Old 06-03-2008, 05:14 AM   #26191
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Originally Posted by cpatel529 View Post
What is the approximate spring stiffness for the Schumacher White springs?
14 lbs
Old 06-03-2008, 09:07 AM   #26192
6Venom's Avatar
Trader Rating: 44 (98%+)
Default Mission Asphalt Setup
This is so noob but I started a search and didn't want to read through several hundred pages (at least not today).
Does anyone have a link to some asphalt setups for the Mission? I'm reconfiguring mine to run lipo and brushless and was hoping for a basic setup to start with.
Thanks for the help!
6Venom is offline   Reply With Quote
Old 06-03-2008, 10:00 AM   #26193
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
you won't believe where i found these ...
http://www.racing-cars.com/usa/searc...e1=prodvalue14
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-03-2008, 10:08 AM   #26194
JayBee's Avatar
Trader Rating: 31 (100%+)
Unhappy
Being that my local carpet track (Seattle Indoor Raceway) has just recently reverted back to asphalt, I'll be converting one of my foam cars back to rubber just to get some 'stick' time. Sucks with Vegas coming up. There is one carpet track about 2.5-3.5 hours away that's a World Class carpet track that I'll have to travel to get some Vegas-esque (<--a seaball-ism) type practice.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-03-2008, 10:56 AM   #26195
6Venom's Avatar
haha...I know, thanks. I had hoped someone had something newer than 2003. Thanks for the info though, I do appreciate it.
Old 06-03-2008, 01:28 PM   #26196
Super Moderator
Marcos.J's Avatar
Originally Posted by sf85 View Post
Can someone please send me a good setup for the mi3 for medium to high grip asphalt track?
thx
Hey Skip this is the set up that I ran this past weekend on my Mod and 13.5 car at superiors, it was really good!
Old 06-03-2008, 03:58 PM   #26197
skypilot's Avatar
Trader Rating: 14 (100%+)
1.2 mm drilled on the shock pistons is close to what number in the losi pistons, (i have the losi finger drill set) looks to be a 56?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-03-2008, 04:35 PM   #26198
yyhayyim's Avatar
Trader Rating: 26 (100%+)
losi 56 is 3 hole pistons
yyhayyim is offline   Reply With Quote
Old 06-03-2008, 06:21 PM   #26199
Thanks for the setup Marcos!
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 06-03-2008, 06:32 PM   #26200
hey guys ive been having trouble with snapping axles ive snapped 2 in very light contacts (corner dots) is there any options for stronger axles?
what could cause this? any suggestions
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-03-2008, 07:17 PM   #26201
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
56 is the closest. 3/64th's is close as well
I don't have the PN but schui makes a steel cvd. The only draw back is there is a shoulder at the threaded end of the cvd that requires you to run a 1 mm spacer or ream the inside of your whels a bit. I run the stelies in the rear of my car as I always run at least 1mm of spacers on the hub there anyway . . .
Old 06-03-2008, 09:08 PM   #26202
skypilot's Avatar
thanks for that.
btw, any shouie guys - driving - to pavement nationals, just a little heads up, i won't be packing any type of liquids for the flight and will be bugging you guys for hand outs, also not bringing a soldering iron. not complaining about my borrowing stuff will get you a drink, or some sort of food of your choice.
or i may just buy it at the track and give it away after the race depending on how much you drink/eat.
Old 06-03-2008, 10:00 PM   #26203
Super Moderator
Marcos.J's Avatar
get the steel CVd's part # U2151 and use the purple alloy hexes part # U2401 and you should be just fine for the MI3 !
Old 06-03-2008, 10:00 PM   #26204
Super Moderator
Marcos.J's Avatar
no problem Skip
Old 06-03-2008, 11:43 PM   #26205
JayBee's Avatar
Marcos da Prophet!!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
