Old 04-05-2008, 04:52 PM   #25711
TC3MIKE's Avatar
Send a message via Yahoo to TC3MIKE
I might just do that also. I think I will just order the 4000mah which is 20.5mm x 47mm x 136mm. You think I will plenty of runtime for 19x1/10.5?
TC3MIKE is offline   Reply With Quote
Old 04-05-2008, 04:54 PM   #25712
abailey21's Avatar
Trader Rating: 36 (100%+)
Not clue on SMC LiPo's runtime????
All I can speak on is the Core's and I was running about 21 minutes in 13.5 this afternoon before it hit the cutoff.
I was also about 1 second off the 10.5 lap times so they're very close, so I would say you should able to make a race
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-05-2008, 05:01 PM   #25713
TC3MIKE's Avatar
That was a 5000mah correct? Well, running over 21 minutes I guess that answered my question!
Old 04-05-2008, 05:02 PM   #25714
abailey21's Avatar
yeah I run the Core 5000 in my MI3 and I've never had an issue with run time
K.C.C.O.
Old 04-05-2008, 05:08 PM   #25715
TC3MIKE's Avatar
Are you able to tape lipo packs in? Sorry for all the questions but I really need to know.
Old 04-05-2008, 05:35 PM   #25716
yokemad's Avatar
Originally Posted by yokemad View Post
If I change Droop from 5mm front 4mm rear to 4mm front 3mm Rear is that gains the overall Traction of the Car???
Cheers
anybody??
yokemad is offline   Reply With Quote
Old 04-05-2008, 05:45 PM   #25717
abailey21's Avatar
We've found a couple different ways, strapping tape works good but you have to factor in the left to right movement.
I used the U3222 Battery strap, I removed the backbone and servo taped it to the top of my battery and used 3mm spacers under the posts to hold it in and not bind the chassis.
K.C.C.O.
Old 04-05-2008, 05:55 PM   #25718
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by HVAC25000 View Post
Now, for those of us that don't know (me), if you'd had the option, could you have run the same tire with a thicker insert to get less tire roll in corners, and stopped the traction rolling that way, or am I guessing wrong as usual?
if there were a premount available with a thicker insert and that would have stopped the traction rolling then i would use it, but i don't know if that would have been the cure. i guess i should have mentioned that i traction rolled with the old sp30, sorex 28, cs32, instead of chasing setups, (which i did for a long time) i just use a little CA now.
skypilot is offline   Reply With Quote
Old 04-05-2008, 05:59 PM   #25719
baf1's Avatar
Default fushion 28??????
pics of the car , fushion 28...
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 04-05-2008, 05:59 PM   #25720
skypilot's Avatar
if you use a piece of double sided scotch tape on the bottom of the lipo it will take care of the side to side movement. you can also check into battery locaters available from shouie and PPD EZ weights. there is a thread for the PPD
Old 04-05-2008, 06:25 PM   #25721
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by abailey21 View Post
You'll have better balance if you leave it out from under the bulkheads.
Hang it about 3mm off the edge of the chassis and you'll have great balance.
Be careful with this. By just hanging the battery and/or weight off the outside edge of the car, you're not really balancing the car. You're just giving the battery more leverage on the chassis. The left side of the car is still heavier than the right. Best thing to do while our basic car designs are still based on sub-c cells is to try and get the battery as close as possible to the same weight and distribution of that weight as similar to a 6 sub-c cell pack as you can. Id rather have weight attached to the top of the pack and have it be the same weight as a 6 cell pack over having some weight hanging off the outer edge of a pack that's shifted over to the right and weighs 2/3 of a 6 cell pack.A car is only truly balanced when the weight is distributed evenly and in the same location on both sides of the car.
Jon Kerr is offline   Reply With Quote
Old 04-05-2008, 06:30 PM   #25722
Jon Kerr's Avatar
Cheers
Sorry, I missed this. By changing both front and rear the same amount, you won't really be changing the balance of the car. You're really going to be limiting how much the car rolls all the way around. That should take away a bit of grip all around.
More droop in the front than in the rear is something I've never liked. Always made the car feel really twitchy going in and then just too stuck coming out of the corners.
Old 04-05-2008, 06:32 PM   #25723
Jon Kerr's Avatar
Are you actually CA'ing the contact patch or just up the side wall?
Old 04-05-2008, 07:23 PM   #25724
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
thats what i did i added weigth to match it to a 6 cell 4200 pack now my car is balanced and legal weight
RACE OPT USA
Bartolo Racing R/C
Old 04-05-2008, 07:47 PM   #25725
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
FYI, the Schui lipo locaters are designed for the standard chassis, and do not fit the carpet chassis. I rpefer to cut my own pieces of lexan and servo tape that to the bottom of my battery . . .
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
