Old 03-27-2008, 06:40 PM   #25591
abailey21's Avatar
Trader Rating: 36 (100%+)
It's an either or situation...
You can use the attached alligator clip (I use these)
Or you can plug the banana plug into the side and use that as well...
Or if your feeling frisky cut the alligator clips and solder on banana plugs instead
Originally Posted by jubilee View Post
A few of you guys must use the Core-RC charger, right?
I just got mine, and a power supply. In the 6 years I've been out of RC, I've either gotten dumber (very possible) or things have gotten more complicated.
My power supply has 2 holes on top to stick banana plugs into. The Core charger has an attached cord with clips....but it also comes with a banana plug harness, and a place to plug that harness in (right next to the attached cord with clips). How the heck do I connect this thing to my PS? Can I use that harness? Do I need to replace the clips with banana plugs?
I'm very sorry if this is ridiculously simple to everyone. I'm new to lipo and dc chargers. Don't want to screw anything up. Thanks for your help!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-27-2008, 06:41 PM   #25592
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
The SP power syply should have a normal wall plug that plugs into the wall and another little black wire that looks almost like a charging cord for like a radio well that little black wire will plug into the left side of the charger.
Hollywood
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 03-27-2008, 06:44 PM   #25593
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Hollywood
how many hollywoods do we have on rctech??
Old 03-27-2008, 06:49 PM   #25594
Trader Rating: 37 (100%+)
Thanks guys. Apparently I'm a bit slow.
So this thing comes with two banana plug harnesses: One with a male end to plug into the charger, and one with a female end to use with the various battery plug adapters...
Got it. Thanks again!
jubilee is offline   Reply With Quote
Old 03-27-2008, 06:58 PM   #25595
abailey21's Avatar
He meant on the charger itself polly poopy pants!
You playing in the dirt tomorrow night?
Hollywood
K.C.C.O.
Old 03-27-2008, 07:35 PM   #25596
skypilot's Avatar
Trader Rating: 14 (100%+)
the cord with the banana plugs on one side and a female plug on the other gets plugged into the right side of the charger, from there, you can use the cord with the male plug on one end and deans plug on the other for your core battery. i don't remember right off hand if it came with extra banana plugs for the left side,
jaybee will have to chime in. he is using the core p/s and charger.
ill be at SIR tomorrow if you want to stop by for a talk. (should be a good night of racing, lots of folks in town for the TCS weekend.
btw, you running tomorrow night JB
skypilot is offline   Reply With Quote
Old 03-27-2008, 07:59 PM   #25597
JayBee's Avatar
Trader Rating: 31 (100%+)
Yes, 13.5 foam w/the GT1(10.5) rubber guys unless there's another option
...and btw you guys are correct on the p/s issue.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-27-2008, 08:06 PM   #25598
drew07's Avatar
Hey guys whats up? Just wondering how many of you are planning to attend the ROAR NATS in june? If the weather hold up we will be doing some tire testing for the track owner this sunday to help pick the controlled tire for the race. After we get a better idea on what tire might be used i will be posting some good starting setups for this track. I must say one thing about the RCHOBBIES track, traction is something you will NOT have to worry about, the track is hooked. And i'm not just saying that because it is my home track, although it does help.
DREW,
TEAM LOSI/NOVA ROSSI/J-CONCEPTS/FRANCHIZE DEZIGNS/PROLINE/WERKS/FD WRAPS/AIRTRONICS/OS/AKA
drew07 is offline   Reply With Quote
Old 03-27-2008, 09:45 PM   #25599
Okay, I figured out how to hook this thing up. When I hooked up each new 5Kmah Core lipo (LiPo Balance charge: Auto), charge current went straight to 0.1A and batt voltage started at 7.4 then quickly rose to 7.6-something. Scared the crap outta me. Aren't these packs supposed to be 7.4 maximum?
Wish I could stop by SIR, but we've got out of town guests coming over.
EDIT: After reading the instructions over again, it looks like a final-charged voltage of a 7.4V batt should be "4.2V/cell for the nominal V of 3.7V/cell". What the heck does this mean?
Old 03-27-2008, 09:50 PM   #25600
STLNLST's Avatar
If Marcos J goes back to Schumacher then I may have to come back.....
STLNLST is offline   Reply With Quote
Old 03-27-2008, 10:04 PM   #25601
JayBee's Avatar
UH-OH!!
Old 03-28-2008, 05:12 AM   #25602
Super Moderator
Marcos.J's Avatar
might as well
Old 03-28-2008, 05:38 AM   #25603
Skiddins's Avatar
The packs are 8.4V maximum. 4.2V per cell.
The Core 5000 packs are two cells in series (2S) (all connected etc internally so you'll never see them.)
The balance connector has one wire connected to the same place as the positive, the middle wire connects inbetween the two cells, the third wire will go to the negative.
This middle wire allows the balancer to see the difference between the two cells as well as the overall voltage of the pack.
All lipo chargers should maintain maximum charge rate until the pack voltage reaches 8.4V, the charger will then slowly reduce the charge rate so the voltage does not go above 8.4V, this will keep reducing until the pack has finaly finished charging.
This all make sense?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-28-2008, 07:22 AM   #25604
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
You should come to Memphis and race. Ricky and myself are going up their to show the cyclone and xray guys how good Schui's run
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
slammin is offline   Reply With Quote
Old 03-28-2008, 08:27 AM   #25605
DavidAlford's Avatar
Send a message via AIM to DavidAlford
Are you just looking for another reason to bring the dress back out?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
