Old 04-17-2008, 02:15 PM   #25831
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
cool. THX : )
Old 04-17-2008, 02:38 PM   #25832
yokemad's Avatar
Originally Posted by Barger View Post
Yokemad...A bit of advice...mount the fan to the endbell..so it blows straight into the endbell...motor runs a lot cooler and more efficient...remember vents on can force air out
Thanx for advice that fan now broken but it blows the air to the end bell do you think that works or make the things worst???
Top deck is the standard euro top deck you can stiffen up one side of the car by rotate the Y shape eighter front or rear side but you can't use servo saver with it even normal servo horn has to be filed to fit...
Lipo Trackpower 4900
yokemad is offline   Reply With Quote
Old 04-17-2008, 05:20 PM   #25833
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MattW View Post
Well, no that is the way round that we run it - at least in the UK.
yea, but you drive on the wrong side of road too.
sorry couldn't help.
i did put it on that way, but my servo arm hit, maybe i need to space the servo out a bit and try again.
anyone try it both ways and find a difference.
skypilot is offline   Reply With Quote
Old 04-18-2008, 05:24 AM   #25834
Mopar's Avatar
Shawn or Adam, will Schumacher have a booth at the RCX show this weekend.
Mopar is offline   Reply With Quote
Old 04-18-2008, 05:29 AM   #25835
yokemad's Avatar
Originally Posted by skypilot View Post
its on backwards.
no room for the servo arm to move
no its not on backwards and there should be enough room cos car turns perfectly lol
Old 04-18-2008, 06:38 AM   #25836
abailey21's Avatar
Trader Rating: 36 (100%+)
Shawn is out there, i'm not attending (someone has to be here in the office)
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-18-2008, 07:21 AM   #25837
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Adam incharge of Schumacher U.S.A.?? scary!!
Old 04-18-2008, 07:57 AM   #25838
Send a message via AIM to adamliehr
Uh oh... Could this be the end of Schuie USA???
(insert terrified shreaking here)
Duh duh dunn
adamliehr is offline   Reply With Quote
Old 04-18-2008, 09:03 AM   #25839
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hahahaha....they sent the real OG....Robin to make sure he doesnt blow the place up. Its kind of like your parents are leaving for vacation and they send your Uncle over to watch you and make sure you make it out alive while they are gone.....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-18-2008, 09:51 AM   #25840
skypilot's Avatar
comparing your two posts, i'm confused
Old 04-18-2008, 09:52 AM   #25841
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I ran my Mi3 for the first time on Wednesday. Wow! What an amazing car. I loved it compared to my TC5 and it wasnt even setup completely.
I was having some problems with the rear shock popping off the arm mount. I am running the shocks all the way outside on the rear arms and it was rubbing the tire. I dremeled some of the material off but now the shock pops off if I hit the wall. Anyone have any suggestions? I think that I may have to move them in one hole on the arm and see if this helps or replace the bottom shock cup with one that has a through hole and use a screw or something.
Anyone selling a front one-way by any chance?
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 04-18-2008, 09:55 AM   #25842
skypilot's Avatar
Chirag
just about every setup i've seen or used the rear shocks are on the 2nd hole in.
Old 04-18-2008, 10:55 AM   #25843
Skypilot - Thanks for the help. I will make this change and replace the rear shock mounts. I wasnt getting enough traction in the rear of the car so I thought that laying the shocks down more would help by moving to the outside hole on the arm. I wil move in one hole.
Chirag
Old 04-18-2008, 11:55 AM   #25844
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Wuss...
Old 04-18-2008, 12:03 PM   #25845
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Randy Caster View Post
Wuss...
please go. you are not welcome here.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
