Old 05-08-2008, 07:57 PM   #26011
skypilot's Avatar
Trader Rating: 14 (100%+)
i run a diff in my trans am car because of the low grip hpi tires, with real HP and tires the car lags coming off the corners, i prefer the spool
skypilot is offline   Reply With Quote
Old 05-08-2008, 09:19 PM   #26012
JayBee's Avatar
Trader Rating: 31 (100%+)
Spool on the car @ all times except for foam/carpet; then the diff comes out
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-08-2008, 09:23 PM   #26013
Solara's Avatar
Trader Rating: 16 (100%+)
This is something I want to find out....what are the different (handling) betweeen using a SPOOL and 1-way...? I am going to use the 3.5 on a 275' long 1/8th track....
Right now...I am more toward the spool cause most outdoor mod are running spool....but isn't 1-way carry more speed overall?
P.S....Adam, ship that 3.5 and 1.1 ASAP....or I have to spend time on the 1/8th on road instead....FAST...LOL
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-08-2008, 09:39 PM   #26014
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by gdcopbdcop View Post
YES!!! lol, of course....see you there i will also be there on sat to practice. i may run down to ripon on sat night to race after practice....will you be there?
Be where? I'm not practicing this weekend and I won't be going to Ripon.
STLNLST is offline   Reply With Quote
Old 05-08-2008, 09:41 PM   #26015
JayBee's Avatar
IMHO, OVERALL HANDLING feels about the same; but corner entry and to some degree corner exit is drastically different.
To carry more speed into the corners with the spool, you're on throttle alot longer than with the 1-way. Tap the brakes and get right back on throttle early-mid corner. The spool has alot more inherent braking effect too.
With the 1-way, brakes for me usually is a big no-no. High speed 'coasting' suits this type of front end and over shootin' corners is a BIG problem for alot of peeps.
On that size track though, I would try both. The 1-way will probably win out & will yield lower motor temps.
Old 05-08-2008, 10:19 PM   #26016
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Oneways were used more often to make up for cars that didn't turn inherently IMO. These days, I don't think there's any reason to run one unless you're on carpet with rubber tires. Everyone ran diffs in the front back in the day. Diffs push on asphalt. They just do. If you run one loose enough to give oneway like diff action going into the corner, it'll unload super easy on power and push like crazy coming out of the corners. Tighten it up some and you loose some turn in and it still will tend to unload on power. Older car designs didn't have the steering that our cars do now. So to make the car turn, guys started running oneways. Problem is you loose your front brakes and all but the best drivers with the most balanced and consistent cars lost the ability to use the brake period as the car will swap ends quickly if there's a slightly heavier load on one side than the other when you so much as touch the brake. So head to head racing tended to suffer because guys couldn't dive into corners and race aggressively. Then the Reedy Race put in a no oneway rule. So guys started tightening their front diffs to keep it from unloading on power until they had a locked diff. Then they worked on getting the car to turn in harder off power with a locked diff in the front. That's when we started seeing purpose built spools all over the place rather than just locking up a diff. The spool gives a lot of exit steering as both tires are pulling hard under power. Racing got better, closer, and the cars now tend to handle better with a spool than a oneway since we don't usually need as much turn in as a oneway provides and the stability of the spool just makes it easier to drive fast.
Jon Kerr is offline   Reply With Quote
Old 05-09-2008, 06:16 AM   #26017
mickrcarver's Avatar
Trader Rating: 98 (99%+)
ok stupid question here,I just finished putting the medium arms on my mi3 front and rear,are they spose to bend like putty? lol I mean these things are really soft more so on the front than rear. Any body else with this going on?
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 05-09-2008, 08:16 AM   #26018
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Yep. Thats the medium arms!
Old 05-09-2008, 09:39 AM   #26019
oh ok cool where can i get more??
www.ovrccc.com
Old 05-09-2008, 11:33 AM   #26020
abailey21's Avatar
Trader Rating: 36 (100%+)
You sure you got the med and not the ultra flex??
The medium flex front to rear all came out of the same batch of material and are no different front to rear.
Also they don't "bend like putty" by any means, even though they are softer than the CF arms its not by much.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-09-2008, 12:11 PM   #26021
they all have an M stamped on them and they all said medium flex on the package the term like putty may have been alittle stretched but they do flex alot more than the c/f's
www.ovrccc.com
Old 05-09-2008, 12:24 PM   #26022
Jon Kerr's Avatar
If you think the med flex a lot, you should see the ultra flex.
Old 05-09-2008, 01:24 PM   #26023
wow!!~flex could be good for my track its green and bumpy
www.ovrccc.com
Old 05-09-2008, 07:59 PM   #26024
Solara's Avatar
Thanks Jay and Jon.....basicly, what you guys saying is very much close to how I feel.....so once Adam decided to send my 3.5 sometime THIS YEAR....I will use the spool and try to run against 200mm nitro TC...
Meanwhile....front spool on my 1/8th Serpent is the ONLY option....
Old 05-10-2008, 07:45 AM   #26025
Goingfast's Avatar
Trader Rating: 29 (100%+)
Default MI3 2.5 carpet chassis
who got 2.5 carpet chassis for sale used or new lmk...thanks
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
