Old 01-30-2009, 11:06 AM   #27121
theisgroup's Avatar
the guy next to the banner is wes lion and the guy next to him is his dad. and the lady across the table is wes's mom
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-30-2009, 04:09 PM   #27122
Solara's Avatar
Trader Rating: 16 (100%+)
Awesome...thanks yang.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-31-2009, 04:52 PM   #27123
haywood's Avatar
Trader Rating: 48 (100%+)
Default LOOKING FOR USED MI3.5
Guys,just had a couple of questions about the two kits available,what are the major differances in the mi3.5 kits.I am looking to run on ozite with foams.Does anyone have a used kit for sale?Thanks for any help.
haywood is offline   Reply With Quote
Old 01-31-2009, 09:14 PM   #27124
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Jan Larsen View Post
Anyone heard from Marc M. (Mr. McGoo) recently? Cant get in contact with him. If you read this, read you PM's aswell bud, need to talk to you
go to www.mikeshobbyshop.com and clink on hobbytalk.
you can search under members for Mr McGoo. OR after selecting hobbytalk, go to team McGoo and send a pm for Mr Mcgoo there and he should respond.
He just had a baby girl,I believe the sex is correct, so he may be a little slow to respond but I send him a pm about you trying to contact him
idbdoug
idbdoug is offline   Reply With Quote
Old 01-31-2009, 09:23 PM   #27125
idbdoug's Avatar
MI2 setup for VTA class. Does anybody have a link or suggested setup for this car for rubber tires?
idbdoug
Old 02-01-2009, 01:04 AM   #27126
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
idbdoug
lol, Doug, that was from september!
Old 02-01-2009, 05:53 AM   #27127
idbdoug's Avatar
Jeez, your right. Anyways, hopefully I can figure out the basics of this on-road car stuff.
idbdoug
Old 02-01-2009, 10:05 PM   #27128
Solara's Avatar
If I understand you correctly, you are asking about the RACER version and the PRO version right..?
If you are running foam on carpet, I would skip the RACER version, racer version is the entry level. Go to the PRO version and upgrade the upper deck, foam towers and foam chassis...then you are ready to go.
Old 02-02-2009, 10:11 AM   #27129
Solara's Avatar
idbdoug
I really don't recall how much of a different between Mi2 and Mi2EC, but I was using the Mi2EC for like 2 years and was using the Mi2EC for some TRANS AM racing till I've got the Mi3.5. But I am using this setup by Adam Rogers with some minor changes to fit the 21.5 power plant...works great.
I added the front sway bar (thin one), used USA Carpet F/R shock towers, used Carpet upper deck but used the standard chassis. Rear toe set it as low as possible (-2 or less) for USVTA racing (don't need that much toe-in to increase speed). Ride height F 5mm R 5.5mm. Used front 1-way. The key is ROLL CENTER....T/A tend to be very touchy about rolling and you need to spend some time on this matter. Sometime I ended up CA the front edge of the TA tires just to take off some traction to avoid traction rolliing.
If you are using LIPO....balance the car is important, Mi2EC tend to ROLL alot due to the old design of the CG location. I added extra weight on the LIPO side and off set the lipo by 1/2".
http://www.racing-cars.com/usa/image...am_cw_2006.pdf
Old 02-04-2009, 10:32 PM   #27130
Mike Haynes's Avatar
Hey guys what is the internal on this car?
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-05-2009, 06:09 AM   #27131
1.8
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-05-2009, 06:00 PM   #27132
Trader Rating: 26 (100%+)
whats the internal on the 3.5
eddie10 is offline   Reply With Quote
Old 02-05-2009, 06:05 PM   #27133
Mr. McGoo's Avatar
Same. 1.8
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 02-05-2009, 08:50 PM   #27134
Banter's Avatar
Default Mi2
Ok, let's have some Mi2 nostalgia.
I have an Mi2 and I'm rebuilding the CVD shafts and fixing a broken one. I assume these are MIP shafts.
The grub screw is completely smooth where you would expect there to be angles for an allen wrench/key. Even the instructions to use an allen key, but it's smooth on the inside.
How in the world do I get the grub screw out? (and back in for that matter)
Thanks!
Banter is offline   Reply With Quote
Old 02-05-2009, 09:17 PM   #27135
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Thanks!
do you have the plastic dogbones?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
