Old 05-04-2008, 07:02 AM   #25951
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by Big Features View Post
I dont think so, the Mi2 arms have some graphite in them, the Medium arms hae very little if any.
just making sure i recall PW using the MI2 arms in a set up then switched to the medium arms with the same set up.
Old 05-04-2008, 09:41 AM   #25952
stlnlst, i give big props to scotty..his car was wonderfull, and his driving magnificant....however, i do have a small question that i ask myself,,
his motor had the purple metal ring removed, AND it had a large vent cut out on the endbell, BOTH of which would have made the motor illegal for use at the reedy. would he have had the same times? would he have won without the illegal motor???,, it could be,,,or not..... but i do agree, his car was wonderfull
gdcopbdcop is offline   Reply With Quote
Old 05-04-2008, 03:50 PM   #25953
baf1's Avatar
Default HAM!!!!!!!!!
WHERE HONEY GLAZED SPIRAL CUT MMMMMMMMMMM
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 05-04-2008, 05:02 PM   #25954
AdrianM's Avatar
Those changes only change the looks and improve cooling. If he was fast he would have been just as fast with any other motor.
Adrian Martinez
Old 05-04-2008, 05:08 PM   #25955
AdrianM's Avatar
The stock Mi2EC arms are C/F arms. The stock Mi3 arms are also C/F and are similar but are reinforced with added material and have the new Mi3 sway bar ball stud hole.
The Med flex arms are not C/F but use glass fibers in a lower percentage relative to the base plastic material.
In PW's first setup he used original Mi2 (not EC) arms that are no longer available. He drilled holes for the sway bar ball studs. These were glass filled but had a higher glass to plastic ratio than the Med flex arms. Like Marco said eventually to the Med arms and they were even better.
Adrian Martinez
Old 05-04-2008, 08:07 PM   #25956
STLNLST's Avatar
Trader Rating: 21 (100%+)
When you're puttng his car down for the A main then you'll have your answer.
STLNLST is offline   Reply With Quote
Old 05-04-2008, 08:30 PM   #25957
stlnlst, i agree, he was very fast. if he drives that way at the reedy he will more than likely be in the main....and he certainly deserves it.
Old 05-04-2008, 08:31 PM   #25958
stlnlst, i agree, he was very fast. if he drives that way at the reedy he will more than likely be in the main....and he certainly deserves it. it couldnt happen to a nicer guy either
Old 05-05-2008, 12:08 AM   #25959
There isn't such thing as an Mi2EC arm? The Mi2 and the EC had the same arms, so if you want to get the C/F arms it will be labeled under Mi2?
Also the Mi2 C/F arms are a thinner mould at the end (where you insert the pin shaft thing ) so it is marginally lighter once you replace all four arms with the Mi2 versions.
Kirby Masterman is offline   Reply With Quote
Old 05-05-2008, 01:42 AM   #25960
Send a message via ICQ to MattW
Mi2 kit was supplied with std plastic arms - with C/F released as an option. EC kit was supplied with the option C/F arms in the box.
The EC C/F arms are ~ 1.5 - 2g lighter per arm than the std Mi3 arm. You then need more wheelbase spacers, so probably not much in it weight wise at the end of the day.
MattW is offline   Reply With Quote
Old 05-05-2008, 10:05 AM   #25961
allan hewett really laid it down today in the 13.5 class at the reedy warm up race at roseville. he qualified 2nd in the race that had a large turn out, and finished 2nd in the main, 1 1/2 seconds behind the winner. his car looked great all day. dujuan moore borrowed arron youngs car for the day. he qualified 1st in the b main, less than 1 second out of the a main. he ran into some bad luck in his main. me, i just suked, but i had a great time.
I tested all weekend and ended up with a good setup for the car and the speed passion gt. It was a good weekend and hope to do the same for reedy.
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 05-05-2008, 11:58 AM   #25962
Racer X's Avatar
I want to thank Allen for the setup that I was able to steel from his car...much better than the one I was using. If there is anything I can do to help you out at the Reedy (or any other Schumacher drivers who are planning to attend), feel free to ask!
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 05-05-2008, 12:03 PM   #25963
abailey21's Avatar
Trader Rating: 36 (100%+)
Hewitt call me!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-05-2008, 08:53 PM   #25964
JayBee's Avatar
Trader Rating: 31 (100%+)
Adam call ME!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-05-2008, 09:56 PM   #25965
Super Moderator
Marcos.J's Avatar
Originally Posted by JayBee View Post
Adam call ME!!
JayBee Ill call you
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
