Old 07-22-2008, 02:34 PM   #26581
MagicMarker's Avatar
Originally Posted by cpatel529 View Post
Are the carpet towers used for carpet foam and when you have carpet rubber with high traction?
Yes - used for both. I have even used the carpet tower on ashplat.
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 07-22-2008, 04:50 PM   #26582
skypilot's Avatar
Trader Rating: 14 (100%+)
How can you tell the difference between the carpet and stock shock towers? On one set that I have, there is a gap between each of the shock mount holes. On my other set, all 4 of the shock mount holes are "attached" to each other. Can someone help me determine which one is which.
What is the advantage of the lightened bulkheads? My car is already underweight as it is..
How can I tell the difference between the medium flex arms and the stiff ones? I have ones that say C/F on them and ones that dont. Not sure which is which.
Chirag
with VHT being used at the big dads race this weekend the CF arms should be fine. I've running the mediums cause they don't break not for extra steering
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-22-2008, 05:34 PM   #26583
baf1's Avatar
Default ??????
anyone using two hole pistons on tarmac,and if so, wait oil difference is there two hole pistons to three??? thanks.
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 07-22-2008, 06:01 PM   #26584
skypilot's Avatar
i use two hole 30wt front three hole 35wt rear works pretty good IMO
Old 07-22-2008, 06:35 PM   #26585
Hey what's up National Champ? You going to Vegas?
Old 07-22-2008, 06:38 PM   #26586
skypilot's Avatar
whats up mr. magic,
really want to come and looking for flights everyday, not going to race though, just come hang and cheer you guys on.
Old 07-22-2008, 06:59 PM   #26587
That's already come hang out and just chill for a bit.
Old 07-22-2008, 07:13 PM   #26588
Trader Rating: 28 (100%+)
properly prepping the suspension arms etc, how important is it? eg using an arm reamer
Ashley Cobb is offline   Reply With Quote
Old 07-22-2008, 07:34 PM   #26589
I prep and ream every arm that goes on my car. In fact, I have several arms with ball ends installed and droop screws in the arm for quick change out. Anyway, get a 1/8 inch drill bit and put it in an out hex driver, so you have a reamer and ream each arm until it spins freely on the bit. Hope this helps.
L8R Marker
Old 07-22-2008, 08:01 PM   #26590
L8R Marker
That's probably why my cars never work properly.
Thanks for your help champ!
Old 07-22-2008, 08:15 PM   #26591
No problem on the help. The champ part is all Skypilot - he's got the lastest title.
Old 07-22-2008, 08:38 PM   #26592
skypilot's Avatar
Part of that "Champ" stuff belongs to the team, you guys helped with some decisions, like when i said, i was going to change the car after the first main and you guys were, "dude, don't touch it" or something to that effect,
and don't forget when i was freaking out over the battery for the 3rd main peaking at like 2500mah and 160 degrees or something like that, you calmly said, "just repeak it" it all helped and thanks again to you and rest of the team, except adam, he just sat there all day doing nothing
Old 07-22-2008, 08:52 PM   #26593
You may be right but there was still only one guy driving the car. As always great job.
I'm off to bed my friend , I have to get up in 6 and 1/2 hours.
Nighty nighty
Old 07-22-2008, 09:05 PM   #26594
skypilot's Avatar
see ya
Old 07-22-2008, 10:18 PM   #26595
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Ive used both the 3 mm HUDY arm reamer and a reamer I bought 4 years ago to ream stock motor bushings. Both worked great. I have found the M arms take a little more effort. But it is definitely something I do. Be sure you are checking tolerances with a perfectly straight hingepin. I keep one in my box ust to check the arms so a bent one from my car doesn't have me reaming too much. However I have found some arms perfect from the package, so check them before you ream 'em.
On a related note the Tamale stuff is the real deal. I've been running some foam 13.5 and have been realy impressed with the durability. The pieces allow you to take every last fraction of a mm of slop out of the arms without any binding. And the best part is it stays that way. When I compared my car to a fellow racers 008 his car felt like a TT-01, lol.
Just wanted to give puplic props to McGoo, Seabass, Larry et al. Between that and my discovery of the M arms, I haven't broken or bent a piece in months of racing and twice weekly all day practice.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
