Old 07-28-2009, 05:37 AM   #27466
koval's Avatar
Originally Posted by vazzo View Post
Mr 2 posts!
no mr 1515 posts your behavior is rude!
koval is offline   Reply With Quote
Old 07-28-2009, 05:52 AM   #27467
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by koval View Post
i took the cvd's out .they works free without binding any way!but i noticed that without wheels no vibration at all .when i put back wheels starts again !
Well then, without trying to sound to sarcastic it seems that it is a wheel balance issue.
Try a different set of tires and see if that helps
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-28-2009, 06:04 AM   #27468
Stusdal's Avatar
Originally Posted by SRW141 View Post
Did you build the car from a new kit? In the instructions it tellsyou to glue a 2mm plastic shim to the inside of the steering knuckle arm. This hits against the caster block. Which stops the steering from going 100%. Which helps with this chatter. You still get some of this chatter whe you free spin it, but when on the track it takes it away.
Hope this helps.
Also experienced this problem last time the car was on the track (Not so often any more, cause I got the phi09).
Did not build from a new kit, but cant find this anywhere in the manual I downloaded from racing-cars. Do you have any pictures showing this?
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-28-2009, 11:40 PM   #27469
Drifting101's Avatar
90% of the time spool chatter (vibration in the front when running a spool) is caused when the CVD blades are both vertical at the same time, but if one is vertical and one horizontal chatter is gone. So simply unscrew one outdrive and rotate it 90 degrees.
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 07-30-2009, 03:45 AM   #27470
LOSI123's Avatar
Trader Rating: 63 (100%+)
whats the best fitting li-pos for mi3?
LOSI123 is offline   Reply With Quote
Old 07-30-2009, 04:50 AM   #27471
Dad uses IP5000 40c, they seems to fit well, Feral batteries carry them
Schumacher
Old 07-31-2009, 11:40 AM   #27472
koval's Avatar
i purchased foam tires and the vibration still exist but less than with rubber cause the rims was wrong,the good is that the car now have more grip and i need less steering so the problem now dont buther at all in driving!i try to turn one blade vertical and other horizontical as a friend wrote but i cant see any difference at all!i believe that spool make that vibration so i will try to change with the back diff.i m curious only my mi3.5 have that problem?in my country (greece) schumacher are completely unknown so i cant get any opinion...
Old 08-02-2009, 06:29 PM   #27473
Trader Rating: 20 (100%+)
What do you guys think about this chassis upgrade ?.
http://www.exotekracing.com/EXOTEK_N...7/24_MI3X.html
hippie is offline   Reply With Quote
Old 08-02-2009, 07:51 PM   #27474
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Getting one asap for sure
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 08-08-2009, 08:25 AM   #27475
mr fit's Avatar
I have a mi-4 it came with a 85 tooth spur gear 48 pitch. What pinion can I use for a 13.5 speed passion motor on a fairly big track. Also a 10.5 motor.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 08-08-2009, 06:42 PM   #27476
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
What speedo are you using?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-09-2009, 06:08 AM   #27477
mr fit's Avatar
speed passion gt v1.1
Old 08-09-2009, 08:27 PM   #27478
mr fit's Avatar
Here's my MI-4 ready to roll. Speed Passion GT v1.1 esc, Speed Passion 13.5 motor, Airtronics 94758 digital servo,smc lipo & 2.4g spectum receiver. Now i need some track time (test & tune)
Schumacher Corner-cyclone-001.jpg   Schumacher Corner-cyclone-009.jpg   Schumacher Corner-cyclone-055.jpg   Schumacher Corner-cyclone-039.jpg
Old 08-10-2009, 09:00 AM   #27479
abailey21's Avatar
Just a little update for you guys trying to contact us via email and phone today;
A semi truck backed into a transformer behind our building and will not have power at the office today (08-10-09). Were hoping to have the power restored by tomorrow morning but I will keep all the threads updated as we get more info. Were closed today and working from home and i'm going to check the office tomorrow morning.
K.C.C.O.
Old 08-11-2009, 06:47 AM   #27480
abailey21's Avatar
Were back up and running today
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
