Old 04-23-2009, 07:11 PM   #27376
Herc Driver's Avatar
Guys,
Do you have the Cat SX chassis in stock?
1. New Graphite w/batt slots and batt bar?
2. S1?
Jordan (My son) wants to know about the status of the E-Manic and if Schumacher is going to release a COOR (SC10, Slash) type truck?
Thanks as always...Props for the Iraq track!
Paul
Combat Search and Rescue Pilot
Schumacher Cat SX, Soon MI4
Herc Driver is offline   Reply With Quote
Old 04-27-2009, 10:57 AM   #27377
1shnot's Avatar
which online store do you guys recommend for schuy parts?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 04-30-2009, 06:13 AM   #27378
abailey21's Avatar
Trader Rating: 36 (100%+)
Yes for all the Cat questions...
As for the Manic that was only a prototype and the official decision has not been made for release yet
Originally Posted by Herc Driver View Post
Guys,
2. S1?
Paul
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-30-2009, 06:14 AM   #27379
abailey21's Avatar
Marcos could you be so kind as to post the mod you did for non schuie related spur gears, I have a couple guys asking me about it.
K.C.C.O.
Old 04-30-2009, 09:55 AM   #27380
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
sure let me find it
Old 04-30-2009, 10:07 AM   #27381
Super Moderator
Marcos.J's Avatar
here it is
you need to go to autozone or advanced auto parts and buy this plastic vacumm fitting Part # 47341 its about $2.00. then you cut te end about 3 to 4mm thick, then slide in spur gear of choice, the mi3 bearing will fit inside the fitting, then you have to drill 2 wholes in the new spur gear to match the MI3 pulley and you are done. it took me less than 5 minutes to do it.
Schumacher Corner-pulley-001.jpg   Schumacher Corner-pulley-002.jpg   Schumacher Corner-pulley-003.jpg   Schumacher Corner-pulley-004.jpg   Schumacher Corner-pulley-005.jpg
Old 05-01-2009, 02:08 PM   #27382
Hey guys,
I'm looking for a starting setup for foam and rubber at this small carpet track.
I have the Mi2, and here are some pics.
I'm really just gonna run here for some fun, and I have already re setup my car. I'm just curious how far off I am from others.
Josh
JoshM20 is offline   Reply With Quote
Old 05-07-2009, 08:14 AM   #27383
sagejyoung's Avatar
hey chaps were can i find some information on what other belts will work on my 3.5? i would like to know if i can source some cheaper belts...
sagejyoung is offline   Reply With Quote
Old 05-07-2009, 08:32 AM   #27384
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Belt Sizes from Various Cars
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-07-2009, 04:51 PM   #27385
1shnot's Avatar
Thanx for that awesome info....
looks like tc5 or 416 are the almost perfect match, or yokomo Bd's if you can get one
-Fast cats
-T.O.P
-Airtronics
Old 05-07-2009, 05:58 PM   #27386
Why would you bother...origional belts are great...if you are running 17.5 I would suggest the Shue grey belts...they are more plyable and have less friction...might strip in mod though
Barger is offline   Reply With Quote
Old 05-07-2009, 07:48 PM   #27387
1shnot's Avatar
its not questioning the quality of the belts for me... in toronto, as far as I know I'm the only one will drive schumacher, at my track its Xrays,tamiyas,and lately it's been associated, so its alot easier to run 416 or tc5's belt for me
I've been searching for "fix" the chattering with spools, I wonder if I use diff and converted to spool would that help a little? I will try spool with reducing exp on my radio and also try CA 2mm shim to my knucke as well, but just wondering if diff/spool would do the trick....
-Fast cats
-T.O.P
-Airtronics
Old 05-08-2009, 12:01 AM   #27388
sagejyoung's Avatar
Originally Posted by seaball View Post
thanks seeball! thats it
Old 05-08-2009, 12:05 AM   #27389
sagejyoung's Avatar
so from what i can read into the information there are no belts that will fit on my mi3 from other brands and no one else uses 3.6mm teeth? is that right? (ill answer that, its the width) sorry fellas
has anyone tried any other pulleys? im keen to try some stuff for development
Old 05-08-2009, 12:28 AM   #27390
Skitee's Avatar
Sage the belt tooth pitch on all the belts is 3mm, the schumacher belts are 3.6mm wide and no nobody else has the same width belt.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
