Old 07-31-2008, 04:36 PM   #26641
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by abailey21 View Post
The Ackerman arm looks more like a one off than a pre-production part?
You're not suppose to be guessing about this stuff...LOL
Teemu and I ran the HPI setup several times in '06
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-31-2008, 04:38 PM   #26642
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
and dont forget the Corally steering rack too
RACE OPT USA
Bartolo Racing R/C
Old 08-03-2008, 02:51 PM   #26643
baf1's Avatar
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 08-03-2008, 06:18 PM   #26644
Mopar's Avatar
My MI2ec will be hitting the track again
Mopar is offline   Reply With Quote
Old 08-03-2008, 09:54 PM   #26645
skypilot's Avatar
Trader Rating: 14 (100%+)
Mi3, is just a incredible chassis.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 08-04-2008, 06:26 AM   #26646
abailey21's Avatar
Trader Rating: 36 (100%+)
You have an incredible chassis!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-04-2008, 08:34 AM   #26647
skypilot's Avatar
just having some amazing runs with it,
Old 08-04-2008, 11:58 AM   #26648
Mr. McGoo's Avatar
Suspension Upgrade Update....
For those waiting on the suspension upgrade, I should have everything done next week. Unfortunately some of the parts needed have been on backorder, and I got tired of waiting, so I am buying everything from like 5 different places so I can get these things out of here!
I will keep everyone updated.
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 08-04-2008, 12:02 PM   #26649
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Mi3.5 Pro
Any word on MI3.5 performance at the 2008 Euro?
yyhayyim is offline   Reply With Quote
Old 08-05-2008, 10:40 AM   #26650
hi , im new to the uk team and gotta say the 3.5 is an
awesome car , so agile and direct ! set up is easy and very noticeable
even on small changes , its really impressed me (ive had a few different
cars too ! ) also the corner speed is sweet !
glenn
G WESTWOOD is offline   Reply With Quote
Old 08-05-2008, 12:22 PM   #26651
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Hey guys had a few questions in regards to setting up my Mi3 for carpet rubber.
I am currently running on a med traction carpet track with RP30 tires. I am using the carpet chassis and the thin top deck. I am using pink and blue HPI springs (the softer ones in the rear). I also have a one-way in the car. I have tried spool as well and seem to run the same lap times with either option.
Also, I am running the standard bulkheads w/ Core 5000 Lipos.
Is it recommended to use the carpet chassis or the asphalt chassis for carpet rubber?
Also both my diff heights are set to low. How does this affect handling?
I had also been messing with gear ratios this past weekend. Our track is 100 x 60 with average of 9.3 second laps. I was geared at a 96/47 with my SP 17.5 and was running 8.9-9/0 consistent. I went down to a 96/40 and ran 8.7 consistently. My motor is coming off the track at 130 degrees.
I am consistently running in the middle of the pack for 17.5 rubber.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 08-05-2008, 02:00 PM   #26652
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Are you running the lightweight bulk heads or the standard ones on your car right now? If you are using the lightweight ones stick with the foam chassis if not then go to the stock chassis. For me depending on what bulk heads I had on my car that would dictate what chassis I would use. The lightweight bulk heads give the car more flex and if you add them to the stock chassis thatís almost too much for med to high grip carpet IMO....but the foam chassis and the lightweight bulk heads combo works great along with the stock chassis and stock bulk heads for med to high grip carpet on rubber tires.
Have you tried the spool on carpet yet?
How low are your roll centersÖ.how many mmís are the mounts spaced so we can see if you are too low or what.
I have yet to run a 17.5 in my MI3 in anything other then Trans AM so I cant help you on the gearing....just keep the temp around 120 to 150 and most times you are in the ballpark.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 08-05-2008, 04:06 PM   #26653
Kevin,
Thanks for the comments. I updated my post to take into account your questions.
Old 08-05-2008, 04:47 PM   #26654
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I prefer the carpet chassis and the carpet top deck for rubber tires on carpet even in medium and medium low traction conditions. I felt the thinner top deck and chassis were less consistant and more easily tweaked than the thicker versions. I've broken my share of kit top decks, but never one of the carpets.
my too sense, lol.
Old 08-05-2008, 05:49 PM   #26655
skypilot's Avatar
can i get a dinner menu or what?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
