Old 02-19-2009, 08:02 PM   #27226
markf3x's Avatar
Default Haynes
Hey, I just wanted to pop my head in on the Schuey thread and say we're going to miss Mike Haynes over on the Losi side. Congrats to Mike on finally getting a ride, you deserve it.. You all can't even believe how helpful this guy has been for all of us Losi drivers. I think you just gained a huge asset on this RCTech forum (ok, maybe in a few weeks after he's played with the car a bit).
Cograts again,
Mark Taylor
Losi type R
Dallas
markf3x is offline   Reply With Quote
Old 02-19-2009, 08:37 PM   #27227
Mike Haynes's Avatar
Thanks for the warm welcome guys, i'm very excited about the new car...i have been running a losi for about 4 years and it has treated me real well, but time for something different. Glad i was of help Mark.
I have been getting a foam car setup over the past few weeks, i think it is pretty close to where it needs to be, after the grand slam race i'l post the setup i have on it. I havn't gotten my rubber car yet.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-22-2009, 04:04 PM   #27228
BagofSkill's Avatar
Guys,
I've had my 3.5 for three weeks now and am getting close on setup, but I need more!
I race on a carpet track a little smaller than a tennis court, medium traction, tracks are a mix of slow and fast corners (for the size of the track. Rubber tyres.
The car feels good to drive, a nice balance in high and low speed corners, not too edgey to drive so consistency isn't bad- generally no complaints, but I could use some help to find more corner speed. The setup I finished today with was:
13.5 brushless/Li-Po
Standard 3.5 2.0mm bottom deck
Standard 3.5 top deck
Sorex 28R premount on Revlite
HB Moorespeed 159 shell
Front
Spool
High Position
No servo Saver
0' toe
screw block spacers 1.5mm front and rear
quick klips 2mm both sides
link washers horizontal 2.5mm
ride height 5mm
droop 5mm
1.4mm anti roll bar
4' castor
1.5' camber
link washers vertical 2.5mm
inboard pin kick up
pivot block spacers 0mm front and 2mm rear
steering link on the middle hole on the hub
shock on 2nd hole wishbone
3rd hole in on tower
40wt oil
Schu blue springs
3 hole pistons
Std centre track rod on 2nd hole fronm front
Rear
high diff hight
screw block spacers 2.5mm front 1.5mm rear
wishbone quick klips 2mm both sides
ride height 5mm
droop 5mm
anti roll bar 1.4mm
2.0' camber
link washers vertical 3mm
inboard pin horizontal
pivot block spacers
2mm front and rear
shock 2nd outmost hole on wishbone
inner hole on hub, no spacers
35wt oil
white springs
3 hole
like I said, the car feels pretty good to drive but I need to go faster. My feeling is that I need more grip for the slower corners and I suppose a bit more cornerspeed would help. If I lower the roll centres (by 0.5mm shims on either Front or Rear Verticle Link Washers) I get grip rolling.
Can anyone give me some ideas or suggestions?
Cheers, Chris
BagofSkill is offline   Reply With Quote
Old 02-22-2009, 06:59 PM   #27229
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'll be curious to see how close your foam set up is to McGoo/Goetz's vegas foam set up; I never found anything better than that!
What we need you to do is get to work on the VTA stuff!
J/K, were lucky t have you helping us all out.
Old 02-22-2009, 07:22 PM   #27230
MikeXray's Avatar
Trader Rating: 72 (100%+)
that won't be a problem his VTA car is faster than 50% of the 17.5 rubber cars locally
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-22-2009, 07:31 PM   #27231
Jerry P's Avatar
Trader Rating: 44 (100%+)
And it's only .1-.2 slower than the other 50%.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 02-23-2009, 12:53 PM   #27232
Stu
Stu's Avatar
Default MI2 vs MI2 EC
guys, just wondering what the key differences are between the mi2 and mi2 ec. ex, what parts cross over and such, any info would be a big help...
Stu is offline   Reply With Quote
Old 02-23-2009, 09:18 PM   #27233
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default schumacher at the northeast grand slam
super factory . .. ...
1. the new kid
2. the faithfuls
3. (???)
Schumacher Corner-p1010689-640-34.jpg   Schumacher Corner-p1010708-800.jpg   Schumacher Corner-p1010661-800.jpg
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-23-2009, 10:18 PM   #27234
1. the new kid
2. the faithfuls
3. (???)
Shall we add the slacker who didn't race
Old 02-24-2009, 10:35 AM   #27235
Skiddins's Avatar
I believe the main differences were the bulkheads and the chassis etc.
Someone asked a long time ago about converting from an Mi2 to the EC and it wasn't really worth it. Although I believe the corners are essentially the same.
Might be worth looking at the exploded diagrams for both and comparing what comes up.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-24-2009, 11:30 AM   #27236
seaball's Avatar
Shall we add the cracker who didn't race
wow, mike.
so, what's the role call looking like on the roar carpet nationals? we may have two drivers coming out after their respective hiatus.
mcgoo??
Old 02-24-2009, 01:38 PM   #27237
I heard the host location for the Gate has baby changing stations pitside; does taht help Marc? lol
The other baby daddy's at the grocery store know McGoo is a "wheel" by his hot lap with the stroller through the feminine needs section!
Old 02-24-2009, 05:12 PM   #27238
Stu
Stu's Avatar
thanks skiddins!
Old 02-24-2009, 08:25 PM   #27239
hpisims's Avatar
Congrats Mike
Mike is a great guy that is always willing to help someone out in the pits if they need it. I know I for one can't wait to see that foam setup
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 02-24-2009, 08:36 PM   #27240
Mr. McGoo's Avatar
That's how I roll - even with a wobbly wheel, I still can take those rookies!!!! LOL......
I wish I could make the Nats - maybe next year...
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
