Old 12-23-2008, 02:45 AM   #27076
Drifting101's Avatar
I am looking for good set up preferably with a bit more steering than std; it's for a 17.5 on a track with a long straight maybe 40 metres long but with pretty technical parts and medium high traction (TFTR Melbourne, Australia)
Edit: My car will be 1425grams if that makes a diff
Also can i see some pics of mi3's with 3pk receivers and lrp tc for mounting ideals
thanks
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 12-23-2008, 05:54 AM   #27077
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i believe randy castor's setups have more steering than most people care to deal with.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-01-2009, 04:22 AM   #27078
Skiddins's Avatar
Just some interesting news regarding UK drivers at Schumacher.
Chris Grainger has now joined from Yokomo.
He's been the UK Mod champion 3 years running beating the likes of Andy Moore and Elliot Harper pretty regularly.
Perhaps now the Mi3 will get some much needed development to take it to the next level.
Yokomo might not release a new car until 2010 which will probably be focused on the worlds that year.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-01-2009, 06:24 AM   #27079
scoyle's Avatar
Skiddins, great news indeed. Can I ask were you heard it from - there is nothing on the Schumacher site and something as big as this I would have expected them to announce it.
scoyle is offline   Reply With Quote
Old 01-01-2009, 08:21 AM   #27080
Happy New Year to all my Team Mates. Hope everyone had good 2008 and now onward to 2009.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-01-2009, 08:57 AM   #27081
djlove85's Avatar
Default 3.5 setup
Hay adrian i just got an 3.5. is the kit setup good for running on carpet wit rubber tires? if not what should i changegeorge
djlove85 is offline   Reply With Quote
Old 01-01-2009, 09:06 AM   #27082
AdrianM's Avatar
Start out with the attached setup. It is for asphalt but it is a great start. If its open tires run Sorex 28R or Jaco Green tires all the way around. Put traction compound on the full rear and inside 1/3rd of the fronts to start and increase the width if you need more steering.
If you need more rear traction stand up the rear shock a hole and or move the rear lower arms back 2mm.
...and yes we are running spools on carpet with rubber tires.
Adrian Martinez
Old 01-01-2009, 10:53 AM   #27083
djlove85's Avatar
thank's george
Old 01-01-2009, 05:09 PM   #27084
Skiddins's Avatar
http://www.brca-tc.co.uk/
Under the '2009 Preview'
I was as shocked as everyone else
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-03-2009, 07:52 PM   #27085
jackhammer's Avatar
Default MI3 for vta
got it thank for the setup will test this week end
jackhammer is offline   Reply With Quote
Old 01-08-2009, 05:02 PM   #27086
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Rear Hing pins, can some one tell the thickness and length
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-08-2009, 07:57 PM   #27087
Cesar's Avatar
3.175mm thick (.125") 3mm work
55mm long (2.165")
While going fast is fun, racing is about just going faster than the other guy.
Don't let the lure of speed get you away from the close racing. -Mason
Cesar is offline   Reply With Quote
Old 01-09-2009, 12:19 AM   #27088
Bob-Stormer's Avatar
Need rough roll out idea.
I haven't run rubber tire touring in quite a few years. Building the car, just want to get a pinion and spur on it that are going to be close, so I can pimp the electrical install.
Mi3.5, rubber tire, 17.5, 7.4 volts, carpet track 40x80
Thanks,
-Bob
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 01-09-2009, 05:46 AM   #27089
abailey21's Avatar
Trader Rating: 36 (100%+)
Capitan Bob, I run the 90t spur with a 44 Pin on rubber 17.5
Thanks,
-Bob
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-09-2009, 01:35 PM   #27090
20 SMOKE's Avatar
55mm long (2.165")
thanks cesar, exactly what i was looking for
Jamie W
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
