Old 10-30-2008, 02:29 PM   #26956
mini-dub's Avatar
Trader Rating: 16 (100%+)
Yo, you ever going to reply to that email I sent you!?
Also, I need lipo mounting information; I read what you guys were talking about a couple pages ago regarding flipping the belts and such. So I did that last night (along with installing a new, non-broken esc ), however I'm still not really sure what needs to be done in terms of mounting the lipo and how much/where should I put lead.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-30-2008, 02:44 PM   #26957
Cesar's Avatar
I went to the auto parts store got some lead and shoegoo'd it to the bottom of the batt's so they line up in the grove of where the slot is..... I now race a series that allows the weight down to 51oz. so I have no lead on my car....but the batt. is hanging over the side to get the balance just about right.
While going fast is fun, racing is about just going faster than the other guy.
Don't let the lure of speed get you away from the close racing. -Mason
Cesar is offline   Reply With Quote
Old 10-30-2008, 05:31 PM   #26958
yyhayyim's Avatar
Trader Rating: 26 (100%+)
WR
You can add weights to the right side of the pack...or you can use weights under the pack in the battery slots and glue them to the pack like this:
http://www.nexusracing.com/newsdesk_...8f9f2bb3de6240
Or as Adrian Martinez prefers, which is to mount the lipo about 2mm past the right side of chassis(batt side), and then add some weight on the inside of the battery(facing the motor/belts).
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-30-2008, 07:42 PM   #26959
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I cut lexan pieces the size and shape of the battery slots and servo taped it to the bottom of my Lipo. Core 5000 is flush with the edge of the chassis. I haven't checked the balance with the esc moved over yet. how are y'all checking balance without holes in the chassis? Ive tried the multiple scale method, but I get largely varied results with little to no repeatability.
Old 10-30-2008, 10:40 PM   #26960
mini-dub's Avatar
Thanks for the tips on lipo mounting guys.
On the Mi2 we had some towers with dimples centered in the bottom of them so you could balance the car with just two wrenches. I'm not sure who's towers they were, of if they were ever in production (over the whole period we ran the Mi2 I think I tried at least 75 individual different shock towers LOL), but it was a nice feature. So if you think you're precise enough with a dremel and some calipers, you could try this method for balancing.
For those of you who aren't running much (or any) lead, are you finding any problems with having your car so light?
Old 10-30-2008, 11:12 PM   #26961
STLNLST's Avatar
Trader Rating: 21 (100%+)
A lighter car didn't handle the same IMO. The car with a little weight in it felt better and the laptimes improved as well. The MI2 towers came with the dimple standard. You up to a Vegas reunion next year...
STLNLST is offline   Reply With Quote
Old 10-30-2008, 11:43 PM   #26962
mini-dub's Avatar
You lookin for another excuse to wear your little black dress again, big guy? hahahaha we'll see how it works out with school. Unfortunately in college my professors aren't as stoked about me turning in work late. Maybe we should ask Scotty to move the race date forward .
I think I'll probably start the car out as the standard minimum weight for 6c nimh.
Old 10-31-2008, 08:59 AM   #26963
Korey Harbke's Avatar
Not a schuie guy, but a light car usually sucks compared to what we're used to Weylin. The entire suspension setup needs to be softer and radically different in how much setup changes affect the car. Just run it at std min weight and you'll be dialed
Oh... and I second the late work thing... Makes racing hard haha
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-31-2008, 03:13 PM   #26964
I have been running my Mi3 with no weight added. It is right at the 6 cell foam min weight. I don't run anything light weight however. I'm talking steel driveshafts, std bulkheads, steel screws, std bodies, etc. The car feels great to me left to right, although I know the car is not balanced left to right, although its much closer now that I've moved the belts and ESC around. I suggest you try the car at the min weight and see what you think. Its not hard at all to add a little lead if you feel the need. A lot of this is difficult to ascertain on the web though as you don't really know what one person's standard is when it comes to a car handling "great".
Old 10-31-2008, 03:45 PM   #26965
skypilot's Avatar
Trader Rating: 14 (100%+)
couple of options, i have some of the PPD weights that go in the battery slot and act like a battery locater you can have, you can also get the ppd side plate, or for a quick but not very attractive fix, go to the hobbyshop and buy a strip of brass thats one inch wide, make sure you buy a piece long enough to cut in half to make two pieces, the core 5000 and these two pieces will put your car at weight. the battery locater weights aren't a must, but it will keep the lipo from moving, or use double sided scotch tape on the bottom of the battery.
You must be getting ready for a little NWIC action?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 11-03-2008, 09:45 AM   #26966
Grease's Avatar
Does anyone have a good vintage trans-am setup for an Mi3 with 21.5 and a lipo?
Grease is offline   Reply With Quote
Old 11-03-2008, 11:57 AM   #26967
mini-dub's Avatar
Actually Im in Boulder now at CU so Im gonna do some racing down here. I may take you up on those battery locater PPD weights though .
Old 11-03-2008, 12:28 PM   #26968
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I would say start with stock carpet setup then change the oil to 30wt in the front and 25wt in the rear with white springs all the way around. Make the rear end of the car wider like 1mm perside so the rear of the car is closer to 190mm wide. Gearing for a 21.5 lipo 96/41 should be about 4.3ish and seems to work great on long and smaller tracks speed wise. This will get you close then just tune from there to your liking. It looks like the cars like to be run really soft like softer then you would run standard rubber tire car.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 11-04-2008, 02:18 AM   #26969
Drifting101's Avatar
What size turn buckle wrench do i need my the MI3s TBs?
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-04-2008, 01:55 PM   #26970
Grease's Avatar
Thanks, I guess I wasn't very far off. This weekend was the first time I ever tried driving a T/A car. I ran the car that Chris Goetz raced at the Halloween Classic but it was on a much tighter track with less traction. The only change I made was switching the one-way for a diff and gearing it 96/36
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
