Old 04-10-2008, 02:43 PM   #25771
abailey21's Avatar
Trader Rating: 36 (100%+)
I'll remember that next time you need parts!
Originally Posted by jdm19turn View Post
lol..
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-10-2008, 02:55 PM   #25772
jdm19turn's Avatar
come on adam be a good sport ole boy you know it was funny..
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 04-10-2008, 02:58 PM   #25773
abailey21's Avatar
I know I know!!!!!
K.C.C.O.
Old 04-10-2008, 03:06 PM   #25774
Customworksking's Avatar
Trader Rating: 73 (100%+)
I know I know!!!!!
did u get the pm?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 04-10-2008, 03:10 PM   #25775
abailey21's Avatar
Yeah you told me to wait until I have motors????
Originally Posted by Customworksking View Post
did u get the pm?
K.C.C.O.
Old 04-11-2008, 08:46 AM   #25776
Glowster21's Avatar
Trader Rating: 116 (100%+)
Now that I'm the proud owner of an Mi3 I have a few questions......
1: Are there any other brand springs that will work on the shocks?
2: What would you recommend for spares running rubber tires/carpet
3: What spur gear would you recommend for a 13.5 to get the proper fdr with rubber tires?
I don't hit much stuff so I dont need a ton of crazy spares just the stuff that seems weak and any recommended tuning options. This is my first rubber tire car so I figured I would start with the best. I normally run carpet/foam but the rubber class is picking up steam. Most of the guys are running Jaco Greens so any setup info would be great too.
Thanks!
Joe
Glowster21 is offline   Reply With Quote
Old 04-11-2008, 08:57 AM   #25777
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
Most of them work well. I like the spring kits sold by Corally (black for rubber tires). Very consistent, plus cheaper and easier to find that Schumacher.
Get a few bags of the various thickness steel and purple aluminum suspension spacers. Everything on the car is adjusted with those, more or less. Arms, front knuckles... that's about it. I've had my car(s) for about 4 months and have only broken one suspension arm.
The 96T is a must have if you run 13.5 or slower with 64p. You can reach it with a 114T, but it's not fun. There is a 90T out now, too, if your pinions are not on the larger side.
It's a fantastic car—you're gonna love it. Just make sure you go over the car with a 2.5mm driver every so often and tighten all of the screws up. They tend to loosen up when you hit stuff.
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-11-2008, 08:58 AM   #25778
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have a set of the AE springs, a set of the schumacher springs, and a set of the xray springs. they all fit fine.
For spares I would get front arms, inner camber mounts, and hingepins.
You can run wither the 96 or 90tooth spurs. Youll need between a 35-45 depending on which spur you use. Your FDR should be around 4.3-4.6 with the novak or the SP
Old 04-11-2008, 09:03 AM   #25779
abailey21's Avatar
I've only used the stock springs, but I saw a lot of guys running X-ray springs at Snowbirds.
Depending on how much you hit, Front arms and hinge pins??
90t or the 96t spur for 13.5.
Thanks!
Joe
K.C.C.O.
Old 04-11-2008, 09:11 AM   #25780
slammin's Avatar
Trader Rating: 86 (100%+)
Send a message via Yahoo to slammin
Adam your care package is in route
RC Addicts AR
Agama A8t
Agama A215e
slammin is offline   Reply With Quote
Old 04-11-2008, 09:30 AM   #25781
abailey21's Avatar
Sammy call me at the shop before the end of the day!!
K.C.C.O.
Old 04-11-2008, 10:08 AM   #25782
Thanks!
Joe
Joe,
You will want to get front arms, a pack of front inner hinge pins, alloy shims, purple shim set, 4 and 6 degree blocks, stiff and extra stiff top deck, rear arms, 1 pack of cvd's.
I use the xray spring set.
Setup wise. A good one to start out with is Jimmy's from Vegas. It is on the Schumacher website.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 04-11-2008, 10:52 AM   #25783
the first thing i would buy is a p-dub bumper,,,with that, i dont break as many parts. i personally bought the mi-2 bumper, and re-fitted it for my mi-3
i think the mi-2 bumper is bigger, and gives more protection.
gdcopbdcop is offline   Reply With Quote
Old 04-11-2008, 10:54 AM   #25784
seaball's Avatar
Send a message via Yahoo to seaball
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 04-11-2008, 10:55 AM   #25785
Solara's Avatar
Trader Rating: 16 (100%+)
Joe...like i told you, once you owns a Mi3, if you have question, you will get answers, most of the time....more then 1 answer, in different angle, different area and differnet level. No matter what...you will get your question answered....good luck with the Mi3 and welcome to the win.
Check your PM
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
