Old 02-08-2009, 04:05 PM   #27151
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Thanks Shawn for the loaner car i was able to reset TQ by 5 seconds on the 3rd round after finally getting all the clay out of the car I hope the shipment comes in tomorow
Old 02-08-2009, 06:45 PM   #27152
Mike Haynes's Avatar
Hmm, you never know I ran a borrowed shuie today in foam at 360, the car showed some potential There is a good chance Adam will never see it again
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-08-2009, 06:59 PM   #27153
Super Moderator
Marcos.J's Avatar
Old 02-08-2009, 07:14 PM   #27154
Jerry P's Avatar
Trader Rating: 44 (100%+)
Remind me to never lend you anything. Wait i already did and you still have it.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 02-08-2009, 07:16 PM   #27155
OHH YEA....um when do you want that back?
Old 02-08-2009, 07:21 PM   #27156
Jerry P's Avatar
No time soon. I rather it collect dust at your house. I heard the borrowed Shui was looking good today.
Jerry P
Old 02-08-2009, 08:11 PM   #27157
Super Moderator
Marcos.J's Avatar
Let me know when you find a good foam set up
Old 02-09-2009, 02:39 AM   #27158
Drifting101's Avatar
Originally Posted by eddie10 View Post
Can someone steer me in the rifgt direction. im looking for a FDR for 17.5 and 13.5, big track with 115ft straight
I run 35/70 you could gear it up a couple of teeth depending on track temp
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-09-2009, 06:15 AM   #27159
abailey21's Avatar
Trader Rating: 36 (100%+)
Speaking of that, the car is yours, but I do want my Tamale toe blocks back...eventually
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-09-2009, 06:16 AM   #27160
abailey21's Avatar
Rumor has it huh?
Originally Posted by seaball View Post
you're visiting our thread quite often, michael. is there something you'd like to tell us?
(rumor has it we need a foam guy).
K.C.C.O.
Old 02-09-2009, 10:30 AM   #27161
Solara's Avatar
Trader Rating: 16 (100%+)
Like I mentioned @ the SP thread...tell Adam it is the DRIVER, never the CAR...
P.S...your sig is missing a RC car brand...I am sure you know which one.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Solara is online now   Reply With Quote
Old 02-09-2009, 10:47 AM   #27162
Solara's Avatar
I can only tell you indoor carpet....used 17.5 on Mi3.5 with SP speedo (novak 17.5 and SP 17.5) FDR was 4.1-4.3 because it was a 80 footer x 50. Since your track and may be deeper...you can go as high as 3.9-4 range...check your motor temp for adjustment.
13.5 motor...4.5 to 4.7 range (my track is tighter, so I use 4.8-5 range)
Old 02-09-2009, 12:44 PM   #27163
Default mi3.5 race
Hi.
Recently purchased a mi3.5 race and having a couple of problems.
First let me point out im a novice to on road circuit racing but have lots of (20yrs+) of rc experience.
The track i race at is Don Valley indoor in the Uk its a cold hard rubber running track surface, bumpy with low grip.
Im running a SP 13.5T brushless stock motor with a LRP Sphere 2007 esc, Gearing is 89 spur 23 pinion.
I had to do some initial adjustments just to be able to get round the circuit without constantly spinning out under accelartion, I set the speedo power delivery to the lowest value, and the transmitter is set to 90% power and steering, and expodential is at +25% power and steering.
I then changed the front springs to blues, set the front upper shock mounts to the inside holes and the rears to the centre, and swapped out the front spool for a diff, (which had to be spun over so the belt was on the left of centre because it rubbed on the battery when fitted as per the picture in the manual) Everything else is as factory built.
Now its much better on the high speed turns either on or off power, but the back end still spins out on the low speed/tight turns when accelerating.
What do you reccomend i try next, higher weight shock oil in the rear or something else?
Also does anyone have the std kit built setup sheet because there is'nt one in the manual, just incase it was built wrong at the factory intially so i have a good base setting to go back to.
Regards
Craig
BadgersOnAcid is offline   Reply With Quote
Old 02-09-2009, 01:03 PM   #27164
Banter's Avatar
Originally Posted by BadgersOnAcid View Post
Hi.
Recently purchased a mi3.5 race and having a couple of problems...
Hi Craig,
What do you have for tires? Maybe a soft foam like Green would help. I always start with Jaco double pinks in the rear and double pink & orange in the front. Then you can go to a softer compound based on your run.
In my experience you'll want to soften the suspension, not firm it up if you're looking for more grip. Make sure your rear tow in is maximum.
Get your gears so you hit top speed on your longest straight, and then use your ESC or radio to help control spin outs on initial power. Many TXs allow you to set a curve on acceleration.
My 2 cents, but there's some experts out here that will have other ideas too.
Banter
Banter is offline   Reply With Quote
Old 02-09-2009, 01:16 PM   #27165
Thanks for the reply Banter.
Rubber tyres only and no addatives allowed at the circuit, the tyre of choice is the Nosram 27R so thats what im currently using.
Regards
Craig
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
