Old 08-12-2009, 08:36 AM   #27481
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by abailey21 View Post
Were back up and running today
Hi Adam, sent you a PM about an order placed
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 08-12-2009, 12:33 PM   #27482
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Hey Yohan give me a call!
Old 08-13-2009, 02:42 PM   #27483
Low_E's Avatar
Send a message via MSN to Low_E
I asembled my new Mi4 and did some first testing, using the stock-setup.
The car runs great but sufferes oversteer when comming out of a corner and going on throttle again.
1. Could someone tell in what direction as for stup-changes I have to look.
WHat should I do to get rid of this oversteering?
Please, help me by explaining what happens when going on throttle out of the corner. I thought that the car has too much grip on the front, so that I should look to harden the front suspension (harder spring, thicker oil, harder rollbar, ...) ... but when I think about it: when going on throttle, I should think that the weight is transfered to the back of the car again, and thus grip is reduced on the front ... but that doesn't make sence.
Please explain me in what direction I should think. THX
2. Also this:
when assembling the servo, linking it to the steering-parts, i noticed that the ball-end which is mounted on the CF Steering Arm & Mount, touches the servo ... and I use a very normal Ko propo-servo. Is this normal?
I sanded the nut and ball-end-thread down to make it shorter.
again, thx for all help.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 08-13-2009, 03:47 PM   #27484
jdm19turn's Avatar
2. Also this:
What are your droop settings,camber ,brand tires, ect track grip levels ,ride height p.s did you ever try the setup I sent to you lmk?
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 08-13-2009, 04:38 PM   #27485
Danny-b23's Avatar
How much toe in are you running in the rear?
Sounds like what you're saying is that the rear of the car starts to break loose when throttle is applied out of a corner. About .5 degree more inboard toe in the rear should fix the problem.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 08-13-2009, 04:45 PM   #27486
Low_E's Avatar
running kit-setup
with front: height: 6, droop: 5
rear: height: 6,5, droop 4
camber all around 1,5
tyres: don't know but they are rubber and shore 27 or 28
track: dusty concrete (but experienced the same problems on a tarmac track.)
Old 08-14-2009, 08:51 AM   #27487
jdm19turn's Avatar
running kit-setup
Try run 50wt front oil 40wt rear oil blues in front whites in the rear everything else the same as above except neg 2 camber front and rear lmk if it works thanxs joey
mi4 ,mi5
Old 08-14-2009, 09:41 AM   #27488
Low_E's Avatar
thx
are talking about 50wt and 40wt Schum oil? Because I do not have those (Only 30 and 35; ordered 30 in stead of 40 by mistake).
But I do have Losi Oil. Are those similar, are the viscosity-numers alike?
Old 08-14-2009, 11:22 AM   #27489
jdm19turn's Avatar
thx
Yes sir all schuie oil and springs not sure bout the difference in brands iam sure all don't use the same rateing system.
mi4 ,mi5
Old 08-14-2009, 09:16 PM   #27490
Mopar's Avatar
JDM is right, there could be variations from one manufacture to another. Stay with one brand and don't mix and match ever!
Mopar is offline   Reply With Quote
Old 08-16-2009, 05:13 AM   #27491
Drifting101's Avatar
On the Mi4 will the diff pulleys, spur or center pulley warp if I dye them? Because of the heat of boiling it?
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 08-17-2009, 12:41 PM   #27492
Grease's Avatar
No they won't, I boiled mine. They don't need to be in there very long. Once the dye starts boiling, I turn off the heat and throw the parts in.
Serpent S811e 2.0
Serpent S411 ERYX 3.0
www.norcarracing.com - www.franchiseracingproducts.com
Grease is offline   Reply With Quote
Old 08-17-2009, 09:08 PM   #27493
How long should I leave it in?
Schumacher
Old 08-17-2009, 10:28 PM   #27494
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
What I do is take a big azz pot and use a pie pan on top. So kinda like a buffet where they have the boiling water under the pans to keep the food hot. Same deal but I put water and the dye in the top of the pie crust pan. So you can leave the plastic in there and make sure it gets really soaked in with out worrying about having the plastic parts sitting right above a fire. It works really well with little parts because yo cant loose them LOL.
Hope that makes sense. That how I did my CAT SX pulleys and all that and it worked great!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-18-2009, 12:56 AM   #27495
I couldn't wait for your reply so I just experimented, it turned out fairly well
Schumacher
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
