Old 03-06-2008, 08:58 AM   #25336
academygaz's Avatar
Last week I had one my front left shock leak all its oil in a race, I don't know what caused it as I didn't hit anything - they've gone a couple of months without a rebuild though. I've just taken the shock apart and the top black bladder has split.
As I can't open PDF's at the moment, and I haven't got a manual, are the bladders available on their own or is it just as part of the Race Shock Seal Rebuild Pack (U2999)?
Or are there any other bladders that fit?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 03-06-2008, 09:41 AM   #25337
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I believe the much more bladders work in a pinch.
Old 03-06-2008, 09:54 AM   #25338
Regional Moderator
Darkseid's Avatar
If the exploded diagram PDF is correct, then the bladders are only availible as part of U2999
TLR 22...Tamiya F104...
Old 03-06-2008, 10:02 AM   #25339
abailey21's Avatar
Trader Rating: 36 (100%+)
That would be correct, U2999 is the shock rebuild kits that have new bladders in them
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-06-2008, 01:31 PM   #25340
academygaz's Avatar
Thanks guys, I'll get the rebuild pack and change the o-ring on each while I'm at it.
On a similar note, has anyone had the gold colouring turn silver as the shock shaft enters the unit?
Old 03-06-2008, 01:47 PM   #25341
Regional Moderator
Darkseid's Avatar
When the car first came out, I recall someone mentioning this, but they came back later and said that they had made a mistake in building the shocks(not sure what mistake) and that led to the loss of the shaft coating. So I'm not sure if this is something that happens over time, or if its a shock building issue.
I know I've had a couple different cars with this type of coating on the shock shafts, but no matter where I ran the car (indoors/outdoors) I've never had the coating wear off.
Old 03-06-2008, 02:16 PM   #25342
abailey21's Avatar
I had the same thing happen to my original shock shafts, I changed them out and I have not ever had a problem since.
K.C.C.O.
Old 03-06-2008, 02:22 PM   #25343
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
that shouldn't really ever happen. it takes alot to rub off a TiN coating. essentially this is caused by sideloading the shaft. installed, the only way for this to happen is to have friction in either ball joint (cup, or cap). you have to trim the flashing off of the plastic balls up top or the shock will press on, and bind. additionally, you can't tighten the locknut too far or the ball will expand radially and (again) bind up the shock. sitting on my car stand, i always make sure the top of the shock moves in/out really easily with a slight brush of the top of it.
i think our upper shock mount is one of the best in the industry. it allows you to take out any slop a standard ball joint would have by how much you tighten the locknut. it's little things like this, that aren't on a setup sheet, that people don't always know how to duplicate.
-- brandon lattimer --
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-07-2008, 06:09 PM   #25344
justin lessard's Avatar
Send a message via AIM to justin lessard
Whoa.
justin lessard is offline   Reply With Quote
Old 03-07-2008, 06:32 PM   #25345
abailey21's Avatar
Good Morning Sunshine!
Originally Posted by justin lessard View Post
Whoa.
K.C.C.O.
Old 03-07-2008, 07:24 PM   #25346
HVAC25000's Avatar
Trader Rating: 19 (100%+)
HVAC25000 is offline   Reply With Quote
Old 03-07-2008, 07:48 PM   #25347
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
dont forget the anchors for tomorow!!
Old 03-07-2008, 07:49 PM   #25348
well,all I can say is..KLING PWNS BAILEY!
Old 03-07-2008, 10:12 PM   #25349
Big Features's Avatar
Justin, your youthful lexicon escapes me.
(WTF Does PWNS mean???)
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 03-08-2008, 12:13 PM   #25350
TC3MIKE's Avatar
Send a message via Yahoo to TC3MIKE
Its a term they use in chess.
TC3MIKE is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
