Old 11-14-2008, 03:14 PM   #27001
mini-dub's Avatar
Trader Rating: 16 (100%+)
Cool, thanks for that info. I like lots of steering so I think I'll stick with my old setup and then make changes and see what I think of them (what an idea!! ).
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-14-2008, 06:09 PM   #27002
Lost Aggresiva's Avatar
I was wondering if anyone could point me to a good starting setup for the Mi3 for foam/carpet. Haven't raced in a while and am starting to feel the itch again.
Lost Aggresiva is offline   Reply With Quote
Old 11-14-2008, 08:58 PM   #27003
Drifting101's Avatar
http://www.petitrc.com/reglages/schu...umacherMi3.htm
Try here
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-15-2008, 04:03 AM   #27004
Well the nice thing about the short bellcrank is that it actually doesn't seem to take away steering, it just makes it more controllable. But trying them back-to back yourself is a brilliant idea, I don't know why anyone hasn't thought about that before
olev is offline   Reply With Quote
Old 11-15-2008, 11:27 AM   #27005
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
just make sure to reset your radio epa's as the shorter rod will most certainly yield a larger turning radius. and double check your toe if keeping the same pivot hole (in the support plate). when the tie rods go from angled back at the hubs to straight (parallel with the dogbones), the car gets toed in a bit.
lost - i still favor marc mcgoo's carpet nats setup the best. (3/13/2008 from that link)
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-15-2008, 11:57 PM   #27006
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I second this. We just finished a local race running the exact same thing on Medium bite carpet. Even on lower bite carpet it works well with a small spring change. Easy to drive with plenty of steering.
Old 11-17-2008, 04:58 AM   #27007
I am trying to get my head around shock rebound - some setups call for 50%, 70%, 100% rebound.
Can someone tell me what rebound I get if I build a shock 'normally' i.e. put in 30wt oil up to the top, put the rubber seal on and screw the top on with the shock at the fully extended position.
And also how I build a shock to get different levels of rebound?
scoyle is offline   Reply With Quote
Old 11-17-2008, 06:21 AM   #27008
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Take the shock and extend the shock shaft all the way out. Measure how far it extends from the top of the ball cup, to the bottom of the lower shock cap on the shock body. Say its 10mm.
Now rebuild the shock with 30WT oil and put the bladder and close. Push the shock shaft in and then let it go...it should only "rebound" back about 1-2mm...which is like 10-20% of the 10mm max shaft extension.
When you build the shock "normally", all you get is about 10% rebound at best. To get more, use rebound foam, or o-rings which you can place on top of the shock bladder.
Xray shocks use rebound foams, HB Cyclones, AE TC5, etc...most come with small cyclindrical foams which you put insise the shock's bladder to get more rebound out of the shock.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-17-2008, 06:27 AM   #27009
What you say makes sense - I will check my shocks tonight when I get home but I thought that mine, built as normal, were pretty much rebounding out the whole way with no foams on o-rings in place?
Are there any recomendations on foams on o-rings that give the different levels of rebound?
Old 11-17-2008, 06:43 AM   #27010
yyhayyim's Avatar
Really? If you're getting full rebound when u build them "normal", then you just gotta bleed some of the oil out. Open the top cap just a bit, and then push the shock shaft up about 2-3mm, and some oil should bleed out from the top...close the top cap and re-check your rebound. It should be around 50% after this...keep adjusting as needed.
For rebound foams...some use Tamiya or MMR rebound foams, or Xray. I'm sure someone here can post where they can get them from.
Dont forget to go thru Adrian's posts on how to build an MI3...especially the shocks section...here's a link:
Let's Build a Schumacher Mi3!
Really good info, and he covers how to build the shocks, rebound, etc.
Old 11-17-2008, 06:48 AM   #27011
yyhayyim's Avatar
Anyone using MMR or other kind of rebound foam?
Old 11-17-2008, 11:13 AM   #27012
Send a message via ICQ to MattW
It depends on the shock caps. With 3.5 caps (or older EC ones) building "normally" will give full rebound. For less rebound, you push the piston up toward the top of the shock before putting the diaphragm on.
MattW is offline   Reply With Quote
Old 11-17-2008, 01:57 PM   #27013
Yep, just checked mine (Mi3.5) and I am getting pretty close to 100% rebound.
MattW - does it follow that if I push the piston up 50% of the way then I get 50% rebound? Chris Ashton's carpet setup talks about 50% rebound.
Old 11-17-2008, 02:03 PM   #27014
Yeah it's not far off that - it's not an exacting science, but it's not a million miles off.
Old 11-17-2008, 03:51 PM   #27015
And taking it a stage further does putting the foam pieces or o-rings on top of the rubber diaphragm make for faster rebound?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jaw8850
SEO by vBSEO 3.5.0
