Old 02-09-2009, 08:16 PM   #27181
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Marcos.J View Post
If you need spurs smaller than the schumacher go to your local auto parts store (autozone or pepboys) and get one of these vacumm fittings part# 47341, then cut the larger size about 3mm in size. Then fit that piece over the bearing.Then slide on to the spur gear of choice. You have to drill 2 new holes on the spur gear to mount it on the pulley. The vacumm fitting cost less than $3.00 and it took me all about 5 minutes to do. I keep it in my box when I need a certain gear ratio than I cant do with the Schumacher spur gears. I hope this helps.
with this easy spacer I can use almost every spur gear out there.
didn't HPI spurs come with a similar purple ring spacer?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 02-09-2009, 08:34 PM   #27182
Trader Rating: 15 (100%+)
Is anybody using anything different for hinge pins? I have been having them bend on the ends where thier hollow.
AARON YOUNG is offline   Reply With Quote
Old 02-09-2009, 08:48 PM   #27183
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Some guys tried the Losi JRXS-R pins. They were a bit shorter and they were using them without the small screws in the ends of the pivot block.I tried them and they bent just as easily as the standard ones IMHO. I personally am running the drill blanks that Goetz peeped us to. We had Larry Bradshaw (Team Tamale) machine some parts that worked around the blanks and they have been flawless for me. If you PM Seaball I bet he can point you in te right direction to get the blanks. In fact if you PM McGoo he might even have a few sets of the whole thing for you. It included lower pivot blocks, camber hangers, and drill blanks machined and cut for use with a setscrew.
The second best option I found was to use the standard hinge pins and be sure to use the screws tightened in the end. I felt the added meat in the hollow end added some rigidity. Be sure the arm is free however as they tended to bind when tightened down properly. A little work with some sand paper and the shims worked for me. They still bent though . . .
Old 02-10-2009, 05:13 AM   #27184
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
yes they did but noone had them in stock in my area
Old 02-10-2009, 06:22 AM   #27185
abailey21's Avatar
Trader Rating: 36 (100%+)
Hey, email me dude. Your emails have been getting kicked back lately
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-10-2009, 07:02 AM   #27186
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
www.mcmaster.com, part no. 3009A118
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-10-2009, 08:59 AM   #27187
Thanks!
Old 02-10-2009, 09:40 AM   #27188
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by eddie10 View Post
Never ran 17.5 before, but i am this weekend. carpet rubber 115ft straight. 106 and 50 is the biggest that will fit. thats FDR of 3.82. i dont think thats low enough. i heard people tell me more like a 3.2?
3.2 definitely TOO LOW...differnet motor can do different things, DUO 17.5 can even have mechanical timing adjustment...but my 17.5 key number is 4. Then up and down by 2-3 tooth of pinion should get you ball park. 3.2 final drive is WAY beyond that sweet spot unless there are something magic happened...
Again, I was referring to indoor carpet about 50 x 80 track...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Solara is online now   Reply With Quote
Old 02-10-2009, 09:44 AM   #27189
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Quick question guys: What gives more flex, the stiff top deck or the EU top deck?
Thanks!!
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 02-10-2009, 09:48 AM   #27190
Solara's Avatar
Is that direct drop in without cutting and sanding...? Thanks..
Old 02-10-2009, 10:31 AM   #27191
Super Moderator
Marcos.J's Avatar
Thanks!!
Hey Yohan on sunday I tried the EU top deck and the original top deck for the MI3 , my car felt alot better with the original top deck and was a little bit faster with it. But the EU top deck should give you more flex than the stiff top deck.
Old 02-10-2009, 10:40 AM   #27192
yyhayyim's Avatar
Thanks Marcos BTW, you got PM
Old 02-10-2009, 11:28 AM   #27193
seaball's Avatar
nope. you need to cut them to length (with a cutoff wheel). also, i would not recommend polishing them, as the mil finish they come with is extremely fine.
Old 02-10-2009, 02:02 PM   #27194
Grease's Avatar
Default Mi3 swaybars
Is there a better swaybar setup for the Mi3? I never seem to get the same amount of force left to right with the stock swaybar setup even when repositioning the swaybars. And the links never seem to be at the same angle from left to right.
Serpent S811e 2.0
Serpent S411 ERYX 3.0
www.norcarracing.com - www.franchiseracingproducts.com
Grease is offline   Reply With Quote
Old 02-10-2009, 05:25 PM   #27195
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
If you have Mi2EC front arms you can mount the stock Mi3 sway bar off the top of the front bumper brace where it screws to the bulkhead then run the links to the molded ball in the Mi2EC arms.....this setup actually works better because the pivot locations are further out on the arms then with the stock Mi3 arms.....with the stock mi3 arms the pivot location is too close the the center of car IMO to really have any effect unless you are using like a 3mm sway bar.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
