Old 10-14-2008, 06:36 PM   #26896
Drifting101's Avatar
It is so easy to work.....the ideas and thought that has gone in to the car is hugh
I run a reedy 5000 it fits perfect
BTW I ran mine for the first time i TQed it with a 1st and another 1st then a 2nd and the next two races i had a massive headache from the heat and had bad races compared to earlier (6th and 5th) i was getting 7th constanly with my old TA05
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-15-2008, 08:13 AM   #26897
Solara's Avatar
Trader Rating: 16 (100%+)
Robin, Adam and Shawn....will see you guys at the I-Hobby Expo tomorrow. Make sure bring all the goodies and show everyone...
I will post some Schumacher booth and their car's action at the show...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-16-2008, 08:42 AM   #26898
steveonamission's Avatar
Originally Posted by Jamesalex View Post
I am looking at this car and a tc5r and was wondering how easy the car is to work on change set up and fit lipos the hole hog basically any feed back would be great
cheers in advance
You won't be dissapointed one bit with the MI3.5.
IT IS the easiest car to work on out there, no other car out there is as easy access as the MI3/.5. Diffs out with two screws, take the spur out with 1 etc etc, the list does go on
No offence to the TC5's...there no way as strong as the MI3's either.
There strength is on asphalt....we took the top 6 places in the BRCA UK National championship this year,says it all realy.
Just look at this thread too, support is first class.
Regarding lipo, there is a lot of space in the car, so most lipo's will fit, personally when im not doing 5 cell mod, i run a speed passion 4000mah lipo.
HTH
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 10-17-2008, 04:59 PM   #26899
Skiddins's Avatar
Can anyone describe the handling differences between having the steering links in the forward or rearward holes in the steering knuckles.
I know they have a 3rd hole on the latest versions which I think would make the links parallel with the driveshafts etc. but I don't know if I will be able to get hold of them tomorrow.
Their effect on carpet and asphalt would be appreciated as I'm rebuilding for some carpet/rubber racing on Sunday.
Will having them in the forward holes (making the links sweep forward towards the outside make the steering too aggressive?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-19-2008, 12:31 PM   #26900
Mr. McGoo's Avatar
quick question - is there anyway to get the SMC 5000 to work with our car w/o doing some machine work to our bulkheads?
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-19-2008, 01:16 PM   #26901
Trader Rating: 28 (100%+)
use a bitty designs lipo tray which hangs it out over the edge of the chassis a bit
http://www.bittydesign.net/PortaLipoSCHUMACHER-ING.htm
Ashley Cobb is offline   Reply With Quote
Old 10-19-2008, 01:29 PM   #26902
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm thinking the problem is that the SMC 5K won't fit under the bulkheads. I am not sure how the tray would help unless you're suggesting to move the lipo so far out from the bulkheads that it doesn't even sit underneath . . .?
Maybe shimming all 4 bulkheads up 1 mm would work . . .It would require quite a bit of work though. You could shim the roll centers down a mm, but you wouldn't be able to move the shock tower down with it so your shocks will need to be a bit longer. Your diffs, and motor would end up higher too. You might run into problems with the steering rack and the bulkheads.
Wait! I know the answer!
1 CELL LIPO fixes EVERYTHING!!!
J/K McGoo. BTW, do you know if you got the new top wire exit version, or the older side exit version of the 5K?
Old 10-19-2008, 01:34 PM   #26903
I've been told it shifts the lipo out about 5mm which means it clears the top deck/bulkheads.
With mine I just tape it out there and it works fine.
I have the orion platnium 4800's, which fit under the deck/bulkheads but because they have corally plugs on the top it has to sit out a bit
Old 10-19-2008, 04:22 PM   #26904
Mr. McGoo's Avatar
it does look like it shifts it out 5mm. this is for the s400, but the mi3 is the same thing....
Old 10-19-2008, 08:06 PM   #26905
that looks like the one. Only reason i haven't bought one yet is the price
Old 10-19-2008, 10:57 PM   #26906
JayBee's Avatar
Trader Rating: 31 (100%+)
You know guys it wasn't that hard for me to take the sticker off and sand the SMC logo off the bottom side of the plastic case. Worked like a champ Heavy grit followed by 400grit.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-19-2008, 11:42 PM   #26907
A reedy 5k fits like a glove without any brackets So i dont see why a smc wont fit
Schumacher
Old 10-20-2008, 12:28 AM   #26908
I think the lypo tray above sticks out to far...unbalances the car.I have the tray that sticks out about 3mm...I dremeled out the bulkheads and fitted a core 5000...the car is still balanced and I only had to add 10gms of weight to bring the car up to legal weight...and all the weight is under the battery.
Barger is offline   Reply With Quote
Old 10-20-2008, 01:47 AM   #26909
Originally Posted by JayBee View Post
You know guys it wasn't that hard for me to take the sticker off and sand the SMC logo off both sides of the plastic case. Worked like a champ Heavy grit followed by 400grit.
In australia we are not allowed to modify the case of a lipo in any way
Old 10-20-2008, 05:56 AM   #26910
Default Shock Mount options
Hi
Is there some options for replacing the upper shock mount plastic bush and washer (U613 part). Always misplacing the tiny barrel shaped bush. Hot Bodies do a nice Purple alloy one piece item, but doesn't fit. Anybody know another make that will ?
Cheers
Tweaky is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
