Old 02-24-2009, 08:25 PM   #27241
mini-dub's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mike Haynes View Post
Thanks for the warm welcome guys, i'm very excited about the new car...i have been running a losi for about 4 years and it has treated me real well, but time for something different. Glad i was of help Mark.
I have been getting a foam car setup over the past few weeks, i think it is pretty close to where it needs to be, after the grand slam race i'l post the setup i have on it. I havn't gotten my rubber car yet.
Well I guess that's good because I've yet to get you that rubber tire setup . I'll see if I can get that posted soon for you (and anyone else interested).
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 02-24-2009, 08:26 PM   #27242
mini-dub's Avatar
Shall we add the slacker who didn't race
HOT!
Old 02-24-2009, 08:41 PM   #27243
mini-dub's Avatar
Originally Posted by BagofSkill View Post
The car feels good to drive, a nice balance in high and low speed corners, not too edgey to drive so consistency isn't bad- generally no complaints, but I could use some help to find more corner speed. The setup I finished today with was:
13.5 brushless/Li-Po
Standard 3.5 2.0mm bottom deck
Standard 3.5 top deck
Sorex 28R premount on Revlite
HB Moorespeed 159 shell
Front
Spool
High Position
No servo Saver
0' toe
screw block spacers 1.5mm front and rear
quick klips 2mm both sides
link washers horizontal 2.5mm
ride height 5mm
droop 5mm
1.4mm anti roll bar
4' castor
1.5' camber
link washers vertical 2.5mm
inboard pin kick up
pivot block spacers 0mm front and 2mm rear
steering link on the middle hole on the hub
shock on 2nd hole wishbone
3rd hole in on tower
40wt oil
Schu blue springs
3 hole pistons
Std centre track rod on 2nd hole fronm front
Rear
high diff hight
screw block spacers 2.5mm front 1.5mm rear
wishbone quick klips 2mm both sides
ride height 5mm
droop 5mm
anti roll bar 1.4mm
2.0' camber
link washers vertical 3mm
inboard pin horizontal
pivot block spacers
2mm front and rear
shock 2nd outmost hole on wishbone
inner hole on hub, no spacers
35wt oil
white springs
3 hole
like I said, the car feels pretty good to drive but I need to go faster. My feeling is that I need more grip for the slower corners and I suppose a bit more cornerspeed would help. If I lower the roll centres (by 0.5mm shims on either Front or Rear Verticle Link Washers) I get grip rolling.
Can anyone give me some ideas or suggestions?
Cheers, Chris
Your car probably digs pretty hard from just looking at the setup. I think you want to try to soften the setup and get the roll down some so the car will hopefully carve better and get you the corner speed your looking for. Try going to white springs and 35wt up front, 3mm droop front, 3.5mm droop rear, -1.5 rear camber, and 1.5mm vertical link washers up front.
The softer front shock setup should keep the front suspension from digging as hard, though it may roll more which is why I think you should decrease the droop (that'll help with traction rolling, too). Also going to 1.5mm front vertical link spacers will keep the front end flatter through the corner, as well as decreasing camber gain, which will also help with traction rolling. Decreasing rear camber should prevent the rear end from biting so hard which I think will benefit you for both traction rolling and corner speed. If you want you may also go to 2.5mm rear vertical link washers to get rid of some camber gain on the rear end.
Give those changes a shot and let me know how it goes .
Old 02-24-2009, 10:55 PM   #27244
Rommel's Avatar
Now Available!
Interest/Questions PM or post on my thread.
Schumacher Mi3 Flex Chassis 2.0mm Chassis Protector Fits #U3145
Schumacher Mi3 Stiff Chassis 2.5mm Chassis Protector Fits #U3146
Rommel is offline   Reply With Quote
Old 03-01-2009, 06:07 PM   #27245
Default lipo batteries
I just picked up a 3.5 and wanted to now how everyone is attaching their lipos to the frame. Are you using the carbon fibre battery strap or battery tape? Thanks!
glider72 is offline   Reply With Quote
Old 03-01-2009, 07:10 PM   #27246
anotherrcguy's Avatar
Trader Rating: 84 (100%+)
I am running the Schumacher Mi3 and I have to car working good, I have good off power steering but I can't use the throttle thru corners at all or it pushes hard. I am only a few tenths slower than the fastest guys out there but I can't seem to push the car much harder anywhere but thru the corners and when I try it makes things worse.
Does anyone have any suggestions.
anotherrcguy is offline   Reply With Quote
Old 03-01-2009, 07:33 PM   #27247
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Battery tape. Just do it!
Old 03-01-2009, 07:51 PM   #27248
Mike Haynes's Avatar
I use a ppd weight plate with my battery double stuck to it, then i tape the hole assembly in with strapping tape, works very well.
Please post your setup and track conditions, we could be more helpful then.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-01-2009, 10:29 PM   #27249
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
come see me on sunday at the track I have a set up for you
Old 03-01-2009, 10:32 PM   #27250
Super Moderator
Marcos.J's Avatar
Hey Patrick here is my set up for Adrenaline
File Type: pdf MarcosJ MI3.5 Rubber Asphalt Setup.pdf (413.8 KB, 115 views)
Old 03-02-2009, 11:37 AM   #27251
Skiddins's Avatar
Copied from the main Schumacher forum.
Setup by UK national mod champion (3 years in a row) Chris Grainger for the 3.5 using rubber tyres on carpet.
Hi Everyone
Here is a carpet set up that me and Lee have worked our way towards, I would say it was a good starting point
Mi3.5 Carpet set-up
Front
Arm type Graphite
Caster block New medium type
Roll bar Gold
Upper shock position 3rd in
Lower shock position Outer
Piston Tamiya #3
Oil 40wt
Rebound 50%
Spring HPI Pink
Upper link width spacer 2.5mm
Upper link height spacer 2mm
Wishbone width spacer 2mm all round
Wishbone height spacer 2mm all round
Ackerman plate, short balls close together, base plate 3rd hole back
Droop 4.5mm at bottom of arm
No Hex spacer
Rear
Arm type Graphite
Roll bar Silver
Upper shock position 3rd hole in New wider tower
Lower shock position 3rd out
Piston Tamiya #3
Oil 40wt
Rebound 50%
Spring HPI Silver
Upper link height spacer 4mm
Upper link outer inner hole 0 spacer
Wishbone width spacer 1mm front 0.5mm rear
Wishbone height spacer 3mm all round
Droop 5.5mm at bottom of arm
1mm hex spacer
Chassis 2.5mm hard 6 cell
Top deck Std fitted backwards
Grey belts
Servo horn modified, ball mounted between upper and lower hole, High hole makes the steering to fast, lower to slow and restricts lock
Chris
Ride hight 5.5mm all round
Front camber 2 degree
rear camber 2 degree
Front toe + 1
I always prefer harder arms, they are more consistent, softer arms can flex to much as the grip comes up, But the softer caster block gives more steering
Yes Tamiya pistons are 1.1 x3
Sorry There is so much to remember on this car! Great you can adjust everything just hard to remember it all!!
Diff and spool set low, Rubber Modified and 10.5 racing the spool never comes out, indoor or outdoors. Wheelbase is 2-2 rear and 3-1 front 1 behind the arms 3 in front..
yes the 2.5 chassis is way better on carpet, I have not run the car outside yet so cant confirm its better there..
Chris
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Last edited by Skiddins; 03-03-2009 at 01:23 PM. Reason: More Info added by Chris in the UK
Skiddins is offline   Reply With Quote
Old 03-02-2009, 11:45 AM   #27252
this is a question for you guys that have tried the new wide rear shock tower.
is it worth it? what does it do?
i read the news letter, but have any racers that have used it have any reports?
thanks, the cop
gdcopbdcop is offline   Reply With Quote
Old 03-06-2009, 10:39 AM   #27253
jdm19turn's Avatar
if your still looking for a setup i'l post one shortly for you to try and who ever else that won'ts to try it also.
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 03-06-2009, 02:33 PM   #27254
mini-dub's Avatar
Here are some things to try:
standing up rear shocks - will cause more rear sidebite entering and mid corner, but give you more on throttle steering. If you can sacrifice a little rotation mid corner this may do the trick.
less front droop - will keep more weight on the front end when on throttle, this shouldn't change your off power steering much.
more caster - turn in wont be as aggressive, but the car will rotate harder, your high speed steering will improve, and your on throttle steering will improve. If you're not at risk of traction rolling, I'd try increasing caster first. Never forget, caster is faster!
add kick-up - this is similar to increasing caster, I can't notice much of a difference between adding kickup and adding caster. But with kickup you can do it in much smaller increments (on the Mi3.5 you can change it as little as 1/4mm).
Old 03-06-2009, 02:41 PM   #27255
Maybell's Avatar
Its MINI-DUB!!!!!!!!!!!!!
When you movn back home???
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
