Old 05-28-2008, 03:10 PM   #26146
stokka's Avatar
Anyone who can explain what's the advantage with the blocks Larry produces for McGoo?
~stokka
stokka is offline   Reply With Quote
Old 05-28-2008, 03:44 PM   #26147
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
~stokka
if you're talking castor blocks, the advantage is durability and the opportunity to get some angles that aren't offered by the factory.
if you're referring to the suspension upgrade, it is mainly intended to provide durability. the upper camber link mounts won't bend, and the whole system provides you with female threaded pivot balls, which makes shimming the camber gain a bit easier since you don't have to take the mounts off the bulkheads. the lower end of things offers tool steel hingepins, which are polished a bit better, and should never bend.
if you haven't had any issues thus far, it's probably not a worthwhile investment. if you have, it will pay for itself in a few months. not to mention the idea that you won't have to keep checking to see if the car is bent up.
i think it's a must have for carpet guys. i've seen too many bent pieces this past year to think otherwise.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-29-2008, 01:38 PM   #26148
stokka's Avatar
thanks for updating me..
Old 05-30-2008, 10:50 AM   #26149
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
OK, I can't remember the last time I ran a NiMh pack in my car, so here's a queston for y'all.
Is there a standard, or more common configuration for batteries in Sedans? (Mi3 in particular) Do most people put the pos or the neg at the back? I gave in and ordered packs for nats and don't want to be the odd ball incase my homies forget to charge a pack for their race and then were running around trying to swap the bars at the ends! (More likely it would be me)
Old 05-30-2008, 11:05 AM   #26150
John_S's Avatar
posi at the front is the most comon
John_S is offline   Reply With Quote
Old 05-30-2008, 11:50 AM   #26151
theisgroup's Avatar
i configure mine to fit in the battery trays. I think it is called reverse. positive in the front
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-30-2008, 08:40 PM   #26152
Default Setup
Can someone please send me a good setup for the mi3 for medium to high grip asphalt track?
thx
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 05-30-2008, 09:08 PM   #26153
thx
ygpm
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 05-30-2008, 09:42 PM   #26154
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
thx
Hey Skip I got one for you are you coming to superiors sunday??
Old 05-30-2008, 11:29 PM   #26155
ChestyV32's Avatar
Trader Rating: 32 (100%+)
hey Allen can u PM me that setup please
Cheston
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 05-31-2008, 03:23 AM   #26156
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Here's a couple of pics of my new Mi3...finally have it together after about a 5 week build
Schumacher Corner-mi3a.jpg   Schumacher Corner-mi3b.jpg   Schumacher Corner-mi3c.jpg
SchuMi2 is offline   Reply With Quote
Old 05-31-2008, 03:34 AM   #26157
Kennynham's Avatar
Trader Rating: 46 (96%+)
my new Mi3...finally have it together after about a 5 week build[/QUOTE]
Should of brought an RDX PHI would of taken u a couple of hours.....
That is one hot looking car.....
well done mate...
TEAM HB
HB D8 Tekno v4
I Like it Dirty!!!!
Kennynham is offline   Reply With Quote
Old 05-31-2008, 06:11 AM   #26158
Not going to be able to make it out there this weekend
Old 05-31-2008, 08:55 AM   #26159
Super Moderator
Marcos.J's Avatar
oh well , remind me next time i see you i have that bulkhead for you
Old 05-31-2008, 09:07 AM   #26160
Super Moderator
Marcos.J's Avatar
Thumbs down
Cheston
Hey Cheston if you need a really good set up try PW's set up from Kissimme last year , its really good ,I made some minor changes and its really good!! just ask Adam
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
