Old 11-09-2008, 03:51 PM   #26986
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
Originally Posted by Marcos.J View Post
congrats on Adam on your win in sportsman 13.5!! (time to move up)
Agreed, he is getting too good.
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 11-10-2008, 06:22 AM   #26987
abailey21's Avatar
Trader Rating: 36 (100%+)
Did you guys look at the laps? Cause I still think I'm of off the pace on pro by 3-4 laps?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-10-2008, 11:45 AM   #26988
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
not by 3 laps ( maybe 8?? j/k)
RACE OPT USA
Bartolo Racing R/C
Old 11-10-2008, 12:02 PM   #26989
yyhayyim's Avatar
Trader Rating: 26 (100%+)
told u not to let him use your prototype Tequilla TQ tire sauce You've created a monster now
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-12-2008, 05:25 AM   #26990
steveonamission's Avatar
Anyone representing schumacher at the worlds?
If not.......why not?
We need to sign a star already!
steveonamission is offline   Reply With Quote
Old 11-12-2008, 04:37 PM   #26991
can someone give me a measurement on the 3.5 from the bottom chassis to the upper deck. thanks
eddie10 is offline   Reply With Quote
Old 11-13-2008, 03:32 AM   #26992
I saw a Michael Somebody from South Afrika on the forms that is the only person out there driving a schumacher,
unlike Xray and Tamiya, Schumacher doesn't need to prove anything about being the best touring car.
2010 guys, its all ours
Kirby Masterman is offline   Reply With Quote
Old 11-13-2008, 05:22 AM   #26993
I think Ivan Laptev from Russia is running a Schumacher... at least he has done so for several years and was still running Mi3 at the Euros in August. But he's most likely not going to win the worlds
olev is offline   Reply With Quote
Old 11-13-2008, 05:56 AM   #26994
abailey21's Avatar
Olev, kirby and Adam in 2010...
I'm Adam Bailey and I approve this message!
K.C.C.O.
Old 11-13-2008, 06:48 AM   #26995
Adam: this finishing order would suit me just fine. I have won the worlds before... but then I have always waken up
Old 11-13-2008, 10:02 AM   #26996
Jamesalex's Avatar
I need some advice,
How have you been balancing the car side to side as there is no centre line holes is there an easy way?
Jamesalex is offline   Reply With Quote
Old 11-13-2008, 10:29 AM   #26997
abailey21's Avatar
I use a thick piece of solder (as a wire) and I notched my shock tower as close to center as I could get. It works but I know its surely not 100%
Originally Posted by Jamesalex View Post
I need some advice,
K.C.C.O.
Old 11-13-2008, 02:45 PM   #26998
Grease's Avatar
I use a tweak station and simply slide the car forward so that the back of the chassis is balancing on the center bar
Grease is offline   Reply With Quote
Old 11-13-2008, 06:53 PM   #26999
mini-dub's Avatar
Trader Rating: 16 (100%+)
That's a good idea Grease, never thought of that before.
I have a question regarding the standard steering linkage setup on the Mi3.5. In short, what handling differences will we get from going to the new setup? That is, going to a shorter center bellcrank and running the middle hole on the new steering hubs. My steering links were always swept back slightly before, which makes the steering a little smoother and less aggressive from my experience (due to a lower ackerman angle). I just put the new setup on my car and the links are now parallel to my dogbones, so I'm going to expect that to make the steering a little more aggressive. I just dont know what difference the shorter center bellcrank will make.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 11-14-2008, 01:21 AM   #27000
The shorter bellcrank causes 2 effects. First, it makes the steering a bit slower, which can be a good thing if you are running rubber tires, fast servo and fast steering hand. With too fast steering action the car breaks front traction too easily on rubbers. Second, for the same width of bellcrank, it causes a bit bigger ackermann angle, simply because it will turn more (in degrees) for the wheels to turn the same amount. But this also depends on the bellcrank location and position of the tie rods.
I like the shortest one, it calms the front end down a bit. Had to use the medium lately when the short one broke and I didn't have a replacement handy... car was less comfortable for me to drive. Then again, I'm not a world class racer as well, someone with a more precise steering hand might have a different opinion.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
