sounds like a good idea, Thanks.
Old 09-03-2009, 09:50 AM   #27510
Solara's Avatar
Trader Rating: 16 (100%+)
Stop asking, Al's and myself (Harold) just took good care of you...race your Schumacher and WIN something.
[/QUOTE]
Oh finally...you need to see me and I will show you some "speed secret".
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
