Old 10-02-2001, 08:02 PM   #256
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Im not sure, Schuamcher says that it will be adjustable we will have to wait and see.
Kevin K is online now   Reply With Quote
Old 10-02-2001, 08:49 PM   #257
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Do you have pictures of the inboard toein setup? Im not quite sure how it works but it sounds good.
Also regarding setup. i have been a fan of 1 hole pistons and realtively soft oil(30-50 front and 30 in rear.) I notice quite a few setups use 60wt and 2 hole pistons. What is the difference for you guys who have tried both? I race on medium-high grip fast asphalt circuits.
I tried going 2 hole piston and keeping the soft oil and the car definetly slouched more in corners and lost steering generally. The 1 hole piston setup is extremely fast but very aggresive and twitchy. it is also very susceptible to condition changes.
Thaks
PS All this talk about Putnam brushes cracks me up. My surname is Putnam and I keep seeing me name everywhere! LOL. racerX can you recommend a 12 turn motor with his brushes?
Oasis2001 is offline   Reply With Quote
Old 10-02-2001, 09:50 PM   #258
AdrianM's Avatar
Lets get away from the trem inboard toe in. We are really taking about "Arm Sweep" as in making the rear arms sweep forward. Arm sweep as no direct effect on rear toe in. Rear toe in is still set with turnbuckles. I just want to make sure people dont confuse the two adjustments.
The Mission will include the ability to have 2deg of forward sweep on the rear arms and 2deg of rearward sweep on the front arms in addition to the standard parrallel hinge pin position.
I want all of you to understand one thing. This will be the best car we have EVER made! I have talked with the drivers that have tested the Axis 2.5/Mission Prototype and they are going 3-4/10th's faster with the prototype than with their tricked out A2's. Keep in mind that the Mission will have a better drivetrain, layout, balance and more accurately made parts than the A2.5 Prototype. You guys have no idea how bad I want to get my hands on final version this car!
Adrian Martinez
Old 10-02-2001, 10:13 PM   #259
rc10gttothemaxx's Avatar
Send a message via AIM to rc10gttothemaxx
i'm lucky i got word of this car sooner i got my preordered i'm hoping i can wip some arse with this car up at trcr in tacoma in the stock class so thank you schumacher for making pimped out rides for us rich people
nothing like a schumacher
rc10gttothemaxx is offline   Reply With Quote
Old 10-03-2001, 09:09 AM   #260
Racer X's Avatar
Oasis: The reason you mostly see setups with the two hole pistons is that most everyone has decided to just use two holes as a starting point and adjust with shock oil from there.
I think that Putnam is now doing mods, email him @ PutnamPro@AOL.Com
Racer X is offline   Reply With Quote
Old 10-03-2001, 09:49 AM   #261
Trader Rating: 35 (100%+)
I just bought myself a Losi XXX-S for my Birthday (9/28). Looks like I'll be buying a Schumacher Mission, for Thanksgiving!
Geppetto is offline   Reply With Quote
Old 10-03-2001, 09:59 AM   #262
Regional Moderator
Darkseid's Avatar
Geppetto: now thats how to really enjoy Thanksgiving!
TLR 22...Tamiya F104...
Old 10-03-2001, 11:41 AM   #263
Default 1st real photo of the mission
Here is the first photo from the new schumacher mission he wins his first race.
rimaracing is offline   Reply With Quote
Old 10-03-2001, 12:12 PM   #264
AE_Racer's Avatar
Send a message via AIM to AE_Racer
that has already been posted
quote from Darksid's post
...Heres the pic from Schumaher's site.
Attachment: axis25.jpg
This has been downloaded 41 time(s).
AE_Racer is offline   Reply With Quote
Old 10-03-2001, 12:19 PM   #265
Racer X's Avatar
...and its not a Mission, it's a hybred (Axis2.5) car used for testing chassis layouts. But thanks for posting it again (for anyone who missed it)
Old 10-03-2001, 03:17 PM   #266
Send a message via ICQ to MattW
inboard toe/sweep will also shorten the wheelbase, which helps traction. On the proto car there is 2 sets of holes in the chassis, use the inner for "inboard" and the outer for current parallel set-up.
Using more pistion holes with thicker oil makes the car better on bumpy tracks. Is isn't all that un-usual for us to run 100wt 4 hole on a couple of bumpy tracks.
MattW is offline   Reply With Quote
Old 10-03-2001, 05:15 PM   #267
Kevin K's Avatar
Yes Matt it will also shorten the wheel base but its a little more then a shorten wheel base. You can use the front upper arms in the rear and that will shorten the wheel base but does not effect the "Arm sweep" which has a greater effect on traction and car performance. I have tried it both ways and the "arm sweep" is better then short wheel base.
Old 10-04-2001, 08:10 AM   #268
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Kevin,
I know you race on carpet so this question is for you (or anyone else who can help).
My friend has TC3. He is a Green Machine 3 with TRC plaids up front and purple in the rear. He is using a 76 tooth spur. What pinion size would you recommed for a tight track where the top gus turn 10 second laps?
Also, does anyone know a brush/spring combo for the GM3 that will give the most power. Thanks everyone.
Ty is offline   Reply With Quote
Old 10-04-2001, 08:21 AM   #269
Regional Moderator
Darkseid's Avatar
Who is Schumacher's main designer. I mean ever since the Yokomo MR4TC (with Masami doing most of the work there)came out, its pretty regular to see the magazines cover who was the main designer of the new cars. I doubt that Schumacher will get the same attention in the magazines, so figured I'd ask here.
Is it one main guy, or a team of people. How long do they usually spend designing a new car?
Old 10-04-2001, 10:40 AM   #270
Kevin K's Avatar
TY......one of the tracks that I race at they run about the same lap times and most of the TC3 guys run 64 pitch and they run 26 to 28pinion and 100 spur with rubber tires. Not too many run stock that I know but on my car I go up 2 to 3 teeth when running foamies b/c the smaller size tire. I would say start with a 29 or 30 with the 64 pitch but not sure on 48 pitch, you can convert it and get the drive ratio and just figure out what size 48 pitch pinion you need.
For the Greenie 3 I like the trinity black(on the neg side) and trinity red springs. I also make a small hole in the face of the brush on the neg side, I do this with an exacto. I have tried many things and this seems to run the best run to run.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
