Old 06-08-2008, 05:08 PM   #26236
How do you measure droop from chassis to floor?
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 06-08-2008, 05:13 PM   #26237
Trader Rating: 28 (100%+)
measure the ride height, then lift the car up at the end your measuring and just as the tyres come off the ground measure again
subtract the 2 numbers and thats droop
Ashley Cobb is offline   Reply With Quote
Old 06-08-2008, 05:55 PM   #26238
PW
PW's Avatar
Send a message via AIM to PW
Sup boys & girls! Just stoppin by to see whats up!
Seaball keepin the man love strong in here....
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 06-08-2008, 06:18 PM   #26239
Cesar's Avatar
PW we gonna see you this coming weekend???
I got some ?????
Cesar is offline   Reply With Quote
Old 06-08-2008, 06:31 PM   #26240
So you would have to check your droop every run as your tires would change in size when they get worn? Seems like an inaccurate way to do it
Old 06-08-2008, 08:12 PM   #26241
PW
PW's Avatar
I got some ?????
That's the plan.
Paul Wynn
Old 06-08-2008, 08:30 PM   #26242
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Yeah pretty much. With rubber tires they don't wear to bad. With foams, depending on how where you start with tire size and how much you run them, you will have to consistantly monitor droop. I will say this though, just because you set it at a number on the droop gauge it doesn't take into account for your tire size.
I run rubber tires and still set my droop by subtracting the two numbers.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-08-2008, 08:32 PM   #26243
Originally Posted by Marcos.J View Post
hey JayBee here is my foam car ( with McGoo set up)
Hey are they powerpole connectors on the motor? i thought they were only good for like 25amps?
Old 06-08-2008, 08:59 PM   #26244
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
they are deans,and i had them on all my motors for over a year with no problems at all
RACE OPT USA
Bartolo Racing R/C
Old 06-08-2008, 09:01 PM   #26245
Super Moderator
Marcos.J's Avatar
Originally Posted by mickrcarver View Post
hey marcos the original setup on that car was jim beans snowbirds setup i still have it somewhere but trying to find it by the way the car was ultra smooth on our carpet track
P.S. notice the steering setup for lower ackerman
what springs did he have in the front??
and yes i did noticed the lower steering set up
RACE OPT USA
Bartolo Racing R/C
Old 06-09-2008, 12:05 AM   #26246
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I just ordered my Losi Type R this weekend and was thinking of buying the SpeedPassion ESC. Now I am not a what ever is the hottest thing going this weekend type purchaser. I went to my track and was told I would be better off getting an LRP and was also told none of the TOP drivers for the Reedy Race ran the SP esc so can someone give me the good, bad or indifferent on this esc. Why you think it would be or would not be a good purchase. I will be running stock since I am a novice. Thanks in advance.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 06-09-2008, 06:14 AM   #26247
mickrcarver's Avatar
Trader Rating: 98 (99%+)
those are x ray springs from the new batch I think they were 30's they are marked with a # i think
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 06-09-2008, 06:16 AM   #26248
Super Moderator
Marcos.J's Avatar
thanks!
RACE OPT USA
Bartolo Racing R/C
Old 06-10-2008, 02:13 PM   #26249
Hello
im writing because ive got a problem with drive shafts of MI-3
i know everybody says that the silver ones (u3020) are better than purple one, for me are just the same (broke as glass)and thats my only complain about the car.
im going to put the steel ones (U2151) but a guy told that i have to put a spacer.
anyone of you are using the steel drive shafts and how you tighten the hexs against the Hub ball bearing, cause i want to wear that ones but i dont know what kind of spacer do i have to use.
please help me in this issue
thanks
Joao Martinho
jopor is offline   Reply With Quote
Old 06-10-2008, 02:15 PM   #26250
abailey21's Avatar
Trader Rating: 36 (100%+)
Try U3267's for CVD's
Originally Posted by jopor View Post
Hello
thanks
Joao Martinho
K.C.C.O.
abailey21 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
