Old 07-29-2002, 10:26 AM   #2596
Regional Moderator
Darkseid's Avatar
rcfiend: I never drove an Xray. I drove the car that came out before it, that the Xray was...ummm...similar to! I drove a Corally C4.1. This car was as strong as the Schumacher, with the only weak point being the hinge pins.
If you do decide to go with an Xray over the Mission, I wont try to convince you otherwise. But besure you don't venture too far outside the stock setup on that car. For all the adjustments it has, even those who drive it regularly know that most of them are useless beyond the kit's stock setup.
As for breakage, I'll say it again, I've been running Schumacher sedans off and on since the original SST2000. The only thing I've ever really broken has been the front plastic drive shafts and that was before they added the steering stops to the front arms. Now I break nothing. I would love to see the impacts you guys are taking to break this car.
It seems to me that your issues are more with your track directors than with your car. If your getting hit that hard during practice, they need to clean up your practice sessions!
If your breaking a Schumacher every week, then I don't know what to tell you. Other than, you wont find a more durable car on the market, Period!
Anyways......Good luck with whatever you decide to drive, and if I were you, I would talk to the race director about cleaning up those practices.
TLR 22...Tamiya F104...
Old 07-29-2002, 11:23 AM   #2597
rcfiend's Avatar
Trader Rating: 26 (100%+)
Originally Posted By Darkseid rcfiend: I never drove an Xray. I drove the car that came out before it, that the Xray was...ummm...similar to! I drove a Corally C4.1. This car was as strong as the Schumacher, with the only weak point being the hinge pins.
Thanks for the input darkseid. You may have a point about speaking with the race director. If I race at other tracks I have no problems, unfortunately the track where I get hit the most is the track where all the really good drivers go to.
The impacts I endure are side impacts as I'm entering a turn and the person behind me fails to slow to enter the turn. From this vantage point the car is really exposed. But I guess any car would be. Again thanks for your input.
rcfiend is offline   Reply With Quote
Old 07-29-2002, 12:57 PM   #2598
Schuieracer's Avatar
Send a message via AIM to Schuieracer Send a message via Yahoo to Schuieracer
Yeah the SST99 could compete in the hands of a very good driver. But, a less experience driver would do as well or better with the new Mission, it is so easy to setup and drive. (It is also very efficient and fast )
Schuieracer is offline   Reply With Quote
Old 07-29-2002, 01:44 PM   #2599
Regional Moderator
Darkseid's Avatar
rcfiend: yeah, those side impacts are the worst kind of impacts. I had my GM V12 speedcontrol damaged earlier this season when someone decided that slowing down to turn wasn't the best method!
Old 07-29-2002, 05:55 PM   #2600
cornerspeed's Avatar
rcfiend- Is it SoCal Raceway the track your talking about. I f it is, I know what you mean. I race there to with my Mission car. I ran the new Warpspeed chassis last weekend. Better then ever. I have some tips on keeping your car together better. I will show you sometimee, if you give the car a chance. Any car is going to bend or break. The Mission is one of the most durable. I will be there this Sat.
cornerspeed is offline   Reply With Quote
Old 07-29-2002, 10:06 PM   #2601
heavy's Avatar
Trader Rating: 20 (100%+)
Default Mission Front Belt
Hi guys, just checking to see if anyone has had teh problem of teh front belt turning over (inside out ). Happened to me once early in teh life of my Mission and I just thought it was a one off thing. One of teh other guys at the local track (Bayside, Brisbane Australia) had his turn over last week as well. Maybe running a tad to loose? Any advice?
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 07-29-2002, 11:53 PM   #2602
ottoman's Avatar
R/C Tech Charter Subscriber
Kevin K.... thanks for the setups... I was surprised at the 70 weight oil for rubber tires.... I will try it out... the other item is interesting and I will give it a try also.... whats up with the warpspeed chassis...and good reports yet?
ottoman is offline   Reply With Quote
Old 07-30-2002, 12:17 AM   #2603
rcfiend's Avatar
Originally Posted By Cornerspeed rcfiend- Is it SoCal Raceway the track your talking about. I f it is, I know what you mean. I race there to with my Mission car. I ran the new Warpspeed chassis last weekend. Better then ever. I have some tips on keeping your car together better. I will show you sometimee, if you give the car a chance. Any car is going to bend or break. The Mission is one of the most durable. I will be there this Sat.
Yep, SoCal is the track i'm referring to. What's your name, so i'll know who to look for? That chasis maybe nice, but for $130.00 it better guarantee to shave at least 5 seconds off of my lap times
Old 07-30-2002, 12:23 AM   #2604
ottoman's Avatar
Kevin K... what upper deck are you running? I didnt see it on your setup sheets
Old 07-30-2002, 08:10 AM   #2605
rcfiend- The name is Don Vinkemulder. See you there.
Old 07-30-2002, 08:18 AM   #2606
BagofSkill's Avatar
Heavy
Maybe it's an Aus thing? I'm racing in Sydney and have had mine go upside-down twice, once with the black belt and once with the grey, although luckily both times it was in practice. I lifted the belt tensioner a fraction and haven't had it happen for a while now.
BagofSkill is offline   Reply With Quote
Old 07-30-2002, 10:05 AM   #2607
Default Foam tarmac set-up?
I am looking for a killer set-up for my mission on a permanent tarmac track.I am running Sprint foam tires.Any set-up suggestions will be tried.
Jaco Coetzee
Team SGProducts
[EMAIL]jacorc@hotmail.com
JacoSA is offline   Reply With Quote
Old 07-30-2002, 04:10 PM   #2608
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ottoman.....sorry I run the carpet top deck all the time.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-30-2002, 06:06 PM   #2609
King-G's Avatar
Send a message via ICQ to King-G
Hi Heavy, good to see another Aussie has picked up a mission, and found the forums!..
as for the belt flipping over, It has not yet happened to me, I have run both grey belts and black.
I would suggest it is due to debris getting stuck unter the belts teeth.
Check the pulleys for any crap, and use a toothbrush to scrub the pulleys to remove any junk.
also run just a little tension on the belt, I run just a little for mod, to prevent the front belt skipping on hard acceleration on high grip.
If these solutions fail, try running a little strip of tape on the underside of the bulkhead where the belt runs, to allow less space for the belt to flip over.
Cheers G!
P.S what type of track are you racing on?...rubber or foam?..
King-G is offline   Reply With Quote
Old 07-30-2002, 08:05 PM   #2610
Kevin K's Avatar
Heavy....I was at the track a while back and a kid had the same thing happen and what I saw was that he had is front diff in backwards, meaning left side on the right etc. You might want to check and see if thats in properly. Also he had a pice of flashing on the bottom side of the front upper suspension mount that rubbed on the belt aswell, that could have caused the same problem. So these are somethings that I have seen cause the problem that you are talking about.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
