Old 03-13-2008, 04:45 PM   #25411
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Big Features View Post
Some guys (Ahem) are running the carpet chassis even onrubber tire carpet.
I like being able to put the servo saver as low a possible. Car tweeks less, and is more consistant corner to corner.
well now i'm confused, what does the chassis have to do with servo saver height?
skypilot is offline   Reply With Quote
Old 03-15-2008, 03:27 PM   #25412
hey guys does any one have a good baseline set up for low grip bumpy aphsalt?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 03-15-2008, 05:09 PM   #25413
Regional Moderator
Darkseid's Avatar
I believe the carpet chassis has an opening below the servo saver to allow it to sit below the upper chassis line.
TLR 22...Tamiya F104...
Old 03-15-2008, 05:22 PM   #25414
mi2ec or mi3 I see you have Mi2 in your signiture
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 03-15-2008, 05:59 PM   #25415
yeh gotta update that its (finally)a mi3
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 03-16-2008, 01:14 AM   #25416
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I am considering getting a MI3 for asphalt rubber racing this season. I also do carpet rubber racing. What changes need to be made back and forth to get the car setup from asphalt to carpet and vice versa?
I currently run a TC5 with lipos and a 13.5 BL.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 03-16-2008, 02:21 AM   #25417
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Looks like McGoo landed himself BQ with the Mi3 at Carpet Nationals in Omaha; .3 outta the A! Not to mention Steve "Magic" Marker near the top of the B as well in 13.5 rubber. If I am not mistaken both were running the SP GT!
Team Schui in effect!
Old 03-16-2008, 02:25 AM   #25418
zacabrandy's Avatar
Originally Posted by heavy View Post
Aaron, go to gearchart.com and choose the 1.8 option for Schumacher. You will need a 70t spur and a 36t pinion to get teh required 3.5 fdr or 56mm rollout. The 70t (48 pitch) is a schumacher part and the pinions - I use RW - are readily available in the zone of 35 through 38.
Thanks Heavy
zacabrandy is offline   Reply With Quote
Old 03-16-2008, 05:49 AM   #25419
Hey Josh,
I have a modified set-up for a low grip bumpy track, but its with 6cells,
I'm still testing a 5cell set-up and i'm not confident on writing it down on paper yet.
Set-up 6cell Mod bumpy track low grip
Kirby Masterman is offline   Reply With Quote
Old 03-16-2008, 12:11 PM   #25420
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Kirby Masterman View Post
Hey Josh,
Where's the set-up sheet associated with this link?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-16-2008, 12:26 PM   #25421
yokemad's Avatar
hi guys
I 'm just wondering how important is the side to side chassis balance cos im running lipo with no added weight ....
also just bought an 5 cell chassis gonna use with lipo does it makes any negative effect over 6 cell chassis (current 6 cell chassis really in bad cond. thats why i've got near new 5 cell chassis on flebay )
cheers
yokemad is offline   Reply With Quote
Old 03-16-2008, 01:50 PM   #25422
Attachment 320783
Try this setup. I think it will be a good starting point.
You might want to add some more rear toe.
Steve Walter
Old 03-16-2008, 03:22 PM   #25423
Originally Posted by yokemad View Post
hi guys
cheers
6 weeks ago I would have said you gotta have it balenced. I spent a lot of time adding lead in all the right spots to get my Mi3 balanced with an Orion 4800. It ended up being about120 g over weight though. So when I bought my core batteries I just put them in aligned with the edge of the chassis (I couldn't so this with the Orion because of the outputs on the batery) I know I am heavy by a lot on the motor side, but I can't realy feel it on the track. It may jsut be I am not a precise enough driver to feel it, and I used to be able to feel it all the time if I had the car unbalanced. I say try it without the weight first and ten ad weight and see which way feels better or is faster. I left the weight off so I could get down to minimum and I am a couple tenths faster too now. Could ust be the CORE.
Old 03-16-2008, 05:21 PM   #25424
Trader Rating: 15 (100%+)
Juan aveytia was also running sp stuff in the 13.5 a main.
AARON YOUNG is offline   Reply With Quote
Old 03-16-2008, 05:45 PM   #25425
yokemad's Avatar
Thanx Andrew
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
