Old 07-17-2002, 08:18 PM   #2521
Pit-racer's Avatar
Racer X can I have your asphalt set-up for the mission also.I'm setting up my mission to race Markg on asphalt in the near future...
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 07-17-2002, 08:55 PM   #2522
Racer X's Avatar
KingG: No you can't since the nut would interfere with the steering arms. The part must be threaded which is why the Fireblade part is used. The end result is matching the front and rear hingepin heights
Pit-racer: I'll get that out to you and Randy...I really hope tomorrow. Summer is supposed to be the slow time, but the last three days have said different at work. Tomorrow...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 07-18-2002, 01:54 AM   #2523
Send a message via ICQ to JesseT
I think the point was to use the other rear hinge pin mount. The one with two screws. I think it will do if the height is shaved down slightly. I made some custom mounts out of aluminum. I can post some pics after I've anodized them.
JesseT is offline   Reply With Quote
Old 07-18-2002, 04:51 PM   #2524
King-G's Avatar
Send a message via ICQ to King-G
yeah sorry for teh confusion, this is what I meant...the hingepin mounts for the rear of the car....perhaps the ones which can be flipped for rear inboard toe. possibly need shvaing down as JesseT has said
King-G is offline   Reply With Quote
Old 07-18-2002, 04:54 PM   #2525
PW
PW's Avatar
Send a message via AIM to PW
jesseT....You have to remove to much material away from the rear blocks for the bellcranks to clear. That is the way we did the first prototypes and we found the alloy blocks to work much better, plus you can flip the alloy block over and run the stock roll-center.
BTW, the new Warpspeed Chassis (3mm) is in stock now and we are also taking orders for the 2mm chassis due to arrive in 2 weeks time.
PW is offline   Reply With Quote
Old 07-18-2002, 06:44 PM   #2526
King-G's Avatar
Hey Paul or Racer X, I have 2 different part no's here for the fireblade hingepin mounts, could you please tell me which part to get in:
u1988: O deg pivot
u1989: 3 deg pivot
Cheers
Old 07-18-2002, 07:45 PM   #2527
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
King G......you need both part numbers for the mod. The 3 deg blocks go in the front and the 0 deg blocks in the rear.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-19-2002, 09:41 AM   #2528
Send a message via ICQ to MattW
King G, we've just used the 3 deg block in the UK.
MattW is offline   Reply With Quote
Old 07-19-2002, 10:07 AM   #2529
Racer X's Avatar
KingG: The O degree blocks are used in the rear. The 3 degree blocks are for the front if you choose not to use a spacer, but the 3d blocks prevent the use of the optional 2d rake hingepin mount. If you use the spacer (2mm thick), the 3d blocks are not needed.
Schumacher Mi6
Integy
Old 07-19-2002, 10:13 AM   #2530
Racer X's Avatar
Those who have requested my Mission setup, please send an email to [email protected] and I can send it back as an attachment.
Schumacher Mi6
Integy
Old 07-19-2002, 08:43 PM   #2531
Pit-racer's Avatar
Thanks Racer X got it!
Old 07-20-2002, 02:00 PM   #2532
Racer X's Avatar
Everyone who requested a setup sheet should have one in their email by now. If anyone else is interested, or if you requested one and haven't gotten it, send me an email...
Schumacher Mi6
Integy
Old 07-21-2002, 05:11 PM   #2533
4jw
Default Mission Upper Wishbones
Has anyone been having problems breaking upper wishbones? My son and I seem to be breaking upper arms everyweek. Does anyone make any after market upper arms?
Thanks Jack
4jw is offline   Reply With Quote
Old 07-21-2002, 06:29 PM   #2534
King-G's Avatar
yesterday testing indoors I broke an upper left rear arm, wasnt a fault of the cars, as I brushed a pipe exiting a hairpin, the PVC pipe has a metal joint which loves wheel nuts!...it grabbed the nut and tore the wheel rearward.
I was well pleased to see that the upper arm was the only casualty..The schumacher cars are very durable, very well engineered, and very few spares are required....
I have found that the upper arms, and a pair of front and rear lowers are all thats I have needed.
Old 07-21-2002, 08:07 PM   #2535
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Default Re: Mission Upper Wishbones
Jack, I have broken one upper A arm in the 3 months I've had my Mission, and I'm certainly not a perfect driver. That one time was a pretty good lick against the pipe. I'm not bashing you or anything, but are you guys hitting the boards pretty often? Are you doing anything to modify or change the arms before you install them? Do your front tires stick out of the body any? If you are still learning to stay off the pipes, you might try one of those BRP front bumpers for a TC3 (Ithink). You can mount it to the bottom of the Mission front bumper and trim it to fit your body. It will help a ton if you're brushing pipes. You might also try a different body. The body plays a big role in protecting the front suspension. If you don't believe me, try running a few laps without it... hehe.
Hope this helps!!!
BigDogRacing is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
