Old 01-18-2009, 11:14 AM   #27106
Trader Rating: 15 (100%+)
Im wondering how moving the belt over and sliding the electronics in helps.After weighing every part of the electronics and dividing it in six quadrents the only heavy one on the left is the motor which is 185 grams. htey lipo split evenly is 90 grams per area for a smc 5000.the lightest is the servo with transponder at 56 grams .The speedo and reciever are pretty close to 90 grams which cancels out the lipo weight.I have 30 grams of tungsten under my servo that brings the front equal.I placed 60 grams of tungsten on the back outside of the lipo.whit is a little short of what it should be .But with evrything setup and all shock collars equal the tweak comes out within a quarter of a turn every time.fill me in if im missing something? And will the diff loosen if ran backwards even with the allen coming from the back to lock it?
AARON YOUNG is offline   Reply With Quote
Old 01-18-2009, 12:47 PM   #27107
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The diffs wont come undone if you have the set screw properly tightened. I believe the missing component of your system is the leverage each piece has relative to the center line. Moving the belts and sliding the electronics over reduced the leverage those pieces have. Something like a seesaw with a fat kid and a skinny kid. If the fat kid moves closer to the fulcrum/centerline his leverage is reduced and the seesaw will balance. Same thing if the skinny kid were able to move further out on the seesaw.
Old 01-18-2009, 11:11 PM   #27108
I understand the theory but the motor hangs out the furthest that is why i measured everything from the centerline plus ran the light motor mount with the rest the stock ones cause the light left side weighs the same as the heavy right side. What kind of wheel weights are you guys coming up with? my car came out with 48 % front and 52% rear weight.Also Has anyone done the geometry to figure out the roll centers ? I mapped out jimmy madisons setup for carpet rubber tires and the roll center is on the ground.I guess i have to much time on my hands, next is plotting all the akerman settings with the different bell cranks.
Old 01-24-2009, 03:27 PM   #27109
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
can some one give me the rear hing pin part #
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-24-2009, 05:32 PM   #27110
If your looking for the MI3 or the MI3.5 this is what you need.http://www.racing-cars.com/usa/produ...ecnumber=49709
Monte Hess is offline   Reply With Quote
Old 01-24-2009, 06:45 PM   #27111
skypilot's Avatar
Trader Rating: 14 (100%+)
thats way to much info for this old man to understand.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 01-24-2009, 09:17 PM   #27112
idbdoug's Avatar
Trader Rating: 33 (100%+)
I am considering a used Mi2 for VTA(Vintage Trans Am) racing. Who has a good selection of parts for this car in the USA? Are any of the parts the same as the newer cars?
Thanks for any further information
idbdoug
idbdoug is offline   Reply With Quote
Old 01-25-2009, 02:20 PM   #27113
Trader Rating: 26 (100%+)
will corraly springs fit the mi3.5
eddie10 is offline   Reply With Quote
Old 01-26-2009, 08:28 AM   #27114
Solara's Avatar
Trader Rating: 16 (100%+)
idbdoug
If your is Mi2, very limited...if your is Mi2EC, yes, arms (f/r), C-hub, rea hub, steering knuckles, hinge pins, CVDs, shocks...all the same as Mi3/Mi3.5.
Yes....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-26-2009, 01:04 PM   #27115
Well, everything you mentioned besides rear hub & steering knuckles actually fits the original Mi2 as well. Shocks are different (and the MI2 schocks are a major PITA). I can't remember what was different in the front & rear hubs, they probably fit, but something was different in their dimensions, was it offset?
olev is offline   Reply With Quote
Old 01-28-2009, 03:43 PM   #27116
rcshark's Avatar
Send a message via Yahoo to rcshark
how is the schumacher guys doing at the birds? Me and Tim Bone is going to be stopping buy to say hi to everyone on sat. and going to watch the mains?
Shark
rcshark is offline   Reply With Quote
Old 01-29-2009, 12:46 PM   #27117
im looking for a good rubber carpet setup. medium size track, medium traction.
Old 01-29-2009, 12:52 PM   #27118
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
http://www.racing-cars.com/usa/searc...e1=prodvalue14
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-29-2009, 08:40 PM   #27119
http://www.petitrc.com/reglages/schu...umacherMi3.htm
Arn0 is offline   Reply With Quote
Old 01-30-2009, 09:54 AM   #27120
Solara's Avatar
Can someone ID the entire Schumacher team @ Snowbird in that picture..? I do know the green car (closest pit) is Adam, then Jason and his female friend, what about the last 2..?
Anyhow, good luck @ the birds.......and Adam, you better step it up FAST or I will take over that GTV2 speedo...
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
