Old 02-09-2009, 01:16 PM   #27166
Banter's Avatar
Oh, and it looks like the Mi3 allows pretty much infinite adjustability on the tow in, so I'd start at 3 degrees.
Banter is offline   Reply With Quote
Old 02-09-2009, 01:22 PM   #27167
abailey21's Avatar
Trader Rating: 36 (100%+)
I would add some rear toe...that worked for me
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-09-2009, 01:23 PM   #27168
Thanks for that guys, i'd like to know what the factory kit setup should be if anyone knows?
Regards
Craig
BadgersOnAcid is offline   Reply With Quote
Old 02-09-2009, 02:09 PM   #27169
hpisims's Avatar
Craig what amount of droop are you running front and rear?
You can also go to www.racing-cars.com for setup sheets
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 02-09-2009, 04:58 PM   #27170
Trader Rating: 26 (100%+)
Im looking for some spur gears that will fit a 3.5 pro other than the schumacher ones?
eddie10 is offline   Reply With Quote
Old 02-09-2009, 05:06 PM   #27171
Solara's Avatar
Trader Rating: 16 (100%+)
I think PRS made some that work with Mi3 series, but I don't think they have that many choice (114 and 116 only from Nexus Racing)...beside them, I don't recall any brand made spur for Schumacher Mi3...
Btw, what is wrong with the Schumacher one...? The color or the choice of the teeth?
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-09-2009, 05:15 PM   #27172
Stock ones are great. My smallest is a 106 and i need alot smaller. I need by the weekend and i cant get it in time.
Old 02-09-2009, 05:20 PM   #27173
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
http://www.racing-cars.com/usa/produ...ecnumber=48583
http://www.racing-cars.com/usa/produ...ecnumber=47965
Schumacher USA looks to have 90 and 96t in stock.......call Adam in the AM and bug him for some.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-09-2009, 05:54 PM   #27174
skypilot's Avatar
Trader Rating: 14 (100%+)
i use a 106/42 for 13.5 don't recall exactly, but i believe thats around 4.25
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 02-09-2009, 05:59 PM   #27175
mini-dub's Avatar
106/42 will give you 4.543. I ran 13.5 yesterday with a 114/41 which gave me 5.005. I could have fit a 42t on, but that's as large as you could possibly go with a 114 spur.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 02-09-2009, 06:33 PM   #27176
Never ran 17.5 before, but i am this weekend. carpet rubber 115ft straight. 106 and 50 is the biggest that will fit. thats FDR of 3.82. i dont think thats low enough. i heard people tell me more like a 3.2?
Old 02-09-2009, 06:42 PM   #27177
mini-dub's Avatar
Wow that's a tiny ratio. What about potential 48p combinations that could get you in the proper range? Maybe you could get a small enough 48p spur in time.
Old 02-09-2009, 06:45 PM   #27178
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
If you need spurs smaller than the schumacher go to your local auto parts store (autozone or pepboys) and get one of these vacumm fittings part# 47341, then cut the larger size about 3mm in size. Then fit that piece over the bearing.Then slide on to the spur gear of choice. You have to drill 2 new holes on the spur gear to mount it on the pulley. The vacumm fitting cost less than $3.00 and it took me all about 5 minutes to do. I keep it in my box when I need a certain gear ratio than I cant do with the Schumacher spur gears. I hope this helps.
with this easy spacer I can use almost every spur gear out there.
RACE OPT USA
Bartolo Racing R/C
Old 02-09-2009, 07:36 PM   #27179
Super Moderator
Marcos.J's Avatar
Here is my set up form yesterday(outdoor asphalt), It was pretty good. Its based of Adrian's set up with a few changes.
RACE OPT USA
Bartolo Racing R/C
Old 02-09-2009, 08:08 PM   #27180
skypilot's Avatar
my memory is shot, somewhere i have a setup sheet for nationals and i can't find it, i know i had a 106 on the car, (its still there) but i thought it came out low 4. something range, used the same ratio at Fantasy world.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
