Old 02-10-2009, 11:26 PM   #27196
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by Kevin K View Post
If you have Mi2EC front arms you can mount the stock Mi3 sway bar off the top of the front bumper brace where it screws to the bulkhead then run the links to the molded ball in the Mi2EC arms.....this setup actually works better because the pivot locations are further out on the arms then with the stock Mi3 arms.....with the stock mi3 arms the pivot location is too close the the center of car IMO to really have any effect unless you are using like a 3mm sway bar.
just like this one
Old 02-11-2009, 02:36 AM   #27197
Drifting101's Avatar
Originally Posted by Marcos.J View Post
just like this one
Nice re-anodizing Marcos
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-11-2009, 08:00 AM   #27198
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by seaball View Post
nope. you need to cut them to length (with a cutoff wheel). also, i would not recommend polishing them, as the mil finish they come with is extremely fine.
Super....that is not a problem, and can I order at that website?
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-11-2009, 01:40 PM   #27199
Super Moderator
Marcos.J's Avatar
is not reanodized it was the original prototype
Old 02-12-2009, 03:10 AM   #27200
I have never seen one like that
I have just gone over my car after the weekend and I noticed front left has 2 spacers and the right has one, I am talking about the spacers behind the front arm down wards. Now the question is what difference would it make handling wise? The car broke the club 17.5 record twice this weekend so it is fast, Should I change or leave it? If so what would be better for a large tight and open medium grip track
Schumacher
Old 02-12-2009, 08:24 AM   #27201
Solara's Avatar
I don't think anything are good if they are different between LEFT and RIGHT unless you are doing some OVAL racing...are you talking about the SHIMS underneath the upper aluminum blocks and will create Anti-Dive or Anti-Squat?
Old 02-12-2009, 10:54 AM   #27202
Grease's Avatar
Thanks. I have a ton of Mi2EC arms and tried it and it works better but I don't like the fact that the Mi2EC arms are weaker than pretzels. What do you guys do for the rear bar?
Grease is offline   Reply With Quote
Old 02-12-2009, 11:37 AM   #27203
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
The rear one acually works ok.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-13-2009, 04:09 AM   #27204
Yes
Schumacher
Old 02-16-2009, 02:20 PM   #27205
Super Moderator
Marcos.J's Avatar
I made a few changes to the set up that I posted for the MI3.5, my car was alot better this weekend. Its for outdoor asphalt.
Old 02-16-2009, 04:24 PM   #27206
mini-dub's Avatar
Yes
Try adding a shim to the right front, so both sides have antidive. Then try removing the shims, so both sides only have one spacer (which I assume will remove the anti-dive). Then compare the lap times and feel of the car from all 3 settings. Yeah most the time you always want everything equal L/R on your car, but if you like having antidive on only the left front, then just leave it. Whatever works the best is whats right.
I remember the Novak race a few years ago and I think it was Jared Scott who noticed his car had anti-dive on only the left front, but his car was dialed so he left it. If your car is good, make a note of the setup, make changes, and if you don't like them, go back to where it was the best.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 02-16-2009, 05:05 PM   #27207
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Do you still race these things?
Jon Kerr is offline   Reply With Quote
Old 02-16-2009, 05:16 PM   #27208
mini-dub's Avatar
Still? You must be getting me confused with someone else, I just started a couple weeks ago.
Old 02-16-2009, 06:51 PM   #27209
Jon Kerr's Avatar
I see. So you're a noob and these guys shouldn't listen to you.
Old 02-16-2009, 08:56 PM   #27210
mini-dub's Avatar
Now we're talkin
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
