Old 07-24-2002, 10:03 PM   #2566
AdrianM's Avatar
Alex is very fast in practice today. Timmy is getting there very quickly. PW is hooked up and flying but cant dodge the novice stock drivers in practice well enought to get a clean run. He told me he got punted off the track so hard his front shock tower punched through the hood of his body.
Adrian Martinez
Old 07-25-2002, 02:10 PM   #2567
How is Jay doing? Is timmy running stock?
teamAE is offline   Reply With Quote
Old 07-25-2002, 03:57 PM   #2568
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Yes Timmy is runnin stock and I gotta give a little Wooot Wooo out to the short stack I hope he can make the main. I know hes got the Skill I thought him everything he knows Good luck guys and tell PW I feel his pain.......at least he did not have to pull his car outa the chain-link fence.....outch that hurt.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-25-2002, 06:09 PM   #2569
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Bring home the gold Team Schumacher
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 07-25-2002, 07:42 PM   #2570
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Schumacher Team should have GREAT SUCCESS at the NATS~!
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 07-25-2002, 08:46 PM   #2571
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Hey Adrian.. Just installed the new Warpspeed chassis. Two questions. When you run the motor shifted to the left what do you use for a belt tensioner? Is there a longer one? And second to run the servo in the crossways position what do you use for bellcranks?
thanks
ea
P.S. For any of you out there thinking of buying one of these chassis My car just tweaked perfectly right after building it. Plus there is a TON more room to mount reciever, speedo and transponder on the left side!!
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-26-2002, 03:11 PM   #2572
TTT
Old 07-26-2002, 10:21 PM   #2573
ottoman's Avatar
R/C Tech Charter Subscriber
Kevin K... I am converting my shocks to the losi shaft with the asociated pistons and I have a couple of questions. For my foam car I am using Rob Love's setup with #2 pistons and 80 weight oil. What piston and oil are you using for rubber on carpet? I also measured the kit pistons and the associated and I found the stock pistons to run about .005 bigger than the associated... is this going to be a problem?
ottoman is offline   Reply With Quote
Old 07-26-2002, 10:31 PM   #2574
JonB's Avatar
Send a message via AIM to JonB
I think a lot of the guys are using the losi pistons in the schuie shocks. I am running #56 losi black pistons with the losi gold shafts (.36). I can't remember who said it on here, but a few posts back someone said that the associated pistons are slightly too small and let a little too much oil through on the outsides. Also if you use the Losi shafts, the pistons are a direct fit you dont have to do any filing on the pistons.
JonB is offline   Reply With Quote
Old 07-26-2002, 11:11 PM   #2575
ottoman's Avatar
JonB... thanks... I will measure up some of my Losi pistons. I am still gonna use the asc. pistons in my foam car, I talked to Rob love and he recomended them with his setup so I will start there.
Old 07-26-2002, 11:14 PM   #2576
Kevin K's Avatar
Ottoman.....I ran the #2's and #3's the 3's in the front and thats still what I am using now with foams on carpet. I have been going to Trackside on sundays to get some practice on foams and my car is working very well right now. I will be there this sunday if you can make it down. I think that the extra blow by is not to much of a problem.
Old 07-26-2002, 11:23 PM   #2577
ottoman's Avatar
Kevin K... thanks for the info, wont make it down Sunday... got to race 1/1 scale car sat night.. no time to finish foam car. I picked up a second mission for the foam mod class and we are running the other in stock.. What piston/oil combo in your rubber tire car setup?
Old 07-27-2002, 09:12 AM   #2578
FIRST DAY OF THE ON-ROAD NATS!
Old 07-27-2002, 11:58 AM   #2579
Team EAM
After two rounds...Alex Lopez tied for TQ in Stock with Ron atomic and Timmy Heiser in 3rd.
eric a
Contact Us
Old 07-27-2002, 12:09 PM   #2580
Default Nationals
Hey EA, thanks for the update!! If its possible, can you see whats going on in mod?? Good luck to all of the schuie guys, wish I was there!!
pmccarson is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
