Old 04-16-2008, 08:47 AM   #25816
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by andrewdoherty View Post
I can't get the file to open . . .Anyone else have this problem?
It opened here at work for me which is strange....but the bottom part of the sheet doesnt look like it was ever scaned in or is just plain missing?????
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-16-2008, 08:52 AM   #25817
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
The 3200/3600 does fit very well with the different steering arms. I found the only problem to be the access to the plug socket inside the bulkheads. With the 3200/3600 packs, the battery will need to be securely mounted, which is difficult. I used tape and the battery trap with 2mm shims under the posts, but even that, it still moves around more than I would like.
You need to make sure it is secure because you don't want the battery to hit the bulkheads, the belt or the pinion—which it is close to all of them.
I actually found that the Orion Platinum 4800 fit better in the car—and more securely—as I could make 2 or 3 lexan inserts to tape to the bottom of the pack to fit into the battery slots on the chassis. With the Schumacher battery strap on the car, the battery doesn't move AT ALL.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-16-2008, 09:42 AM   #25818
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
OK, got it to open now . . . but K's right, the bottom is cut off. Any chance that could get fixed, or maybe just a verbal explaination of the missing portion? : )
Old 04-16-2008, 02:03 PM   #25819
yokemad's Avatar
yokemad is offline   Reply With Quote
Old 04-17-2008, 12:03 AM   #25820
Yokemad...A bit of advice...mount the fan to the endbell..so it blows straight into the endbell...motor runs a lot cooler and more efficient...remember vents on can force air out
Barger is offline   Reply With Quote
Old 04-17-2008, 04:10 AM   #25821
abailey21's Avatar
Trader Rating: 36 (100%+)
Or better yet, take all that fan and brushed stuff and add brushless!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-17-2008, 04:11 AM   #25822
abailey21's Avatar
Do you like that top-deck?? Is it the standard Euro, or flex euro deck?
Originally Posted by yokemad View Post
K.C.C.O.
Old 04-17-2008, 05:15 AM   #25823
skypilot's Avatar
Trader Rating: 14 (100%+)
its on backwards.
no room for the servo arm to move
skypilot is offline   Reply With Quote
Old 04-17-2008, 08:52 AM   #25824
any one know where i can get a p dub bumper that will fit the mi3?
i heard the mi2 fits?
schuie usa doesnt have them in stock any ideas where or when they will be instock?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-17-2008, 08:53 AM   #25825
abailey21's Avatar
Give or take I'm expecting delivery in about a week.
cheers
K.C.C.O.
Old 04-17-2008, 09:44 AM   #25826
jdm19turn's Avatar
i put servo tape on the chasiss then put battery tape on the battery and it works perfect the battery doesn't move at all and you don't even need a battery strap.
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 04-17-2008, 10:16 AM   #25827
Racer X's Avatar
The missing part on the bottom is the piviot block spacers which according to Adrians post is 3mm front and rear, but he is using 2mm front and rear and the shock possition which I believe is the second hole out (or that is what PDub usually uses). Hope that helps. I'll be trying this setup at SpeedWorld this weekend to see how it works in preperation for the Reedy Race. I'll let you know how it went.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-17-2008, 10:26 AM   #25828
Send a message via ICQ to MattW
Originally Posted by skypilot View Post
its on backwards.
Well, no that is the way round that we run it - at least in the UK.
MattW is offline   Reply With Quote
Old 04-17-2008, 11:02 AM   #25829
Matt, what handling characteristics have you noticed from trying the top deck both ways? I only picked one up the other week and I had servo foulage with it the 'UK' way so ran it the other way which seemed fine.
It seems it's more of a 'what works for you' kind of preference here, although I'd be interested to find out whether it's worth messing about with the horn and nut etc to make it fit both ways.
Andrew Twigger is offline   Reply With Quote
Old 04-17-2008, 12:08 PM   #25830
AdrianM's Avatar
I got the file from PW and it was cut off when I got it. The missing info is 2mm lower hinge pin spacers
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
