Old 12-12-2008, 10:47 AM   #27046
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by ADDiSON View Post
thats jus sad!!!!! i think i need to teach u how to drive!
rotflmao
Old 12-12-2008, 12:36 PM   #27047
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by reenmachine View Post
Is the same true of the Mi2EC?
But be carefull about doing it on EC...you have to use the EC raiser plates and place them under the bulkhead, but that will also raise the entire bulkhead up (or down) along with the shock tower, shock upper position, the roll center inner mount...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-14-2008, 12:30 AM   #27048
CMB21's Avatar
Looking for a little gearing help for an Mi3 i just picked up.
Car will be running 540 Pro class, and lipo packs if that makes any difference.
It has an 89 Spur (which was already on the car) and i dont have any other spurs for it. What pinion should i go for with the 540-J motor? Track is asphalt, generally high speed track with a few technical sections.
I would prefer to keep it with the 89 spur for now, but if that wont work in 540 Pro let me know Im pretty sure its 48 pitch aswell.
Thanks in advance.
P.S Please dont say move to mod class, as our club is small so there is no mod class but instead most run 540 pro.
~Team Terribles~
Kyosho RB5 SP (Venom esc, Fantom Ion 2)
Team Associated RC8B (GO Engines, AMain C2 Fuel)
CMB21 is offline   Reply With Quote
Old 12-14-2008, 02:16 AM   #27049
Drifting101's Avatar
Thanks in advance.
I run 70, 31 =4.05....Not sure what pinion if you want to use a 89
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 12-14-2008, 09:10 AM   #27050
Solara's Avatar
Thanks in advance.
I have not run silver can outdoor for awhile. But general rule about silver can for outdoor, final drive is around 4.00 and keep checking your motor temp (160 or less)...may be add extra FANS blowing toward the motor will work.
Go to here...
www.gearchart.com
There you will find the gearchart creator, click on there, and choose Schumacher Mi2 with 20T pulleys (same as Mi3)...once you are in there, punch in the 89 spur, and 40 pinion...then a table will list using a 40 pinion with 89 spur you will get a 4.01 final drive. So you should stock a 39, 40 and 41 pinion so you can move around the FDR. I would definitely try the 39 first and check the speed of the car and temp of the motor before heading to the 40 and 41 pinion.
Old 12-14-2008, 03:45 PM   #27051
CMB21's Avatar
Thankyou both for the help.
I will have a look through that now, Cant wait to get the car on the track.
~Team Terribles~
Old 12-15-2008, 07:08 AM   #27052
abailey21's Avatar
Trader Rating: 35 (100%+)
On gearchart you can also use the Schumacher 1.8:1 option, its the same thing
Go to here...
www.gearchart.com
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-16-2008, 06:26 AM   #27053
jackhammer's Avatar
Default MI3 vta setups carpet anyone ?
new to MI3 hoping to have some fun in VTA class this winter need some setup ideas for VTA thanks for the help
jackhammer is offline   Reply With Quote
Old 12-16-2008, 06:58 AM   #27054
abailey21's Avatar
I think Solara may have a pretty dialed setup???
K.C.C.O.
Old 12-16-2008, 07:05 AM   #27055
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Let me scan my setup sheet in then I can post it.....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 12-16-2008, 08:20 AM   #27056
Kevin K's Avatar
Here it is....I couldnt get it to upload as a PDF....but here it is.
Old 12-16-2008, 10:35 AM   #27057
Jamesalex's Avatar
How do you guys go about setting / resetting the Mi3.5 diffs when you rebuild them make them run smooth not to tight or loose, about to rebuild for the first time so was wondering if there is any tips
Cheers in advanced
Jamesalex is offline   Reply With Quote
Old 12-16-2008, 12:48 PM   #27058
Hiya.
Newbie here - so a pretty basic question - but what wheels and tyres can I go for?
I have a schumacher mi3.5 and me and some mates are gonna be doing some drag racing between us for a laugh, so emphasis is on style and speed - hence want something more interesting that plain revlites.
Problem is I got some Ansmann Fuse's and they run on the rear wishbone. What type of wheels can I use and what should I look out for?
R
gingerbob is offline   Reply With Quote
Old 12-16-2008, 01:06 PM   #27059
AdrianM's Avatar
Cheers in advanced
Here you go. The instructions for how the team builds diffs start post #4.
Let's Build a Schumacher Mi3!
Note that everything in the Mi3 build thread also applies to the Mi3.5
Adrian Martinez
Old 12-16-2008, 01:10 PM   #27060
Kevin K's Avatar
Originally Posted by gingerbob View Post
Hiya.
R
Add a wheel spacer or you can get Wider rear Hexes....I think the ones from the MI2(not EC) or Fusion will work....or you can go with any of the other wider hexes on the market just make sure that you space them properly.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
