Old 07-08-2009, 12:54 PM   #27406
jdm19turn's Avatar
Originally Posted by hippie View Post
Yes that helps .
My shocks are built to 61.5mm . IS that the right size or should i extend them by turning the ball cup out ?.
That's the right length for the shocks
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 07-08-2009, 01:10 PM   #27407
Trader Rating: 20 (100%+)
Cool .
hippie is offline   Reply With Quote
Old 07-08-2009, 01:35 PM   #27408
Yes that helps .
I know that everyone has theirs that lenght. I like mine a 1mm longer. I also run my arm roll centers higher and longer shocks seem to work better to get the droop I like.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-08-2009, 02:59 PM   #27409
steve i lenghtend my shocks by 1 mm like you mentioned you do . It made it a lot eaiser to get the droop right. I have another ? . With the setup im trying ( mike haynes) 09 roar nats setup . It calls for 3mm shims for the FR screw block & 2mm shims for the RR screw block on the FR of the car. should i use this to adjust toeout or should i run them the same & use the tierods to adjust the toeout ?.
Old 07-08-2009, 03:20 PM   #27410
Use the tie rods to adjust your front toe out. He is making the arms sweep back for more steering.
Steve Walter
Old 07-08-2009, 03:39 PM   #27411
Would you recomend the swept back arms or run the shims the same on both FR & RR ?
Old 07-08-2009, 04:33 PM   #27412
Sweeping arms back is the last thing I do, when needing steering. 90% of the time run the same shims front and back.
Steve Walter
Old 07-17-2009, 03:39 AM   #27413
LOSI123's Avatar
Trader Rating: 63 (100%+)
Hi guys, I just got an Mi3 and ive got a few ?'s
1. If i put the M2.5 x 4 screws in the inner suspension hinge pins then the arm binds up.
2. when i tighten the hinge pin holders (the purple block things that hang of the bulkheads) , sometimes it also jams the free movemnt of the a-arm (with out shocks on) I assume that in a bit of a crash that these might move even if set correct and done up tight, and thus jam up the movement of the inner hinge pins after a crash, is there a fix to this or just have to check evry one after every crash if you want a perfect handling car every time i hit the track.
LOSI123 is offline   Reply With Quote
Old 07-17-2009, 04:24 AM   #27414
abailey21's Avatar
Trader Rating: 36 (100%+)
I don't run the screws on my hinge pins
And make sure the toe blocks are to tight together that will take care of the bind, but 99% of it is coming from those screws
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-17-2009, 05:31 AM   #27415
LOSI123's Avatar
Thanks Adam.
I have just also noticed what i think may be making mine so bad, Some one has put a 2.5mm spacer behind the arms and a 2mm in front & the manual ive got says both should be 2mm (i think as it doesnt actually tell you about the front one). i am talking about the clip on spacers.
Old 07-17-2009, 09:10 AM   #27416
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Marcos.J View Post
here it is
you need to go to autozone or advanced auto parts and buy this plastic vacumm fitting Part # 47341 its about $2.00. then you cut te end about 3 to 4mm thick, then slide in spur gear of choice, the mi3 bearing will fit inside the fitting, then you have to drill 2 wholes in the new spur gear to match the MI3 pulley and you are done. it took me less than 5 minutes to do it.
Will this work on the MI4 also?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 07-17-2009, 10:51 AM   #27417
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
I dont see why not they both use the same spurs. ( i dont have he mi4 yet)
Old 07-17-2009, 10:53 AM   #27418
abailey21's Avatar
they should
K.C.C.O.
Old 07-18-2009, 03:14 AM   #27419
LOSI123's Avatar
is there any wheel nuts that schumacher make that fit the mi3 that are alum and purple and serratted?
Old 07-18-2009, 06:14 AM   #27420
Drifting101's Avatar
http://www.racing-cars.com/products.asp?recnumber=26571
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
