Old 04-21-2008, 03:09 PM   #25861
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
OK team need a setup that has monster steering on rubber tires on asphalt . I would rather have too much and back off.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 04-21-2008, 03:57 PM   #25862
Rod
Hey pm me your email and I have a good setup I have been working on
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 04-21-2008, 09:54 PM   #25863
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Which aftermarket spur gears will work with the Mi3? Will the RW ones work?
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 04-21-2008, 11:09 PM   #25864
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
There are a few guys modifying RW gears to work. Otherwise, no, the Mi3 uses a specific spur because of the single sided layshaft design. If I'm not mistaken, the Schumacher Mi3 spurs are made for Schumacher by RW.
Jon Kerr is offline   Reply With Quote
Old 04-22-2008, 07:31 AM   #25865
abailey21's Avatar
Trader Rating: 36 (100%+)
Like Jon said the MI3 are a proprietary design, some are modifying RW gear, but I have stock off all gears offered 90, 96, 106, 114, 116, 118, which will cover you from a 17.5 down to a 2.5 mod on FDR.
Chirag
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-22-2008, 07:41 AM   #25866
Send a message via AIM to adamliehr
RIT dye works great to help keep the car looking clean. IMO it just looks like junk when all the white gets dirty. I dyed all my pullies and spurs black in about 5 minutes.
adamliehr is offline   Reply With Quote
Old 04-22-2008, 08:20 AM   #25867
Jon Kerr's Avatar
Kind of like this?
Old 04-22-2008, 09:23 AM   #25868
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
Chirag
a few pages back i posted a very easy way to use any spur gears on the mi3
Old 04-22-2008, 09:48 AM   #25869
Super Moderator
Marcos.J's Avatar
Here it is , i hope it helps
Well i have a over stock of regular Spur gears that I didnt want to let to waste so i came up with a very easy and simple solution to run regular spurs on the MI3 and the it took me less than 5 minutes and less than $2.00 to make. I went to the locar Advance Auto parts store and picked up a "hose tee" for engine vacumm lines part # 47341 for $1.88, then I cut a thin piece of the end (about 3mm). The bearing for the layshaft fits in it perfectly, then i slide the standard spur (after I drilled 2 holes on the spur) and tighten it. Now I can use any standard spur gear on the car Its very easy and the spur gear is alligned perfectly.
Old 04-22-2008, 10:16 AM   #25870
shaggy8's Avatar
hey guys i just picked up a mi2 to run in the trans am series. i was wondering with alot of people going to the mi3 if there were any people with mi2 parts they would like to get rid of????
i havent been racing long so expect wishbone and hub disasters, but would be interested in all mi2 parts.
pm me
shaggy8 is offline   Reply With Quote
Old 04-22-2008, 10:27 AM   #25871
Super Moderator
Marcos.J's Avatar
pm me
i got a bunch of front and rear arms if you need some
Old 04-22-2008, 01:11 PM   #25872
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Hey guys, I've got some winter rubbers I need to store until next winter. Any suggestions on keeping them from drying out? I was thinking just coating with tweak and putting them in a well sealed bag.
HVAC25000 is offline   Reply With Quote
Old 04-22-2008, 01:49 PM   #25873
Send a message via AIM to Dawn Sanchez
Hey Adam.. who's younger and cooler.. you or Shawn?
This is a question and answer thread, right?
Dawn Sanchez is offline   Reply With Quote
Old 04-22-2008, 02:41 PM   #25874
JayBee's Avatar
Trader Rating: 31 (100%+)
Jon, that's gay J/K buddy!! Looks real good
JayBee is offline   Reply With Quote
Old 04-22-2008, 02:44 PM   #25875
HVAC25000's Avatar
Originally Posted by Jon Kerr View Post
Kind of like this?
Now you've just gotta start mounting your own tires so you don't have to use those hideous white dishes!
Not to be a copycat but I believe I may tear my car apart this week and dye all my stuff too, it really makes the car look nice.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
