Old 03-13-2008, 04:42 AM   #25381
heavy's Avatar
Trader Rating: 20 (100%+)
Aaron, go to gearchart.com and choose the 1.8 option for Schumacher. You will need a 70t spur and a 36t pinion to get teh required 3.5 fdr or 56mm rollout. The 70t (48 pitch) is a schumacher part and the pinions - I use RW - are readily available in the zone of 35 through 38.
Originally Posted by zacabrandy View Post
There is no roll out charts for the Mi3 on gearchart.com.
Whats the transmission ratio for the Mi3 and where do you get your rollout charts from?
Also for running a 17.5 brushless, what pinion/spur combos are people running? For a range of tracks from smallish to large open types.
I here the rollouts need to be somewhere between 50-60mm for the 17.5.
Cheers
Aaron
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 03-13-2008, 05:02 AM   #25382
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If you want to stay with 64p you can also go to a 90/50 combo for a 3.2 FDR
Old 03-13-2008, 06:33 AM   #25383
Regional Moderator
Darkseid's Avatar
Cheers
Aaron
Yeah, I've heard the same thing about 17.5 rollouts. Personally, I don't see how people do it. The temp of the motor really starts to climb when you get up above 52mm of rollout, so to think of people running 56mm, is just nuts! And I can only assume those are some pretty large, open, tracks people are running those rollouts on.
In any case, I run on a relatively small carpet track, and I pretty much stick to the 48-52mm range.
TLR 22...Tamiya F104...
Old 03-13-2008, 06:33 AM   #25384
Regional Moderator
Darkseid's Avatar
Is the 90t spur out yet?
Old 03-13-2008, 06:34 AM   #25385
abailey21's Avatar
Trader Rating: 36 (100%+)
yes!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-13-2008, 06:39 AM   #25386
Regional Moderator
Darkseid's Avatar
Originally Posted by abailey21 View Post
yes!
Well heck, I gotta keep up with the thread better man!
90t spur - U3269
right?
Old 03-13-2008, 06:42 AM   #25387
abailey21's Avatar
that is correct!
I need to keep parts up here better...I'll work on that
K.C.C.O.
Old 03-13-2008, 07:18 AM   #25388
abailey21's Avatar
So being that Darkseid is right and I haven't been on here much with new parts and what not....
U3269 - 90t spurs in stock
U3270 - 106t Spurs in stock
U3271 - LiPo Battery Keys in stock
U3248 - 96t Spurs in stock
U3272 - 5 cell euro chassis in stock
U3274 - Euro flex top deck in stock
U3273 standard euro top deck in stock
CR025 - 4A Core charger in stock
CR026 - 5A Core charger in stock
CR027 - 6A Core power supply in stock
CR035 - M4 serrated wheel nuts blue in stock
CR036 - M4 serrated wheel nuts purple in stock
CR032 mini alloy tool kit in stock
CR004 - Core 5000 LiPo in stock
There's been lots of talk about the 2.5mm chassis on carpet and asphalt (U3146) they are in stock as well
I don't know whats on the horizon for any new parts, but suggestions are explored
K.C.C.O.
Old 03-13-2008, 07:57 AM   #25389
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-13-2008, 07:58 AM   #25390
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
How about some news on the 4wd off-road car????
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-13-2008, 08:07 AM   #25391
abailey21's Avatar
It's coming in 2008
It will have 4 wheels, shocks
It will be 4WD
and the rest is a mystery
K.C.C.O.
Old 03-13-2008, 08:17 AM   #25392
Kevin K's Avatar
It's coming in 2008
It will be 4WD
Unacceptable....
Old 03-13-2008, 08:26 AM   #25393
abailey21's Avatar
Shenanigans!
You will accept what we make public and that is public info, on a side note my avatar is the new 4WD buggy, look closely, you can almost see how fast it is
K.C.C.O.
Old 03-13-2008, 08:40 AM   #25394
Kevin K's Avatar
Clearly your avatar is motionless so it would be impossible for me to tell just how fast it is…..ohh and yes I will be drinking your Milkshake now.
Old 03-13-2008, 08:41 AM   #25395
abailey21's Avatar
Milkshake you can have...
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
